I've been in that same situation where the urine was so bad that muriatic acid wouldn't free the bushings. Replacement was the only option. As for Yamaha parts department. Over the years I have witnesses a deterioration with in-stock parts -- 6 weeks or more for common items and the only person you have access with piano knowledge is David Durbin.
Sent: 02-18-2023 16:29
Subject: Rusty Yamaha Brass Casters
I have been there and tried the repairs to the seized casters trying all sorts of things including rust busters, ammonia, wire brushes, wire wheels, brasso . They where so bad it was as if they where welded. Because of the supply chain fiasco it took 15 weeks to get new G2 casters. two arrived and the third came 2 weeks later. Went to install them and found out they where oversized for the hole. required making a template/jig and routing out a slightly larger mortise. The same piano required a completely new lyre including new petals. The brass pedals had green verdigris all over that would not come off. In addition the pedal box felt and wood had been thoroughly soaked by urine and even after a month outside on a protected porch it smelled. Yamaha searched their stock rooms and found the exact lyre in the same finish. It was a short height that bolted to a mounting block . The piano was 1980's vintage so 40 + yrs old. Another yamaha upright had the right pedal horn snapped off. Yamaha had a complete set of 3 exact finish and shape and that piano was 1970's.
Sometimes we get lucky
Sent: 02-18-2023 13:51
James,
You have almost zero chance of getting replacement casters for a Yamaha of that age. In fact you likely need to wait months for those casters for current U1's. There are times when we as technicians need to deal with the reality that we must repair, to the best of our ability, those issues where the replacement option is impractical or impossible.
Roger Gable RPT
Gable Piano
Everett WA
(425) 252-5000
Sent: 02-18-2023 13:24
Just order new ones from Yamaha along with screws and whatever items like sockets/plates/bushings. Beware that current production may be different and not an exact fit and may require some woodworking. I recently had to do replacement casters on a G2 grand- old ones totally seized and discolored with verdigris, rust due to pet urine. I would not mess around with chemicals , polishes or home brews. Chemical burns, fumes , water and acid reactions, splashes,fumes are bad for you.
Sent: 02-18-2023 12:35
Wim,
Pardon my reply to your post. I'm a stickler about nomenclature. Yamaha casters (U1) don't employ bearings -- they use pin and bushings. There is a difference and could have a bearing (pardon the pun) on how to treat the problem. Bearings, both roller and ball would definitely be destroyed with harsh chemicals such as muriatic acid, whereas pins and bushings used in those casters could survive the chemical if not left in the acid too long. Also, one needs to use rubber gloves and thoroughly rinse the product with water after emersion.
Roger Gable RPT
Gable Piano
Everett WA
(425) 252-5000
Sent: 02-18-2023 12:17
Replace them. You'll have to drill out the screws that hold the caster to the legs. And, the stems and casters bearings will be too rusted to get them to work.
