Gentleman all excellent suggestions that will really help. It could be one or more of these things. Fortunately I have an Edwards action caddy so I can get the action out and moved to the side. Another one of those piano placements done in a corner of the room looking into the room. I am trying to save my hands , arms and back by not lifting actions . I wish I had bought that cart years ago- I got one autographed by LaRoy.....
Anyway I will through this beast from bottom to top. I think the player never noticed because the dampers in the tenor/treble clear the strings just enough but you have to mash the pedal down. Some people never notice this as long as they get a response.
This piano had issues about 7 years ago when action centers kept seizing randomly. I did 3 callbacks within a week because the piano was to be used for a dine around fund raiser with a hired pianist. Every time I went back the problem was with notes I had not treated. I made pencil notes on the hammer flanges A0 had only a 1/2 swing using the swing test. after protek treatment swings went to 6. Yesterday it was between 5 and 6. All of the ones I treated in 2015 that had 1/2 to 1 1/2 swings where still at 5 to 6.. I took some hammers home and popped center pins out and all where size 21 and silver, no obvious score marks or plating issues. Susan Kline commented to me they may have been replaced by another tech under warranty since the standard pin was size 20 . Does anyone have experience or re-collection when the seizing pin flu was an issue with YC and associated brands, This is a Samick SG-140
Sent: 07-01-2022 09:42
Subject: Samick Grand SG140 damper tray lift
Sounds like PMS. Pitman was lost in the move.
Sent: 07-01-2022 05:46
There is another possibility that the rubber grommet in the lift tray is missing. A small hammer-shank would fit in the hole and make it work, somehow. As was suggested by Steven, the current pitman doesn't sound original. A hammer-shank is too small to insert a pin into. What may have happened is the original was lost in a move, and a tech may have tried to fashion a new one without knowing the original length, and/or didn't have enough time or a proper dowel and pin to recreate what was there. What you describe is exactly what would happen if the pitman was too short. And if the grommet is missing, you'll have to create something to take its place like a piece of leather to cover the large hole (about 1/4"). Or get a new grommet. If you can lift the tray by hand and everything works, you know it's not the tray pivots.
