Actually, on all the tubular set ups like this that I've seen, the bolt/pin that holds the tube is a carriage bolt, it won't twist, you have to pull it straight out. If you remove the wing nut and let the tube come off the pedal completely it will remove the tension of the spring and the bolt might slide out easier giving you access to the bracket and the mounting block.
But it looks in the picture like the tube comes really close to the plate near the bass bridge so you might not have much wiggle room. You could always drill another hole in the pedal if you want to move that threaded rod back away from its present position.
Sent: 03-23-2026 01:27
Subject: Samick SM3A pedal issue
If you haven't got the tube axle out, you haven't gotten to the most likely root of the problem, which would be the compromised plastic bushings in that interface. Until you replace those, you will have both a misaligned tube and increasing noise in the mechanism. Pushing down on the tube against the coil spring is a necessary part of the strategy for getting the axle out.
Sent: 03-22-2026 12:27
This piano, was donated to the church several years ago.
Partial success. The pedal axle plastic washers were broken/missing and I was able to replace them with bushing cloth and leather washers.
The flat part of the tube connecting the pedal to the rod overhangs the wood further than the distance I could move the pedal into the piano, so moving the pedal would not fix the issue.
There is only one hole in the pedal for the bolt connecting the pedal to the tube, so I couldn't just place the bolt further back to get the tube off the wood.
The screws for the tube support are under the tube. You would have to remove the tube to get to the screws. There is a 9 mm nut on the back of the axle, but the axle wasn't coming out, there was no room to get good leverage to push it out. Even if I did, the wood was so narrow I couldn't place the left screw further to the front in order to reposition the tube.
Previously someone had tied the two tubes together to pull the sustain pedal tube back. That had slipped, but I retied it as a temporary fix until I can go back with my Dremel and hacksaw to remove enough of the flat section.
The middle pedal has a loose nut on the back, but you can't get a nut driver in because the pedal overhangs the nut.
[ not sure if the photos will be attachments or just show in the post ]
Sheffey Gregory, RPT
Sent: 02-21-2026 14:56
I always carry a small hacksaw in my tool bag. A hack saw does not generate sparks and could be used without any further concerns, aside from perhaps protecting against metal crumbs.
Sent: 02-21-2026 10:38
It occurred to me after my 1st posting the grinding down the corner of the lifter arm is the "hack" repair. Not that I might no do it. However, I think addressing the actual cause would be better and I suspect the plastic pivot bushings or loose pivot mount. If grinding is necessary it will likely generate sparks so ample protection of the floor and case parts with a moving blanket would be in order. Better yet to remove the lifter arm and grind on a bench.
Tremaine Parsons RPT
Georgetown CA
(530) 333-9299
Sent: 02-20-2026 18:21
I think Floyd is onto something that the problem is at the fulcrum. If not plastic bushings, then perhaps the screws holding down the metal stamped bracket that the rod pivots on have loosened, it wouldn't take much. I would check those screws and maybe even try to loosen them and push the lever into position before retightening.
I have seen the flattened tubes, sometimes the corners are trimmed.
Sent: 02-20-2026 17:34
I seem to remember it hits the toe board but not the knee board. Adjust so the pedal doesn't go down so far.
