Chris, I like the various YouTube vids that you have been doing. I agree that there is no ultimate string scaling software and string scale is only part of the whole picture. However, techs have to start somewhere and Scale Ripper is free and allows Techs to get their feet wet and at least start to grasp the concepts. I know you started with a string scaling program and then ultimately went on to develop your own spreadsheet which likely gave you more control regarding whatever you wanted.
I know the S&S bought the original Atari Scaling program from Dr Sanderson most likely just to have more information because I'm inclined to doubt that they would change much even though a Stein B note 21 plain wire has only about 120lbs of tension. Flabby and harder to set the pin. But, hey, its a S&S
Also looking at things in the Paulello Typogram is enlightening. This gives us more information to ponder or try out. There are many in the Paulello camp these days. I no longer do much rebuilding so have not yet experimented with Paulello but it certainly makes sense in concept.
Any time we can have a little more information about anything is helpful provided that we can consider things rationally as to what may be correct (or not). Or, somewhere in between
All the best! Tremaine
Tremaine Parsons RPT
Georgetown CA
(530) 333-9299
Sent: 02-01-2023 13:52
Subject: Scale Ripper
In my opinion none of the available software is sufficient for a well thought out re-scale. Just getting the tension even is just the beginning. From there you got different tensile strengths of different materials and brands. You learn a lot by breaking wire.
None of them even talk of proper proportion of single, bichords, trichords, let alone the option to calculate the proper ratios. WmB.White talks about that for reference.
Sent: 2/1/2023 1:43:00 PM
Subject: RE: Scale Ripper
Well that makes sense, thanks John!
Tim Foster
Sent: 02-01-2023 13:33
TIm,
Scale Ripper core diameters are in mils, not mm.
John Rhodes
Vancouver WA
(360) 721-0728
jrhodes@pacifier.com
Sent: 02-01-2023 13:25
I'm not familiar with Scale Ripper but there are a couple other options: Tremaine Parson's PScale and Arno Patin's Abacus.
