Thank you for your review and opinion.
Sent: 01-23-2026 08:32
Subject: Solution for loose tuning pins
Quite frankly I would discuss the fact that the piano is exhibiting signs that it has reached it's expiration date. Time to start looking around.
People buy these things THINKING they are built to last generations...poppycock! They need a dose of reality. 30-40 years is about it especially for pianos like this.
Sent: 01-21-2026 22:52
For the larger pins (#4 and 5), did you drive or screw them in? How did you remove the original pins?
CA might be the best treatment in this circumstance.
Sent: 01-21-2026 13:57
Sounds to me like the pinblock is probably cracked and any efforts to tighten with larger pins or sleeves/shims will only expand the crack. Which, I would guess, is why they were ineffective.
I have heard of pulling the pins soaking the pinblock with thin epoxy and re-drilling, but I would guess that's beyond what the piano is worth.
Maybe someone else will have a suggestion for an effective repair.
Trevor Penner
Hillsboro KS
(620) 877-0306
music2himalone@gmail.com
