Hi Peter,
I am a bit late to the game here...
Like Horace and others, I too have removed the removable cross braces from numerous Steinway pianos that have them, never with any issues with the piano.
Some time ago, a fellow tech advised me that if, after removing the screws, the removable brace is under tension (end to end, pushing horizontally again the string frame), it is best not to remove it. Presumably, this would be because of difficulty replacing it and/or possible negative effects to the piano from taking it out.
A manufacturer's representative who was in the know once told me off the record that it should not be a problem. (It was at a convention, and there may have been alcohol involved...)
Sent: 06-17-2024 08:10
Subject: Steinway B Cross Brace
So...in the final analysis it would seem a "safe" thing to do since if ever a serious problem had erupted as a result we doubtlessly would have heard about it.
Plus, I guess that if it was determined (and spread) that the entire structural integrity of the piano rested on this one little bar...the PR nightmare for Steinway would be "significant". So I'm thinking it's just fine to take it off.
Thanks for all the input!
EDIT: I wonder if on any of these models in history that this bar was also conveniently and boldly emblazoned with the company name, etc...?
Sent: 06-16-2024 13:19
I cared for a university piano years ago that a musician had removed the cross brace because it was buzzing. It had been off for years. Piano seemed fine.
I did order one from Steinway with bolts and with a little grinding/filing was able to get it to fit like a glove. It is still fine (since late 80's) and doesn't 'buzz'.
Nancy Salmon, RPT
