I do not agree with the idea that felt or other materials such as a sheet, blanket etc make for a good string cover. 100 % wool is superior and will absorb moisture and water for a bit of time. It will also do a great job of holding dust, dirt and debris. A Kawai grand was saved from being a total loss by a 100% woolen cover I purchased from Dawson String Cover. The drain for a bathtub on the floor above the piano had failed and water poured all over the lid of the Kawai directly below. The owner opened the lid and found that the string cover had collected a puddle of water in the area over the bass strings, tuning pins and soundboard. Absolutely no moisture got to the action, pinblock and just a little reached the bass cheek block .
I am currently working with a customer who has a Boston Grand right on the ocean. Even though the temperature seems comfortable the humidity readings are in the high 60s low 70's . I am going to collect more info 24x7 with a data logger but the truth is these homes are exposed to all sorts of good and bad weather, moisture laden air, air currents. She is ordering a cover because it will absorb the excess moisture that would otherwise settle on the strings. In addition she will be using a dehumidifier in a corner of the room.
Sent: 09-17-2022 09:27
Subject: strange string corrosion
Fleece repels water (I wear my fleece jacket in the rain!) Seems that should be OK for a string cover.
Sent: 9/16/2022 3:58:00 AM
Subject: RE: strange string corrosion
I have always felt that felt is the wrong material to use for string covers. In my opinion, felt absorbs moisture when the humidity is high, and then releases it later when the humidity is low.
I've always bought string covers with a nylon blend with cotton. I get mine from Guye at Instrument Covers.
guye@pianocovers.net.
