The more practical question is if you tune a piano completely at one temperature and then the whole piano changes temperature together how much does that usually affect the tuning? I've heard that the strings change temperature first but then the plate catches up which will compensate to a surprising degree sometimes.
For 20 years I've tuned a little piano at a Grange hall out on the countryside. One year it was about 50° in there and I could actually see my breath. Oddly, the piano was at pitch and the octave spread was surprisingly good. This was a Wurlitzer spinet.
In his book under the lid, Steve Brady recommends not having the stage lights turned on right before a concert tuning because of the temperature change during the tuning. Either tune in the dark with a headlamp, or let the piano warm up for a few hours prior to tuning.
It's a bummer to have to reschedule a tuning and miss that income due to a situation as mentioned above. I'd be tempted to go ahead and service the piano perhaps focusing more on voicing or regulating instead of tuning. Then it would be interesting to follow up a few weeks after the heat is on and see what changed. There's nothing like seeing what happens in real life!
Ryan Sowers RPT
Sent: 01-12-2023 14:49
Subject: Temperature vs humidity question
....."But how much does a change of temperature affect strings and plate and it's affect on tuning?"
Almost immediately.
If you put your finger on one or two strings at A4 for just a few seconds you will see how much that little bit will (temporarily) change the pitch.
