  • 1.  Testing & repairing grand damper flanges on-site
    Posted 11-26-2025 14:10
    I am committed to doing a complete test of the main [2] damper centers on a Chickering CH189 6'1" Grand #77667 [year not findable -- 1980's?]. I did an action overhaul regulation in 2023, and have twice now done single unplayable tight-damper repairs. Last time I outlined the correct procedure if it happened again: test ALL of them while it was apart, then repair, during that same session, any that are tight.. During this November's service, a damper in the tenor had the familiar problem. It would not return and would not respond to any type of quick-fix stuff and needs removal/testing/repinning. He understands what's happening. I'll go there and find all of the tight ones and repair them.
    I'm looking for help in this post, regarding working efficiently. I suspect these are Young Chang parts, although I would have been guessing Samick for the manufacturer. Long ago, I did a bunch of Young Chang sets in the Toronto Canadian warehouse that existed at that time, and also under warranty in people's homes. But I don't remember exactly what I did. I think: Move stop rail up, remove sostenuto, take each one out individually with the damper attached, test the two pivots by feel or gram gauge, re-install or repin. I'd love to go in there a bit more prepared ... like smarter than I am now. I'm assuming the tight-ish ones will be completely de-attached from the damper to accomplish the re-pinning part.
    Any words of wisdom are welcome!
    And while we're here, does anybody know what's up with Young Chang centres being the only late 20th century company it seems that cannot have centres fixed by chemical treatment [sizing/lubricating] using chlorofluorocarbon liquid or whatever protec is, silicone-naptha, etc, etc. I have never learned why they are impervious to our usual quick repairs. Entire sets of console jacks, upright hammer flanges, grand dampers, more. It's a real hassle when one suddenly gets tight, along with the aspect that any one in the future could suddenly get too tight to operate.
    Well .... that's my rant-like question. Thank you.
    David Patterson RPT
    Newmarket ON
    (416) 638-0901
  • 2.  RE: Testing & repairing grand damper flanges on-site
    Posted 11-26-2025 14:33
    David
    Tight Young Chang/Samick centers have been discussed on this list many times, including some remedies that work, and others that don't. In my opinion, these centers, including jack, wippen and hammer flanges, all behave like the old Steinway verdigris problem. The best and only permanent solution is to replace them. Which, of course, is expensive. So one must ask, is it worth it? Realistically it would be. Even spending $3-4K is still cheaper than buying a new piano. Practically, it depends on if the customer wants to spend that kind of money. If everything about the piano is good, tight pin block and no wear on the hammers, it is worth it. But it's the customer's decision.
  • 3.  RE: Testing & repairing grand damper flanges on-site
    Posted 11-26-2025 16:23
    As long as you're reaming the flange bushings with the Mannino broaches, you should be good. Probably best to do it to all of them, rather than having some that appear OK today seize up in the foreseeable future.
  • 4.  RE: Testing & repairing grand damper flanges on-site
    Posted 11-29-2025 18:12
    I think it is hard to really evaluate the back action without completely removing it from the piano. Sometimes the pinning issues are sporadic and sometimes they are super pervasive. I have had some clients with pianos with this type of issue and I've just let them know that it is a fairly expensive repair, but if only a few of the dampers are hanging up, you can just fix them ala carte, with the full knowledge that more will probably need attention in the future: Write this down for the client because they will probably forget until then next damper fails several months or a year or so down the road.
    One of the issues you have to really look out for if you are doing the whole set - be very careful with travel paper when you remove the flanges. The travel paper will often fall off and you need to keep track of where they go and reglue them back in place. Each paper that you loose track of will result in a flange that won't properly align with the wires when you reinstall.
    Ryan Sowers RPT
