The Problem With Fast Re-Attack Tuning - YouTube Presentation
  • 1.  The Problem With Fast Re-Attack Tuning - YouTube Presentation
    Posted 01-20-2024 05:35
    Here is the YouTube URL link: https://youtu.be/Z-nEm6aIB0E
    • Rapid Re-Attack Tuning is fundamentally problematic and inaccurate.
     • It takes signal processing analysis to explain why.
     • We get spectral smearing.
    • For example, using a repetition rate of the note of 3 times per second, the spread between the 3 highest peaks in the spectrum on the note C6 is 9 cents, and the standard deviation 2.7 cents.
     • This means the 'jitter' of your ETD will likely be at least 2 cents in this example, and if the ETD's needle jitters less than this, it is likely the ETD is using insufficient bandwidth to achieve the needed accuracy.
    • The 'Freeze' concept of tuning, of which I conceived, is capable of resolving this single attack and getting repeatability and accuracy in a deterministic manner.
    • The PianoSens sensor further reduces the time-domain jitter by totally eliminating the effects due to acoustic interferences picked up by a mic.
    Steven Norsworthy
    Cardiff By The Sea CA
    (619) 964-0101
