I've come across SS duplexes which are in tune and bring a musicality
to the top octave and others which aren't. Steinway or Steinwas they
should be in tune and if they're not intended to be and are not an
Steinway might just as well be a Steinwas. As a footnote I really
enjoy tuning the top unisons when they come into resonance and the
sound just starts fitting together, and often the duplexes give those
extra aural queues for the unisons to be coming together.
Sent: 3/29/2023 9:34:00 AM
Subject: RE: Tune SS duplex scale
The duplex bars are usually easy to tap proximally, not so much the other way. To lengthen the scale, lowering tension by 300 cents or so may allow enough slack, but the stability will be gone for a while.
Be advised that changing the back scale that the factory has installed will make this a Steinwas.
