Thank you James, that is a starting point.
I understand that pins under 30 - 40 inch pounds are probably going to slip in the dry season.
My questioning is related to how much torque one can reasonably expect a few years after a rebuild, and where the cut-off to unacceptable is. I.e was a rebuild done properly...
Is there any reason a rebuild should not last as long as a new build?
Jurgen Goering
Sent: 10-29-2024 01:50
Subject: Tuning Pin Torque
January 1993 PTG Journal article by Nick Gravagne
Sent: 10-29-2024 01:37
There is an article in the PTG Journal showing tuning pin torque ranges. 20-30-40 inch pounds are way too low . I think either 50 0r 60 may be the minimum acceptable with little to know risk of slippage. I will try to find the guide or at least post the journal issue and date
