Thanks for the replies.
Mike - I will check that out as well, from the attached picture I took previously it doesn't look like it.
Ed - I wouldn't be surprised if this director might have a similar approach to choral directing. :) I heard from some he is a bit heavy handed in his playing as well. :) See attached picture for the D5 string location, right before the break.
Peter - I understand your point, and agree wood will "relax" or breakdown over time and this piano is about 40 years old I believe. However, this is the first piano I have come across with this problem. I don't see hundreds of piano's a year, nor am I as experienced in this field as others, but I have my own 1908 Mason and Hamlin Grand - no problems, a client's 1888 Steinway, no problem, and other very old pianos that don't have this issue.
Sent: 12-12-2023 13:11
Subject: Unstable unison one note, then two - D5, E5 - Kawai Grand
Adam-These are the first notes on the capo section, yes? These notes are often more sensitive to humidity change. Mike Ello mentioned a rare possibility, easy to observe.
I maintained an old choral practice piano which had midrange problems that surprised me despite my best efforts.
One day I passed by during a rehearsal and heard the director at work: "ALTOS!!! F SHARP!!! F SHARP!!! [BANG!!! BANG!!!] F SHARP!!!"
Sent: 12-12-2023 12:20
Thanks for your reply Ed and James. :) James - I think it is the angle of the video. All bridge pins are the same height.
Ed - Yes, first time with this piano. Here is the brief timeline:
2 weeks (I looked it up, I thought it was only 1 week mentioned above) after tuning, only D5 unison was out. Brought all three D5 pins down maybe 10 cents then back up to pitch matching the octave with D4. Also added a couple drops of thin CA glue to the tuning pins.
A few days later, same problem, D5 unison out, E5 unison waning a bit. The rest, good. Slight pounding of the D5 pins, just enough to move them down a bit, still plenty of space from the coil.
Did some research, found out about bridge pin possible issues, went back a few days later (D5 still unstable), removed tension and found I could move the bridge pins (see prior video). Added thin CA glue to the bridge pins.
D5 held on for about a month now. Could be lack of using it (it is a church rehearsal room piano), stable temps, etc. And then, another call. D5 unison out again. Went back, tuned it and a couple surrounding notes (C#, D, D#, E) they were off juuuust a bit and added some more CA thin glue to the bridge pins.
D5 lasted about 2 days.
The rest of the piano is great, no problems, no complaints, happy client. Just this one cluster...
Would love to figure out the mystery to the dissonant unison. :) I will check the back lengths next time I am there...I might just move in. :)
Thanks for everyone's help!
Adam
Sent: 12-12-2023 11:38
Adam-I believe all bridge pins move slightly when tension is added to the string, more obviously so as a piano ages. It is not necessarily a problem. This is just the first time you've seen it.
What I hear, in terms of direct observation, is that you tuned and a unison went out. This is nothing special. And this appears to be the first time you tuned this piano. So I am not certain that anything was wrong with the piano beyond a drifting unison.
Then, on your first callback, how much did you wiggle and yank on the pin/string? Or did you just quickly tune the unison with minimal movement?
Then the things you did on your second visit, releasing tension on the string and pounding the pin are good ways to introduce more instability in the system.
Given what I understand of the situation, I'd suggest (if the unison drifts again) that you pluck the back lengths, listening to the neighborhood pattern. If the back lengths of the string you loosened are lower than the neighboring pattern, you might gently tap the back length and retune, hoping to bring the back lengths up to pitch.
Then wait and observe. Thank the customer for their patience as you get to know their piano.
Sent: 12-12-2023 07:28
Good Morning Ed. :)
Thanks for the alternative insight on tightening screws. Any opinion on the bridge pins? :)
Adam
Sent: 12-12-2023 07:01
Wim wrote: <[Tighten plate screws] As tight as you can make it. I used a brace and bit. If you don't have one, then use a square shanked screwdriver and use a crescent wrench to turn it. >
No! No! Especially not "as tight as you can make it."
This from Del Fandrich's article on plate screws in the February 2015 Journal:
"In wood screws, relaxation occurs because of creep, or time-dependent deformation,7 and it is creep that leads to stripped-out frame screws. Over time, the wood fibers deform, and the pressure against the tops of the screw threads decreases. The technician comes along and tightens the screw, increasing the amount of compressive force against the tops of the screw threads, and the cycle repeats. Figure 2 illustrates what happens when the screw has been rotated 180° after a few years and a few tightenings.This is probably what happened to the frame screws I encountered; most of them were either stripped or nearly so.A sincere technician had been very consciously tightening them year after year-not much each year, but enough so that over time, the threads cut in the wood rim failed.
A good case can be made that frame screws should never be tightened after that initial setting at the dealership (or prior to that first tuning, if the dealer is one of those that doesn't believe in adequately prepping new pianos)."
Read the entire article (or at least the second half) to learn a lot about different types of screw threads and how gradual tightening can eventually strip out a screw.
Tightening plate screws is another of "the ways I've alway done it" that should be questioned.
Sent: 12-11-2023 18:22
While it doesn't seem like it matters, just that little bit of extra tightness can make the plate more stable.
Sent: 12/11/2023 6:07:00 PM
Subject: RE: Unstable unison one note, then two - D5, E5 - Kawai Grand
Thanks Wim. :) I will check that and see if it makes a difference.
More questions, of course! :)
- What is the recommended torque value, if any besides tight?
- How would tightening the plate have an effect on only a small group of notes, vs the entire piano?
Thanks. :)
Adam
Sent: 12-11-2023 13:58
Adam
I would suggest you tighten the plate bolts/screws. I had a piano that had the same type of problem. Several tuners couldn't keep about 6 notes in tune in the middle octave. I traded the piano in for a S&S I had rebuilt, so I had time to do some work on it.
When I checked the plate screws, only two of them move by no more than 10 degrees with my brace. But I found that was all that was needed. The piano stayed in tune for over a year after that. (lost track of the customer after a year).
