Upright Soft Pedal System Function
  • 1.  Upright Soft Pedal System Function
    Posted 09-26-2025 14:51
    This post is a followup to my post two days ago: Upright Soft Pedal. I'm looking here more for thoughts on regulating the vertical soft pedal and the soft pedal system effectiveness on a vertical.
    Larry Fine's book states that "the hammers move closer to the strings, softening the sound". I agree with the first part of that statement, but largely disagree with the latter portion. Pretty much any vertical I've played has a very poorly functioning soft pedal system. Yes, it moves the hammer line closer to the strings, but the volume reduction is pretty close to negligible and the tone is unchanged (unlike the soft pedal system - or una corda - on a grand piano the when adjusted properly moved the hammers slightly to the right or left and the strings strike a softer spot on the hammer and thus make a softer tone).
    Randy Potter's class text states that to regulate the soft pedal on a vertical, one should adjust the pedal so that there is not more than 1/8" of lost motion in the pedal. There is no information on how effective the soft pedal system on a vertical is.
    I don't have a copy of Reblitz (or at least I have no idea where it might be!). Does anyone have a copy? Does Reblitz have anything to say about regulating the soft pedal system on a vertical or how effective it is in use?
    I'm looking for opinions on whether a properly adjusted vertical soft pedal system effectively reduces volume and softens tone. Please feel free to compare its function to that of a grand una corda pedal system.
    I'm also looking for opinions on whether there is anything that a piano technician can do to make a vertical soft pedal system work more effectively after they have regulated the trapwork so that there is just a hair of lost motion to the pedal and depression of the soft pedal moves the hammer line approximately half-way from the rest position to the strings (not that there is any real way to regulate blow distance reduction short of gluing in some firm felt above or below the soft pedal to limit its travel).
    Thanks for any constructive input.
    Terry Farrell
    Farrell Piano Service, Inc.
    Brandon, Florida
    terry@farrellpiano.com
    813-684-3505
  • 2.  RE: Upright Soft Pedal System Function
    Posted 09-26-2025 15:02
    Terrance
    The soft pedal on an upright piano is not effective if the piano player doesn’t also plays softly. It’s like putting on the brakes. You can maintain 50mph if you keep pushing down harder on the gas.
    There are some pianos that have a mechanism on the wippen that will keep the capstan in touch with the stickers, but on 99% of the uprights there is going to be lost motion. I guess that is one way to reduce the volume of the piano.
    Wim.
  • 3.  RE: Upright Soft Pedal System Function
    Posted 09-27-2025 01:34
    My observation is that the only thing that truly makes an upright piano quieter is the soft rail - usually operated by the middle pedal. In my experience, unless the pianist is really trying hard to play quieter while using the left pedal, it doesn't make any difference at all. And when they do try, it doesn't seem to make that much difference even then.
    My guess is that the only thing the left pedal is good for is stimulating a heavier action, and even then maybe not so much. That's the only purpose I can think of for introducing that much lost motion.
    Still, some people use the left pedal just because it's there. I always try to adjust it with zero lost motion instead of the 1/8" that some recommend. My reasoning behind this is that if I'm going to go to the trouble of regulating it, it might as well work the way it was designed to. I understand leaving 1/8" of lost motion because some pianists rest their foot on the pedal, but that's a bad habit and not the piano's fault. Thus I choose to adjust out lost motion in the pedals. Just my 2¢.
  • 4.  RE: Upright Soft Pedal System Function
    Posted 09-27-2025 09:33
    Sorry, not constructive, but I remember hearing in a convention class a LONG TIME AGO that the effect of the upright soft pedal, for the average pianist, is to play harder because all the lost motion makes the keys feel funny.
    Cindy Strehlow, RPT
    Urbana, IL
  • 5.  RE: Upright Soft Pedal System Function
    Posted 09-27-2025 09:53
    I always tell people that when you press the pedal and it moves the hammer closer to the string, it's like a pitcher trying to throw the ball without a windup.  You don't get as much momentum, so you get a softer blow.
  • 6.  RE: Upright Soft Pedal System Function
    Posted 09-27-2025 10:00
    Terry,
    Since your client is not satisfied with the degree of attenuation afforded by a conventional upright soft pedal, it sounds like they need a retrofitted practice mute rail, that puts felt between the hammers and the strings and is operated by a choke mounted under the keybed.
    Doesn't sound to me like you have said or done anything wrong.
  • 7.  RE: Upright Soft Pedal System Function
    Posted 09-28-2025 11:32
    Paul, I totally understand the momentum thing, but, in your opinion, does the soft pedal mechanism on a vertical properly facilitate soft playing - i.e. does it really work?
    Terry Farrell
    Brandon, Florida
    813-684-3505
  • 8.  RE: Upright Soft Pedal System Function
    Posted 09-28-2025 12:18
    Hi Terry:  Well, I'm not a pianist, so what do I know?  I do have clients who say it doesn't work or doesn't do much.  I ask if they play on a grand, and explain how they work as opposed to their vertical piano. Once they see what it does when they press the pedal, it sort of explains things. Their level of expectation is lower.  If the hammers are bright and there's not much dynamic range, then the difference in volume is probably going to be much less.  Same if the touch weight is less, ie., Yamahas because it's too easy to get a loud sound.   As far as what we can do as technicians, I don't think we can do much if anything.  Someone suggested a mute rail, but that's not meant to be pedaled and it interferes with the feel of the action.  I do know that often the rest rail doesn't move much, or there's some hard felt which prevents it from going very far.  I always try to remove any lost motion so at least I can squeeze out that last few mm's of extra movement.  You could ask them to call another technician for a second opinion.  At least they will understand that you're not at fault and their piano is ok, working as designed.
    FWIW.
    Paul
  • 9.  RE: Upright Soft Pedal System Function
    Posted 09-28-2025 13:00
    The backcheck wires need to be adjusted so that the backchecks all rise simultaneously when the hammers are  1/2 of  the total blow distance. I was taught
    this while training in the Bechstein factory in 1979.
  • 10.  RE: Upright Soft Pedal System Function
    Posted 09-28-2025 15:35
    What do you mean the backcheck wires need to be adjusted? The wippens and backchecks should not move at all when the soft pedal is depressed. If they do, the bridal wires need to be adjusted. Also moving the backchecks will not affect their timing with the hammers.
    Trevor Penner
    Hillsboro KS
    (620) 877-0306
    music2himalone@gmail.com
  • 11.  RE: Upright Soft Pedal System Function
    Posted 09-28-2025 16:44
    When I took lessons as a kid, my teacher said not to bother with it, because the same effect should be achievable by learning to control how hard you press the keys.
    At any rate, the half blow pedal is just not very effective at reducing volume. It can make it a little easier to control faster pianissimo playing, but like others have mentioned the excess lost motion it introduces kinda works against you.
    I have had customers think the pedal simply wasn't working properly, even when it was, because it has such a minor effect.
  • 12.  RE: Upright Soft Pedal System Function
    Posted 09-28-2025 12:32
    If the player is trying to play softly, holding the soft pedal down DOES make a difference.  If the player is playing "hard", the effect is "not-so-much".
    Mark Wisner RPT
    Fairbanks AK
    (714) 337-9074
    MarkWisner
  • 13.  RE: Upright Soft Pedal System Function
    Posted 09-28-2025 12:55
    My thinking has been that the left pedal on the upright is only supposed to be a "good" enough simulation to the real thing. It's not supposed to work that well.  But you can develop practice and muscle memory so when you go to a piano with all the real functionality, then you atleast know how to use it.  It's true that if you play soft holding the left pedal on an upright it will be easier to play softer but only if playing soft like Wim and Mark pointed out, but is a weak simulation as far as practical use. Pushing the hammer rail forward would make the hammers more closer to thier center of gravity, which is why it doesn't work if you are not playing very softly - or in a lot of folks cases; it's because thier piano is incapable of playing soft because it hasn't ever been regulated since factory lol
    It's closer to a placebo effect, looking at it from a musician angle.
    If your customer hadn't had thier piano tuned in a long time then they could be getting confused by the difference in reverb and overall overtones which can sometimes take time to get used to for some people. Sometimes when out of tune, the piano can be described to have a muted sound. Tuning makes the sound more full, which is what they could be complaining about.
    One piano at a time, right?😀
    Matthew Walworth
    A.M.O. Pianos
    Lebanon, TN 37087
    https://www.nashvillepianotuning.com
  • 14.  RE: Upright Soft Pedal System Function
    Need WN&G lost motion compensator
  • 15.  RE: Upright Soft Pedal System Function
    Posted 09-28-2025 17:43
    My ¢¢ --
    I have never been able to make the soft, or left, pedal do anything that I can hear on either an upright or a grand. On the other hand, I know I don't play well enough to make it do what it's supposed to do in the first place. When I hear good players, on either an upright or a grand, use it I can definitely hear the difference. The customers that I have that have mentioned their inability to hear a difference, uniformly don't have the skill to play softly in the first place. Many mistake it for a way to make the piano overall quieter, like when using a practice, or middle, pedal on an upright. It's easy to spot a customer who uses it this way on a grand, as the hammers will start to wear flat instead of developing grooves. As Alan suggested, if what the customer wants is to use it like a practice rail, and the piano does not already have one, then you need to install one as an add-on, like he described. If they want to use that pedal to make a phrase they are playing more quiet then they just need to learn how to play more quietly in the first place, and then add that in. It's deliberately a subtle difference to start out with, but knowing how and when to use it helps.
  • 16.  RE: Upright Soft Pedal System Function
    Posted 09-28-2025 18:17
    In my opinion, the soft pedal on an upright piano was only developed for us technicians to check for sluggish hammer flanges. Push the right pedal to disengage the dampers, and then slowly press and release the left pedal. When the hammer rail comes back, it will instantly identify any sluggish hammer flange. lol
  • 17.  RE: Upright Soft Pedal System Function
    Posted 09-28-2025 20:53
    Wim --
    I don't think it was designed for that purpose, but I use it for that purpose myself, on pretty much every upright I see, every time. Very useful for that, indeed.
    What I learned was that original grand piano design had a single pedal for sustain, and later a second pedal, for soft, or unacorda, was added. (That second/left pedal is called unacorda because at the time pianos only had two, not three strings. Shifting the hammers over from bichord, two strings, to unacord, one string, made for a very large, 3db, change in loudness. Today, with the unicorda pedal shifting from a trichord to a bichord only makes for a 1-1/2db loudness change. Hardly noticeable.), Now that third, middle pedal, as I was told, is an American invention of no defined use. It was added purely as a marketing feature so that salespeople could say that American made pianos were better because they had a third pedal. (They could go up to 11. 😁) As we all know, that middle pedal gets used for many things depending on manufacturer and model. Sometimes it's bass damper lift. Sometimes it's sostenuto. In uprights it can get really weird. Most of the time it's for a practice rail but I've seen older ones where the right and middle pedal do exactly the same thing. Sometimes they do so by using two separate connecting rods. Sometimes the two pedals are simply tied together at a single connecting rod. I've even found some where the middle pedal exists but isn't hooked up to anything other than a spring so it feels like it's doing something.
  • 18.  RE: Upright Soft Pedal System Function
    Posted 09-29-2025 11:46
    The "una corda" or "shift" pedal on grands does attenuate the volume of sound produced but, if working optimally, should accomplish more than just a reduction in decibels. Introducing parts of the hammer strike point that are not compacted like the string cuts in the rest position produces different tone, ideally in gradients. Most classical pianists rely heavily on this to produce the most expansive total pallet possible from a given instrument. Pianist Frederic Chiu has spoken extensively about this in forums geared towards piano technicians.
  • 19.  RE: Upright Soft Pedal System Function
    Posted 09-29-2025 16:31
    A little reality. Three strings each putting out 100dB equals 104.7dB. Two strings each putting out 100dB equals 103dB.
  • 20.  RE: Upright Soft Pedal System Function
    Posted 09-30-2025 08:44
    Y'all are missing the obvious:
    The middle pedal was invented to separate the right pedal from the left!
    Doh!
    Chuck Christus, RPT
    Flagler Beach, FL
  • 21.  RE: Upright Soft Pedal System Function
    Posted 09-30-2025 08:59
    That's why pianist from Japan and Europe don't know their left foot from their right.  lol
