I had a fallboard hinge screw that was stripped once. Try needle-nose vice grips first. I eventually had to I use micro easy-outs (not in a power drill! Do this by hand) and these wearable magnifiers were extremely helpful:
https://www.amazon.com/gp/product/B01H8808H6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 I also put tape around the screw to protect the fallboard in case my tool slipped. Work slowly and carefully.
Regarding double striking, as mentioned check after-touch. If there isn't enough this will prevent the hammer from moving away when key is depressed.
If after-touch OK, note let-off. Is it sufficient? If it is, repetition spring may be too strong. Try setting repetition spring to just barely lifting hammer in the hammer-in-check test. If let-off is OK and spring OK, drop could be set lower; see if that works. If it does, rather than leave drop by itself low, I like to lower let-off to get to the point where there's simultaneous escapement (so raise drop back up tiny bit and lower let-off.)
In any case if after-touch is good and spring is OK you'll be able to fix the problem by setting let-off/drop slightly lower. Test using a variety of blows, very soft to hard.
Work on one key first and figure out what's happening.
You could also try adjusting the gravitational acceler ... never mind.
Don Dalton
Chester VT
Sent: 08-12-2022 07:52
Subject: Very rapid double-double strike after a hard keystroke
I will check once I figure out how to get at the action. The fall-board left hinge has a small flathead Philips retaining screw that has its drive stripped by another piano tech. 🤦♂️
Benjamin Lian
88Keys Pte. Ltd.
Singapore
Sent: 08-12-2022 07:07
Have you checked for shallow key-dip? Back check problems like too close or not catching well?
Just my thinking.
Paul
