I would not hesitate to apply a solution of "All" fabric softener and alcohol (and possibly H2O) to the hammers. I have had remarkable success with this concoction (I did not dream it up and it has been discussed here several times).
Ratio: 1 part All : 2 parts alcohol for general purpose usage. If more effect is needed add up to one part water.
I use Everclear 190. You can use industrial denatured alcohol if you want but you don't necessarily know what the water content of it is. Your choice.
I use a spent Cory Key bright pump sprayer bottle and shield other parts with my other hand and fingers. After a few minutes of penetration (5-15) follow up with a light wire brushing of the strike points. If more seems to be needed, add some water and re-apply. Finally, light needling of persistent outliers should tidy things up.
Under the aforementioned circumstances (you mentioned) I fail to see any legitimate concerns regarding the efficacy of this procedure. You should find it to be a very effective tool in your voicing "bag of tricks". Just like CBL I don't leave home without it. Nothing but success with it.
P.S. If they are truly incorrigibly rock hard, I use VS-Profelt (not sprayed) with care. It is slower acting but more powerful. Use with caution.
Sent: 08-05-2022 07:53
Subject: Voicing ideas for Baldwin Spinet and Otto Altenberg Grand
Because of code of ethics #5 I will render the best possible service under the circumstances, always keeping the best interests of my client in mind
Sent: 08-05-2022 06:58
New hammers are needed. Bending over backwards will only delay this. Why do we keep pianos limping along?
