There are obviously choices one can make in products and I'm not going to disparage any one of them. Bacon felt hammers treated as described will still be softer than Abel Natural or Blue Points but those are also good hammers in the right situation, I find. I just put a set of Abel on a Steinway B and a set of Renner Blue Points on a Steinway L and D both with good results. I had to needle those down some but not a lot.
When putting on samples I usually stick to those three. With Ronsen, btw, if I'm sampling weikert or wurzen felt I don't harden them in advance because they present a bit firmer out of the box. Often I have left those unadulterated except maybe the mono chord and the top 5-7 notes. Can't say that about the bacon felt but lots can vary.
Sent: 08-16-2025 18:03
Subject: What are your techniques to prepare and voice Ronsen Bacon Felt Hammers?
Hi David, Thanks for your suggestions. I do have notes from a 2008 discussion thread, where you discuss how you lacquer the Bacon hammers. Here is what you wrote,
"I'm using one 9:1 solution through the set, maybe two applications above C6 and that is plenty to bring out the tone quality tone. That's with MacLac High Solids G-23 clear gloss lacquer (solids content do vary between lacquers). 10 grams of lacquer to 90 grams of acetone in this case."
You wrote these comments a long time ago. If you are so inclined to expand on your current procedure that would be extremely helpful in getting the best tone and performance out of these hammers. Thank you!
Joe Burros
Cell: 646-410-7174
jbcello@gmail.com
www.fmi-newengland.com
Sent: 08-16-2025 12:00
Chris, it would be good, though it appears to be a challenge, if you could make your comments without editorializing on what you think is "bullish" on my part. I know that's difficult for you whatever you meant by it but knock it off. I'm happy to expand on my own procedure if you're interested in it, which I doubt, though it's something I've written about before.
Everyone, keep in mind here that he's asking for how to prepare sample hammers not the final set. A bacon felt Ronson hammer needs hardening 95% of the time. In order to determine what the hammer potential is in a sample, it's necessary to prep it in such a way that it will mimic what is likely to be required in the piano. The product that I use is quite soft setting. A 25-30% solution is really not that strong with that particular product. Of course, if you're using a very inflexible substance like sanding sealer, that would be very strong and I wouldn't recommend it. In fact I don't recommend using that product at all because if it's lack of flexibility.
If you're unsure as to how bacon felt responds to stiffening, then you might consider carrying two samples of that hammer; one prepared, one unprepared. If it turns out that hardening the hammer will be appropriate, it allows you then to do that before you install the set back into the piano. That obviates the need for hardening on site, waiting for it to dry before you can really voice the piano, not to mention introducing toxic fumes to the customer's home where sometimes that can be something unwanted.
Sent: 08-16-2025 10:33
Needing to make a lot of change means the wrong hammer for the piano in my opinion. With the right hammer, its like almost there already and chemicals are used to make small adjustments of balancing the registers, coloring the attack, fixing missing fortissimos and decay drop offs. Just coming over the top to the core seems rather bullish. Why fix a fortissimo problem by going through the attack and decay? I tip the action on its side and isolate the fortissimo first. Then i go back and listen to the attack and decay again.
I use sandarac for fortissimo, and a very diluted shellac for attack and a too open sustain, and needles on the shoulders for decay drop offs, only rarely a problem on Ronsens. BTW, diluted shellac has a sweet sound characteristic of all the other "hardeners i've tried.
chris
Inertia Touch Wave(ITW) The most advanced silky smooth actions. That ACTUALLY USES REAL INERTIA MEASUREMENTS. Instead of incorrect empirical charts.
Engineered Hygroscopic Soundboards. The strongest and lightest boards made today for unmatched acoustic projection, richness and warmth.
Sent: 08-16-2025 09:00
Mr. Burros,
Much will depend on what kind of sound you're after. Mr. Love's advice is good if you want a more powerful sound. With that technique you'll want to use the same technique as you would on a NY Steinway hammer. I put a set of Ronsen Bacon felt on a 1930 Knabe to get a softer tone and used no hardeners. I just lightly filed and fitted them to the strings and used traditional shoulder voicing ( ala Brooks/Negron) to even them out and got a really nice result. Two years in they have brightened up a little but in a good way.
