Working on a 1922 Steinway O right now. The action stack is a bit low according to Steinway specifications.
Taking measurements at the five action brackets, the hammer shank pin centers are 144.7 to 145.0 mm from the action bed. Steinway spec is 146 mm, so they are 1 to 1.3 mm too low.
The wippen pin centers are from 80.1 to 80.7 mm from the action bed. Steinway spec is 82.6, so they are .9 to 2 mm too low.
String height in bass section varies from 198 to 199.3mm. In tenor section string height is 191 to 191.5 mm, and in treble section string height is 191.0 mm on key #61 tapering down to 189.1 mm on key #88.
Some of the experienced technicians I have been talking to say to shim and raise the action so that the distance from the key bed to the shank and wippen pin centers is on spec. Then do a custom hammer bore to compensate for varying string heights.
But, on some older discussion threads, some say that Steinway may have set the top action stack deliberately lower to compensate for a lower than spec string height. Because of that I want to get some fresh opinions about this question.
What do you all think about this question? And how do you proceed with setting shank and wippen center pin height when you have a piano with lower than spec string heights.
Thanks for your help!
Joe Burros
Cell: 646-410-7174
jbcello@gmail.com
www.fmi-newengland.com
