Contrary to claims, I find these older Wurlitzers better built than current low end Yamahas. Any piano needs a stable environment, regular
tuning and regulation. That is not the fault of the piano.
Sent: 12-27-2023 08:55
Subject: Wurlitzer spinet with Quadrasonic bass bridge
Wes
The saw kirf is a factory cut. I've seen it many times on bridge aprons.
After carefully looking at the bridge, it doesn't appear to me that it has moved. What you're seeing is the soundboard not having finish on it where the bridge is glued down.
The strings I can see do not seem to have rust on them.
Can't comment on the rest of the problems you mentioned, but this looks like a relatively newer piano, maybe 25 - 30 years old. If it's a console of that age, they were pretty nice instruments.
