After all, the CDC isn't going to revise their reccommendations based upon anything we say here... I think.
Sent: 02-02-2026 13:30
Subject: Yamaha C7
William,
Did I disagree with you? Call me a crank if that pleases you, I'm thick skinned.
Roger
Roger Gable RPT
Gable Piano
Everett WA
(425) 252-5000
Sent: 02-02-2026 06:56
Subject: Yamaha C7
Roger, if you want to disagree with me in this thread, i welcome your commentary. After all this forum also serves as an arena for ideas, does it not? I know I am swimming upstream against what may be the conventional wisdom, so if you think I am in error, please share your thoughts.
However, standing on the sidelines and throwing impolitic bombs with no substance and only the aspersions, makes you sound like a crank.
William Truitt RPT
Bridgewater NH
(603) 744-2277
Sent: 02-01-2026 13:58
Subject: Yamaha C7
I have kept a respectable distance from this thread while absorbing the details of various opinions and statements about Wims' C7 capo-bar string breakage. I feel some technicians are spot on while others make folkloric statements without any backup research. This thread has conjured up some pretty bizarre statements.
Roger Gable RPT
Gable Piano
Everett WA
(425) 252-5000
Sent: 02-01-2026 06:43
Subject: Yamaha C7
Fair enough, David. I think I need to connect the dots a little more completely.
Rereading the posts, I am not seeing that the breakage is occurring at the capo bar. I certainly have seen that in high use pianos such as are being described in this thread. But it is far more common for the break to occur at the coil by a huge margin, so I am going to assume that is the case with Wim's piano.
Let's count the strikes that have already been identified. Played hard 20 hours a week for 20 years. It would not be surprising for the hammers to flattened with long grooves AND the hammers are very hard. This alone is bad for string fatigue, but getting them to file the hammers is likely to fall on deaf ears, as is getting all the McCoy Tyner wannabees to let up. Piano wire is elastic, and under tension its whole life in a piano. Even if the piano is not played at all, the wire will creep as its life continues. Add this incredible amount of time and hard abuse, and that process of creep will accelerate dramatically. String breakage in this environment is common and well-known by technicians.
It is common for all pianos to have the breaking percentages going up, up, up as we ascend the scale. Which is to say for these ever thinning wires that the start point after stringing is closer to the breaking point. The string has less far to travel before it gives up the ghost. We should also understand that during heavy playing the breaking percentage in a manner of speaking is increasing - indeed, it can spike past the breaking point in terms of the load on the string from the hard blow, ever so briefly. When this is occurring, this dramatically accelerates metal fatigue in the string cumulatively.
How many of us have been tuning and raising the pitch on a particular string and come to a point where the pitch is no longer going up as we move the hammer, and then POP, the string breaks, usually at the coil? The wire has moved past its elastic limit into the realm of dramatic plastic deformation where the string stretches and thins and breaks.
I am going to start to connect this to friction - what does friction have to do with the string breaking at the coil and not at the V bar? (Most of the time). What we need to understand is that the string bearing against the V bar is not static. When the string oscillates, it is sliding back and forth along its length on the bearing surface, hundreds or thousands of times per second. The contact surface for the string to bear on is very small, so the pressures from even a string tensioned at 160 lbs, is enormous, on the order of 200,000 psi! That is enough to deform the surface of bridge pins, which might be in the range of 60,000 psi before plastic deformation occurs. Cast iron falls well below that, even with a well dressed capo bar.
Let me introduce the notion of stick/slip. The string, as part of its oscillation always has sticking friction, where it binds against the plate and then releases, it sticks and then slips with every single oscillation. The string is literally being abraded by the softer iron, and the iron contacting surface is being deformed into the ever elongating string impressions which further increase the frictional load because of more contacting surface.
Yeah, but the cap surface is several inches away from the tuning pin, so that should not make a difference, right?
When the string sticks, tension builds in the wire on one side of the contacting surface because it is binding on deformities in the surface called asperities (think of the deformity as a dam). The string tension always wants to move into equilibrium with the lower tensions on the other side of the contact patch. The building tension becomes overwhelming and the stick is released and slips across the patch, and the tension equilibrates. Moreover, the tension along the length of the string is always moving in and out of equilibrium, so the inequalities of tension at the capo bar are acting on the string at the pin.
The string is already much closer to plastic deformation because the bend is so tight. The outside edge of the string is under very high tension, while the inner edge of the string which bears against the surface is under compression, and there is a transition tension/compression zone between them. The spikes in tension from heavy blows are felt at the tuning pin and are further weakening the string at its most vulnerable place. And now we can add stiction that may also exist at the string rest felts behind the front duplexes.
So what does the incredibly smooth frictional surface that I am recommending have to do with the cost of tulips in Holland? Simply put, it dramatically reduces the build-up of tension before the string renders. If we have removed the grooves and have a well-shaped termination, then the formation of new asperities is dramatically decreased. Couple this with XM wire, and you will have a hugely improved service life.
i would flip the piano over upside down on blankets to dress the V bar and polish it.
William Truitt RPT
Bridgewater NH
(603) 744-2277
Sent: 01-31-2026 23:53
Subject: Yamaha C7
William -
Trying to process this:
- the coil - I'm not clear what you're describing, nor the significance of the 'deformation' at this location. Unless I missed it, the breakage is taking place at the capo. Where is the plastic deformation and how does that effect an increased propensity for breakage?
- the characteristics of concern with regard to the capo seem to be:
- degree of hardness
- profile of v-bar
- friction
- your focus seems to be on the latter. I'm not sure I grasp the mechanics of that friction as a primary cause of breakage.
David Skolnik [RPT]
Hastings-on-Hudson NY
(917) 589-2625
Sent: 01-31-2026 18:25
Subject: Yamaha C7
Ken, I think it is likely safe to simply replace the strings using XM wire of the the same gauges as the original. The tensions will not change going from the original wire to XM Paulello as long as the gauge is the same, but the breaking percentages certainly do and that's the whole point of the exercise. Stronger wire of the same gauge will have a lower breaking percentage, which means there is less stress in the wire. To my ear (having made these substitutions a number of times) the tone sounds a bit more relaxed as a positive.
The area of greatest stress is at the coil. There is the greatest bend there building up torsional forces and the string twists on its own axis down and in. the torsional forces from the twist are significant, so great that in this area the wire is already beginning plastic deformation almost from the moment the wire piano is first pulled to pitch.
I would take a different tack with the profile of the V bar. Carefully reshape it, making sure the string imprints are completely gone. Then poiish the surface with grits up to about 12,000 grit, and finish with Tungsten Disulfide Nano-powder rubbed in under pressure. This will dramatically lower coefficient of friction of the surface. When the string oscillates, it undergoes stick/slip which abrades the cast iron surface, which ultimately leads to breakage.
William Truitt RPT
Bridgewater NH
(603) 744-2277
Sent: 01-31-2026 08:42
Subject: Yamaha C7
If you go to Paulello's web site, and find the typogram used to create a hybrid scale, it would be super easy to compare the bp % for type M and type XM. It's meant to facilitate exactly this kind of what-if comparison. You'd still have to measure the speaking lengths, so it wouldn't be as fast as just subbing in XM wire of the same gauge, but easy enough to do if you're curious. The extra strength will cost you a bit in tone quality.
My gut is that the breakage is due to fatigue in the wire, mostly, and even replacing the wire with the original type will probably get you back to something like the original dependability and tone. I'd do any routine maintenance that conditions require, like dressing the capo or doing something with the bridge pins. If the tuning pins are still a good fit, I would use a dummy tuning pin to wind new coils and only back out the pins one full turn to install. You want to avoid prematurely aging the piano. After 20 years those pins may not be so tight, and this would certainly be the time to go to a larger size if that's the case. But do the whole section, not just a pin here and there.
David's comments about hearing loss are well taken. If the teacher doesn't care, the students won't either. At least, a poster or two on the subject, and maybe a suggestion about where to get some decent earplugs, could help raise awareness.
Ken Walkup
Historicalkeyboards.as.cornell.edu
Sent: 1/30/2026 2:54:00 PM
Subject: RE: Yamaha C7
Hi Wim,
I did this on a Kawai RX2, and only replaced individual tuning pins that I deemed with my torque wrench to be on the loose side. Big mistake. I ended up with a dog's breakfast of tuning pin tightness.
Sometimes when I restring, particularly in the university setting, I am trying to leave options open for those who will come after me, so I upsize as little as possible. Sometimes I retain the original pins if I can get away with it. Sometimes that gives me a reasonable result, occasionally not. If the pins need to removed rather than just threaded back a turn, (specifically, if I'm pulling the plate), I definitely upsize.
Any time I'm just threading the pin back a bit, I'm winding the coil for the new string on a dummy pin then transferring it to the pin in the block.
Sent: 01-30-2026 14:33
Subject: Yamaha C7
Floyd
I was asking about the tuning pins, not the bridge pins.
Willem "Wim" Blees, RPT
St. Augustine, FL 32095
Tnrwim@aol.com
Sent: 01-30-2026 12:12
Subject: Yamaha C7
If I can exactly match the size of the original bridge pins, I will not go for enlargement. I will rely on the CA. Nevertheless I will drill to deepen the holes as necessary so that I can avoid filing the tops of the new pins. I typically use pins with rounded tops. Maybe you're happy to file, and to eliminate the drilling step. I forget exactly how far undersize I drill, but I think the appropriate bit sizes are specified in the Schaff and/or Pianotek catalogues.
The more often you can visit the piano, the more quickly it will stabilize. I wish I could be more specific than that. Of course at the outset you'll need to nudge the wires at all of the bends to speed up the process.
Sent: 01-30-2026 11:31
Subject: Yamaha C7
Floyd.. Thanks for the advice. When you've done this, did you go up one size on the pins, or used to originals? How long before the piano was "stable"?
Tnrwim@aol.com
Sent: 01-30-2026 11:12
Subject: Yamaha C7
Hi Wim,
It is my understanding that metal fatigue sets in at the terminations of the vibrating length, especially if the piano is played hard over an extended period of time.
If I were in your position, I would do (and have done) the following. I would restring the treble with Paulello music wire, using the hybrid scaling strategy. In practical terms, that means most of the treble would be strung with the high-tensile-strength XM wire. This would give greater durability than the original stringing. Wire diameters do not need to change from the original. While I was at it, I would definitely dress the capo bar. While the strings were off, I would also apply water-thin CA at the base of the bridge pins for give some insurance against future false beating. (If I wanted to do even more, I might replace the pins, pre-soaking the new pins in McLube, then applying CA after installation. This would give happier prospects for pin removal in regard to future repinning efforts. In such a case, the pins closest to the struts would not be replaced, due to the plate strut blocking their exit path.) I have found the application of CA to the bridge pins to be somewhat risky with the strings in place, but almost foolproof with the strings off.
For what it's worth, I always go and re-read David Love's "Reshaping the Capo Bar in situ" (Pianotech 07-22-14) before I tackle the task.
I think this would do more than remediate the nuisance of string breakage. I expect this would give an audible improvement to the sound in the treble.
