Scott,
Before deciding for sure that it's a "piano" issue, you might try listening to the nite being played from various angles and places other than strictly at the keyboard. This can sometimes reveal that the problem is actually an acoustic reaction to the room itself since, if you find that it sounds different (better?) when you move to the side or rear of the keyboard, it ain't the piano...it's the room (or the lid, etc). This should be part of the diagnosis as it's a real thing. Fixing it can be as simple as changing the angle of the piano or the lid, or even simply tightening all the case screws, etc. Attenuating leg transmission also is a possibility as the floor can do it too.
As to your OP regarding the duplex, I routinely mask off the entire duplex with tape to find out what (if any) effect this is having acoustically. It can be significant, and it can be bad (i.e., undesirable). If things improve, I'll selectively or globally mute out the duplex section(s) with cloth. Same with other NSL sections. Very effective diagnostic tool (tape).
Sent: 05-18-2025 00:07
Subject: Yamaha GB1 Voicing issue
I concur with Roger. I've seen this issue several times before, and all the symptoms are what you describe. Most likely it's the lack of down bearing.
One thing you might try is needling the top of the hammer in question along both edges, about 2-4mm deep, with pokes about 3mm apart. I've had good success increasing sustain with this technique on pianos that have sufficient down bearing. If you don't see an improvement after needling in this manner, most likely the hammer is not your problem.
Sent: 05-17-2025 15:29
Scott,
As the owner of numerous Yamaha grands (not GB1's), I've noticed your observations in that area when the net down bearing is little to none. I suspect, in my case, the soundboard has lost its crown resulting in that loss of down bearing. If this is true, all the hammer voicing will be in vain. Try changing out an adjacent hammer that is producing good tone. If no improvement is realized, then you can reasonability assume the problem in not in the hammer.
Roger
Roger Gable RPT
Gable Piano
Everett WA
(425) 252-5000
