I don't know if it's incorrect, but I usually do it before I start the pitch raise, and if it needs a second treatment after I pull it up to pitch, I'll do that before fine tuning. I've had good results so far.
Also, I use the thin, almost watery CA glue from Hobby Lobby (pink label). It's the best one I can find.
www.professional-piano-services.com------------------------------
Sent: 10-07-2023 16:12
Subject: Yamaha GH1 with loose pins
I was under the impression (can't remember where I heard this) that you want the tuning pins a little bit closer to their ideal position before adding CA. Is this incorrect?
Sent: 10-07-2023 16:07
Just out of curiosity, since you already know that you have a substandard tuning pin torque situation, why not apply the CA glue before the pitch correction, and proceed to tune right away?
Sent: 10-07-2023 14:50
Thank you all, I went ahead and quoted the job. I have done it a number of times before, my normal procedure is doing a pitch correction followed by the treatment, and then a fine-tuning after the pins have set for 45 minutes or so. Would you add anything to this procedure?
Sent: 10-07-2023 10:58
CA glue is the way to go. If there're some outliers that don't respond well enough you can tap them in and as Paul said, you can add more CA glue later. The viscosity of the glue can be debated. I use just a regular viscosity and have had fine results, but many people recommend a thin or ultra-thin viscosity. I've never had any leak through the pin-block, but if you do use a thin viscosity I'd recommend removing the action, just in case.🙄
"That Tuning Guy"
Scott Kerns
Lincoln, Nebraska
www.thattuningguy.com
