Are rusty strings really a problem?
  • 1.  Are rusty strings really a problem?
    Posted 05-08-2026 20:14
    1958 Baldwin F. Really a very nice piano, with the exception that the strings and tuning pins are a bit rusty. Not bad rusty but all over surface rusty. I just did a 50¢ pitch raise on it, and a fine tuning, and everything came in clean without a hint of problems. So, are rusty strings really a problem, if the cause of the rusting has been removed? In other words, if the strings don't need replacement because of the rust, does cleaning them actually provide a solution to a potential problem or is cleaning them more of an aesthetic endeavor?
  • 2.  RE: Are rusty strings really a problem?
    Posted 05-08-2026 20:29
    Geoff
    Rust on the strings is not the problem, except, as you said, they look bad. Where rust becomes a problem is at the contact points: The coil, the agraff/v-bar, bridge pins and hitch pins. You can't clean under the string where they make contact. As long as the strings render and don't break, you're good to go. It's when the rust creates rendering problems, or break, is when there is a problem.
  • 3.  RE: Are rusty strings really a problem?
    Posted 05-08-2026 21:22
    In essence Wim is on the ball - lubricate at the friction points but that doesn't take into account fragility at the coils.
    However rusty strings can hide old strings which are inharmonic and contain false beating partials. The fundamental isn't false but the 1st partial is. In this situation it's really difficult to get a pleasant unison.
    The other day I had a dogs' dinner of an instrument. Strings were shiny - they'd been cleared up. Agraffes were shiny having been wire wooled. Four strings in the central section had been replaced. So string breakage had been a problem. One could see remnants of rust powder where it hadn't been possible to clean. I didn't have Protek with me and the strings were difficult to render and going down below middle C, a string broke on me. Luckily it was at the coil and I went home for tools and lubrication, and wrapped 1 1/2 turns from the neighbouring string to borrow for its neighbour . . . and all was well. But unisons plagued me because of false partials. Then I got down to below the bass break  . . . and my tuning lever didn't fit! The bass strings were original with small european pins! Luckily the client had another instrument with small pins for which I'd brought a lever . . . Returning to the treble above C5 the partials plagued me more and come C6 the top two octaves were small pins again.
    Why had the central octaves been restrung? What had caused tendency to the central section strings to have been vulnerable to breakage?
    I conclude a 2nd rate instrument upon which 2nd rate economy work had been done . . . and the whole neglected enough to have had rusty strings.
    +44 7868385643
  • 4.  RE: Are rusty strings really a problem?
    Posted 05-08-2026 22:37
    I recently brought in a 1981 Kawai grand that had surface rust all over (from living a mile from the Atlantic for much of it's existence). Although the overall tone was not bad, I couldn't help but wonder if there would be any improvement by cleaning up as much of the rust as I could (it was slated for restringing anyway due to loose tuning pins).
    I spent better than an hour polishing up the strings the best I could. Then a tuning (I had previously tuned it in its rough state just to get a fair idea of it's potential). In the process of this tuning a d subsequent playing, I felt that there was in fact a global improvement in the instrument as a result. The tone "seemed" cleaner and more focused. Whether it was a psychological response (because I wanted it) or whether it was in fact real...I cannot say for sure. It was not huge, but enough to appear noticeable. The piano is now getting readied for restringing so it's out of commission.
    Another piano, a 1959 Steinway L was restrung and re-hammered 10 years ago, but has lived also on the seacoast (literally in this case), and when I came to it the wire was (is) totally brown with rust. I asked the owner if they had a tendency to open the doors and windows in good weather and he said: "All the time!" Needless to say that answered my question as to the rust. Otherwise the piano played and sounded fine...just plain ugly. And since the purpose of my visit was to assess for sale value, I had to downgrade it's potential significantly as a result of all the corrosion. Too bad.
  • 5.  RE: Are rusty strings really a problem?
    Posted 05-09-2026 09:06
    I joined Ralph Stillwell's chapter 45 years ago. Some of you may remember him, he was a Yamaha rep and very PTG involved. He swore that polishing the strings improved the sound. If I remember right, he would do that even if they weren't rusty. I can't remember what he used.
    Cindy Strehlow, RPT
    Urbana, IL
  • 6.  RE: Are rusty strings really a problem?
    Posted 05-09-2026 13:23
    I have clients who live right on the Atlantic ocean who have totally destroyed their pianos by opening windows and doors to smell the ocean air. Not only do the string get deeply rusted and pitted by the actions seize up and wood and felts are compromised. Houses away from the beach can have similar problems because people like fresh air or want a nice breeze. Many times the rust can be just surface rust formed by the dew point getting too high .The rust in this case is on the surface of the string and will wipe off with a cloth . However rust can be so severe and it forms pits in the strings that most definitely weaken the string and affects the sound. Any rust at the coils and tuning pins, bridge pins and hitch pins is a problem that can and will affect string bearing and rendering . When it comes to bass strings and rust chances are the rust will have a major impact on the sound. I have tried all types of things on bass strings to improve them with very limited success.
    There was a church here with a Yamaha C7 that sat in the sanctuary without air conditioning for about 3 weeks. It had to be totally re-strung because of the amount of string rust.
    In some cases strings may improve with some cleaning but I think it depends how deep the rust is and where
  • 7.  RE: Are rusty strings really a problem?
    Posted 05-09-2026 13:40
    A couple of instruments I maintain are on the seafront in northern Italy. Would it be good advice to suggest to clients that they keep a thermal cover on their instruments?
    Has anyone any experience of such protection?
    The Yamaha grands might be especially vulnerable as they have rubber buttons on the underside of the lid maintaining a 1/4 inch gap . . .
    +44 7868385643
  • 8.  RE: Are rusty strings really a problem?
    Posted 05-09-2026 14:08
    David
    I lived/worked in Hawaii for 14 years. It was COP, (Common operation procedure), to put string covers on grand pianos. It wasn't 100% protection, but much better than nothing.
  • 9.  RE: Are rusty strings really a problem?
    Posted 05-10-2026 01:53
    If I lubricate rusty strings and drop the pitch of each string before pulling it up I very seldom have strings break at the coil (a tension break).  I regularly lubricate strings at the bearing points (not bass strings!), but this is a complex subject as the lubricant is not necessarily getting to the actual contact points like it does on moving parts in a car.  Strings breaking at the capo bar are only due to heavy use.
  • 10.  RE: Are rusty strings really a problem?
    Posted 05-10-2026 13:59
    Thanks so much to a kind colleague for picking me up on senility. Half my brain thinks of a fundamental note and the first harmonic an octave up . . .
    So . . .
    " The fundamental isn't false but the 1st partial is. In this situation it's really difficult to get a pleasant unison.  "
    I should have referred to the 2nd harmonic or 2nd partial . . . and bad unisons affect the brain!
  • 11.  RE: Are rusty strings really a problem?
    Posted 05-09-2026 14:20
    Thanks to all for your replies. This piano was donated to a church. Don't know it's history but it's not been touched in years. Cause of the rust is unknown, but it's mostly just a thin even coating. No pitting or flaking. When I tuned it yesterday only a couple of bass notes gave me a slight "tick" sound when the string released through the agraffe, but otherwise, after the pitch raise, it tuned up nicely and without problems. Not even any false beats. Thank you for recommending the Protek treatment of bearing points and coils. Don't know why I didn't think to do that right from the get-go, but it's on the list for next visit.
    Neither the church, nor I, am interested in a serious cleaning of the strings. Not really in the budget, especially since the piano is otherwise happy and clean. However, is there a way I could quickly pretty them up a bit without having to destabilize the tuning? Quick brush with non-oily steel wool for instance?
  • 12.  RE: Are rusty strings really a problem?
    Posted 05-09-2026 16:31
    Schaff sells a product called politte, or something like that. It's kind a like a large eraser. Or you can use 0000 steelwool.
  • 13.  RE: Are rusty strings really a problem?
    Posted 05-09-2026 16:42
    I used "fret erasers" I bought from Stew Mac, the online guitar repair site.
  • 14.  RE: Are rusty strings really a problem?
    Posted 05-09-2026 20:07
    The Schaff product that Wim mentions is now simply called "Steel Polish" it did have some sort of brand name before. It's a rubber bar impregnated with emory.
    As another islander, rust is very common, the patina of rust you describe is generally not too troublesome. The string cover helps a lot, if you look closely at the coils, you'll probably see that the top coil is the one that's rusting, likewise, if you take the string off the hitch pin you will see that bottom of the wire is much less corroded than the top, if at all. Bottom line, it is the dust that settles on the string that holds the moisture long enough to corrode.
    When the rust progresses, what I have found is that it can degrade the tone quite a bit. The formerly smooth wire is now covered with flakes and I think that dampens partials in uneven ways and the thickness of the wire is also now compromised and uneven. The result can be dull or nasty sounding treble sections.
    Another problem is that if there is rust present it's like a contagion. I've replaced strings and found it hard to distinguish the new wires after just a few year's time. Even if you polish the old wires, if the rust dust is till present, it will likely reappear on the strings. And after polishing, the strings are still going to be pitted, they look better but they aren't as good as wire that hasn't been corroded.
    There's also a product called Bull Frog rust inhibitor, you can find it at 'The Rust Store'. The local dealer includes their Bull Frog Emitter Shield with all of his new pianos. It emits a molecule that binds with metal and inhibits rust. I think it will even slow down rust that's already started.
  • 15.  RE: Are rusty strings really a problem?
    Posted 05-09-2026 21:00
    Steven --
    "... it is the dust that settles on the string that holds the moisture long enough to corrode." Never thought of it like that but this makes really good sense.
    Funny thing is I actually have one of those old Schaff Polita eraser bars. Purchased it when I first started in this biz, almost 25 years ago. Never used it. Perhaps it's time dig it out and give it a try. If it's still good.
  • 16.  RE: Are rusty strings really a problem?
    Posted 05-10-2026 02:29
    When I used steel wool or worked on a piano that had strings that were cleaned with steel wool I was picking buzzing steel wool filaments off of strings for  years!
    I only use Scotch Bright or a substitute on pianos never steel wool.  Polita works, but for heavier rust I just use a fine sanding sponge.
  • 17.  RE: Are rusty strings really a problem?
    Posted 05-11-2026 02:26
    I tested a metal polish similar to FLITZ and it does polish steel well and quickly, BUT, in a corrosion test it actually corroded the strings over time.  I don't recommend metal polish.
    Cleaning or polishing strings is best done before a tuning, I don't know any way to manipulate strings that wouldn't affect tuning.  On the other hand, a light cleaning before a tuning might render strings through the bridge and might result in a more stable tuning.
  • 18.  RE: Are rusty strings really a problem?
    Posted 05-12-2026 06:42
    You might want to give Balistol a try. I use it for many purposes, but what it is extremely good at removing surface rust. It then acts as a protector, slowing down further development of rust.
    No adverse effects to the unwound strings.  Now, be aware, do not get it on the copper wound strings as it will discolor quickly.  I've been using it for 10+ years without any issues.
    Here in Florida, we are constantly battling any rust development. The wool string cover felt, along with damp chaser systems stops all rust development in its tracks.  I also have very wealthy homeowners who despise the look of the wool string cover felt. Even if with my warnings, they don't want to distract from the look of the string area. In those cases, I'll use the Balistol ( on a cloth) and rub it onto the strings.  It does surprisingly well at stopping rust development.
    Tom Servinsky
    Jazz Pianist for events
    tompiano@tomservinsky.com
    772 221 1011 office
    772 260 7110 cell
  • 19.  RE: Are rusty strings really a problem?
    Posted 05-12-2026 09:26
    I also have a very wealthy client who lives right on the ocean with a nice 15 year old Steinway L. No rust on the strings. I discussed a string cover, but they said they didn't want or need one because the house is hermetically sealed and pointed to several pieces of art that needed protection from the elements.  Considering that the piano was 15 years old with no signs of rust, I couldn't argue with that.
  • 20.  RE: Are rusty strings really a problem?
    Posted 05-12-2026 12:14
    A few years ago I performed a series of tests using a variety of materials to prevent corrosion.  I tested WD40, museum waxes, oils, Ballistol and other materials and after over 6 months in a corrosive environment (under a covered southern California patio) I rated each material for its effectiveness at preventing rust.  WD 40 and Ballistol came out somewhere in the middle, the best results were with a furniture wax (Howards Feed n Wax) and oddly enough, Marvel Mystery Oil (a car engine additive).  Steel polish like FLITZ and MAAS were actually corrosive, they may leave a deposit that attracts water and increases rust.
  • 21.  RE: Are rusty strings really a problem?
    Posted 05-12-2026 12:26
    Gotta be careful about putting anything on strings that could seep into wood.  Remember the guy who used to oil pianos.  His favorite was Tribotech, an engine additive, which he used on bridge pins.  If you're rubbing it on strings with a cloth, make sure it's not going to seep anywhere.  Just enough to coat the string with bare minimum.  But you knew that.  I used to use fine steel wool on old bass strings, but only rubbing longitudinally, not across perpendicular.  That would get into the windings.
    Thanks for doing the testing.  I would imagine regular motor oil would also work.  Did you try that?
  • 22.  RE: Are rusty strings really a problem?
    Posted 05-12-2026 17:05
    I tried mineral oil (drug-store laxative, which is only highly processed crank-case oil), it was OK.  I have a customer who restores very valuable Japanese swords and he uses mineral oil, but it needs to be renewed or cleaned every few years.
    I believe that Marvel Mystery Oil has an an anti-corrosive additive (oil of wintergreen?).  The reason I tested the waxes is because I use it on soundboards and was afraid that the orange oil that I dilute it with might be corrosive.  It wasn't.
  • 23.  RE: Are rusty strings really a problem?
    Posted 05-10-2026 10:09
    The Steinway Worldwide Technical Reference Guide says this:
    "Preparation for Tuning
    Check strings for discoloration/corrosion and clean with a pad (like Scotch-Brite or steel wool) or
    light benzene in order to minimize the occurrence of false beats."
    I have used a green Scotch pad and it worked well to remove light rust.
    But I live in the dessert so rust isn't much of a problem here.
    Gannon Rhinehart
    Santa Fe NM
    (505) 692-8385
  • 24.  RE: Are rusty strings really a problem?
    Posted 05-11-2026 02:35
    It is possible that the cleaning process might seat or render strings at the bridge and reduce false beats and increase stability.  Might not be a bad idea, though I would never touch strings after a tuning.
  • 25.  RE: Are rusty strings really a problem?
    Posted 05-11-2026 02:38
    Very sadly the Bull Frog Rust Emitter Shield is out of stock wherever I look. . . . :-(
    +44 7868385643
  • 26.  RE: Are rusty strings really a problem?
    Posted 05-11-2026 03:50
    David, at the Rust Store they also have rust blocker in strip and cup form that I believe use the same technology. They also have it in a spray bottle, I was using that in my shop by spraying it on a piece of felt and putting it in tool drawers.
    Hopefully the 'shield' is still going to be produced but I think those other products will work and they seem to be in stock.
  • 27.  RE: Are rusty strings really a problem?
    Posted 05-13-2026 20:52
    One of my R.P.T. friends treats all of his piano wire with silicone. It seals the steel and helps in rendering at the bearing points. He sprays the coils, then wipes it with a rag as he loads it into a "film can". I'd be interested to see someone in a corrosive environment try it and report how it holds up. One advantage is that it turns into a solid and won't creep along the wire. A guy in our area would spray WD40 on the termination points for tuning. Problem with an oil is that it stays liquid and ends up following the wire into the pinblock. I can't count the amount for pianos ruined around here!
    Best wishes!
    Eugene Taets RPT
    Silvis IL
    (309) 796-2888
  • 28.  RE: Are rusty strings really a problem?
    Posted 05-13-2026 20:58
    I was always told that silicone creeps, too, just like WD40. I warn my customers not to use Pledge on pianos because the spray contain silicone and will creep into the pins, and eventually into the pinblock.
    I don’t think applying it as a solid to the strings and pins will make it not creep.
    Wim.
  • 29.  RE: Are rusty strings really a problem?
    Posted 05-14-2026 12:02
    This seems like begging for trouble. When the sprayed wire is handled and coiled onto the pin, silicone from the wire might get into the pinblock.
    NYC
  • 30.  RE: Are rusty strings really a problem?
    Posted 05-14-2026 10:43
    Unfortunately, I think any guild member spraying silicone into pianos should be investigated and disciplined. Especially if there's a trail of ruined pianos behind.
  • 31.  RE: Are rusty strings really a problem?
    Posted 05-14-2026 11:59
    Totally agree with Peter.
    The specific info escapes me, but...
    A few decades ago a study was done on some critical manufactured parts that were continually failing final inspections. The suspected culprit was a lubricant containing silicone. Problem was that it was not being used near where the failing parts were being made.
    Long story short, the silicone was found throughout the facility. Workers clothing, hands, tools, doorknobs, faucet handles. Everywhere! As easily as it was unknowingly transferred from one surface to another the lubricant was banned from use. Even at that, it took months of clean-up before totally gone from the facility. (Info supplied by my dad, dept. head of development engineering, and in retirement a QC inspector on electronic products subcontracted by the federal government)
    Deb
    5 Tarr's Lane WEST
    Rockport, MA  01966
    978-546-8428
  • 32.  RE: Are rusty strings really a problem?
    Posted 05-14-2026 13:00
    As our weather starts to warm up from spring to early summer I plan to conduct a series of tests with piano wire suspended from a jig I made to sort out strings I took out of a Hardman Peck grand in my shop/garage. I plan to have an untreated new steel string and a few strings wiped down with various products such as Ballistol , non silicone rust prevention (used by Boeing) McLube (sailkote)  StewMac guitar string wipe, I planned to do this last August but the summer here was brutal with many days where air conditioners could not keep up Some of the pianos I maintain equipped with Dampp Chaser
    dehumidifier bars had trouble and piano pitch and unisons went wild. In any event I am also go to suspend a LASCAR data logger from the jig that will record temp/rh and dew point 24 x 7 . Other plans are to take pictures of the strings with a small microscope to detect changes on the string surface. I expect there will be string flash rusting due to the moisture that will collect on the steel overnight. Most morning here the dew point is in the 90's , grass is wet, car windows collect moisture.  I will have a duplicate jig and strings inside my home which is both air conditioned and humidity controlled.
    I have a full Dampp Chaser in my Yamaha G2 and a woolen Dawson String Cover. My rh is in the low to mid 50's and the dehumidifier rods are just warm . I advise clients constantly to monitor their HVAC and the importance of humidity control. Although I think rust could be accelerated if there is dust on the strings it will begin to form when the dew point is just right. leave a tool outside over night and it will begin to rust
  • 33.  RE: Are rusty strings really a problem?
    Posted 05-16-2026 17:15
    Does anyone know what the active ingredient is in these rust-inhibitor papers?  You see them in a host of applications and they work by diffusing an aerosol coating to exposed metal surfaces that coats them and blocks the formation of rust.  I've used them for many years in my tool drawers along with a patch of felt to protect my chisels, drill bits, etc.   They certainly do the job but it occurs to me to wonder if silicone is one of the constituents of their formulation.  I can understand their hesitation to advertise their active ingredients but I'm not sure it's entirely due to their concern for protecting their copyright when it could be easily analyzed by any competitor by running a sample through a spectroscope.
    Cecil Snyder RPT
    Torrance CA
    (310) 542-7108
  • 34.  RE: Are rusty strings really a problem?
    Posted 05-16-2026 19:14
    The active ingredient in modern rust-inhibitor papers/emitters, like those from Cortec/Bull Frog, is a blend of amine carboxylates (organic amine salts) often paired with triazoles for multi-metal protection. Rather than using older, harsh chemicals like sodium nitrite, these modern bio-based compounds slowly evaporate into the air to form an invisible, protective molecular barrier on metal surfaces.
    You can view Cortec's white paper on the subject here. Cortec also owns Bull Frog, and they use the same tech on their emitter products.
    It looks like these emitters are the only 'passive' chemical treatment that won't potentially cause other problems as there is no liquid carrier that needs to be put on the strings.
    These products are available at theruststore.com
  • 35.  RE: Are rusty strings really a problem?
    Posted 05-19-2026 02:01
    Honestly, I rarely worry about surface rust on the wire unless it's actually pitting or causing rendering issues at the friction points. I've serviced plenty of older Baldwins and Yamahas with that ugly brown coating where the pitch raises went completely smoothly, and the tone didn't suffer at all. Unless the customer is paying for a full restringing or is obsessed with looks, I just leave them alone, scrubbing them down usually creates more mess and metal dust than it's worth. As long as it passes the tuning pin torque test and renders clean, it's fine.
    Mark Purney
  • 36.  RE: Are rusty strings really a problem?
    Posted 05-20-2026 23:01
    If you want to quantify the corrosion on an old piano the best test is not the appearance but the feel.  If the plain wire strings are still smooth to the touch they're probably going to render smoothly as well.  Strings that feel sandpapery to touch are going to grab at whatever steel or underfelt they're crossing and that brittle flaking surface will not only compromise the strength of the string but accelerate the deterioration by giving the rust a fertile patch to grow on.
    The next time you come to replace a string, turn it over and look at the bottom.  Often the top surface is cruddy but the underside is still shiny. That's how it starts.  Dust settles on the top surface and like "seeding" clouds gives the moisture something to cling to. This is one reason string felt covers are effective--they simply keep it cleaner in there.  The other reason is the wool fabric will draw moisture from the air faster than the metal and trap it in their weave.  If you go to a yard good store and ask for baise, you'll probably be handed a roll of polyester.  It's better than nothing, but only about half as good as wool in my estimation.
     There was a family last year in the news that had a bear take up residence in the crawl space under their house. He didn't make a nuisance of himself, they'd just occasionally hear him moving around under there.   So they didn't really have to do anything, did they?  Because he wasn't really a problem.
