ETD Discrepancies and limits of accuracy
  • 1.  ETD Discrepancies and limits of accuracy
    Posted 08-07-2024 19:37
    I've been developing a presentation on hybrid tuning. Something I've been wanting to understand, but am too lazy and mathematically dumb to figure out is this:
    Why does my ear disagree with the ETD? I have a few hypotheses that I'll run by you.
    1. The ETD assumes a perfectly smooth inharmonicity curve between sample points.
    2. Imperfections in bridge notching means the speaking lengths don't increase at a perfectly smooth rate.
    3. Straightness of the speaking portion of the wire and condition of termination points could affect the actual speaking length.
    4. ETDs don't know exactly where the wire diameters change. A wire change introduces an abrupt step in the smoothness of the inharmonicity.
    5. Having all three strings of a unison open, often creates slightly different beat speeds than a single string. ETD's are not reliable when listening to open strings.
    How much do small changes in speaking lengths and wire diameters affect the actual real-world pitches of the harmonics, since this is ultimately what affects the beat speeds? Also which has a more dramatic effect: diameter change or a 1 mm speaking length change?
    Take the F3-A3 Major third, for example. If it's beating at 6.8 bps, how much would the beat rate change if you were to:
    1.  increase or decrease the wire diameter of the bottom or top note by one size?
    2. Increase or decrease the speaking length by 1 mm of either the top note or the bottom note.
    About 75-80 percent of my tuning is aural because I have not found that the ETD can give me the results I'm looking for, especially when I'm setting up the middle two octaves. I often disagree with the machine, especially once the unison is tuned. Having to second guess the display can interrupt my work flow.
    Generally, I strive to always tune unisons as I go, with the final string of each unison being tuned with no mutes in play.
    Since ETD's (I believe) can only accurately measure the pitch of one single string, I question how that translates to the actual intonation of an interval once all 6 strings are in play. We also have to accept that the pitch target is only an "educated guess" (albeit a highly educated one) based on samples. The target accuracy itself may be slightly off due to above mentioned discrepancies caused by wire diameter and speaking length changes.
    This is why I think the perception of accuracy of ETDs is somewhat of an illusion.
    Ryan Sowers RPT
  • 2.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-07-2024 20:42
    Ryan, you'll need to more specific about which ETD you're using, and what settings you're using. Please.
  • 3.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-07-2024 21:24
    Hi Ryan:
    This is a very interesting topic, and important to understand.  All ETD's are not created equal, and they differ in how they process the information coming in, and how they display the pitch.  Most, if not all, advise to tune unisons by ear.  As simple as it might sound, unison tuning is different according to the "school of thought".  Some believe that they should be as pure as possible, and others believe they should have a slight amount of detuning to achieve a sort of "swell".  Exactly how much is not specified, except to note that they should not "beat".  Some ETD's use a single partial in the pitch calculation, and others use multiple partials.  How many, and how the target pitch is calculated is not disclosed.  For example, I used a SAT 1 for decades, which uses a single partial.  I would tune unisons by ear to my best ability to pure.  If I tried to tune each string to the SAT, there would often be discrepancies and beats.  When I started using a multiple-partial app, I began to hear improvement over what I had been doing before.  Since I'm not an aural tuner (but passed the RPT exam), I realized that what I was hearing aurally was better than with the machine alone, confirming what many others had said about checking the tuning after using an ETD to straighten out any discrepancies.
    Then there is the Weindrich effect (sp?) which is the flattening effect of 3 strings played together.  If you want to correct for this, you can improve the tuning, by ear.
    As you probably have heard for months now, there is another discovery and ETD input device which gives a better representation of string vibration than a mic.  The nodes of sound pressure present in pianos presents another wrinkle, where listening from different positions around the piano can present differing beat rates.   Both with ETD's and with one's ears, partials can be heard or masked depending upon where your pickup (mic, sensor, ear) is.  All this with no mention of false beats and mismatched strings.  The magnetic string sensor bypasses any resonances and undamped string vibrations, and presents a much cleaner signal to the ETD.
    Inharmonicity is the phenomenon which is at play here.  Whether it's the graduation of string diameters or bass string scaling, the overtones/partials don't appear where one might expect them to be.  Especially in the bass, there is inconsistency in the various pitches of the partials.
    Given all of this inharmonicity, the job of the ETD is to try to average out all of the inconsistencies, and various "styles" have been invented to favor some partials, split the difference on some, vary the octave width, etc.  Not to mention unequal temperament schemes.
    If that isn't enough, the partials are varying in volume and pitch as time goes on.  Some vary a lot, and some less so.  A new concept called a "Freeze Frame", or timed window within 1 second where the pitch is calculated helps make a consistent reading.  Most tuning is done during the decay phase, but is less accurate because of the changing partial characteristics over the later time period.  As it is thus "attack tuning", over the whole piano, it was not possible to do by ear without the aid of this particular app and the freeze feature.  It is what I am now using, and my clients remark that they like the result.  Most often, I'll tune each string to the app, and clean unisons are almost always the result, in fact cleaner than I was ever able to do by my ears alone.  Not to say I don't listen to them and occasionally tweak as needed.
    Overall, I find that using this app and freeze feature creates a tuning that is as perfect as I have ever been able to do.  Your choices of style, octave width, pure 12ths, etc., will need to be appropriate to the piano size and scaling.  One size may not fit all.  But within these choices, using Pianoscope and the freeze feature will help by accurately displaying the target frequency so that you can closely set your pins.  The protocol for setting up the app include measuring the inharmonicity of every string except the last octave, so there's no interpolation or guessing in between the measured strings.  The result is a smooth transition of beat rates of most of the partials up and down the scale.  Not all will be perfect, since you have to choose which partials and intervals will be favored.  A pure 12th tuning may produce thirds and tenths which beat faster than a normal octave tuning, so that's one consideration, for example.
    I like to think of tuning with an ETD vs tuning aurally is like drawing a graph.  Tuning by ear is like plotting data points, and then drawing a line through them.  Using an ETD is like bypassing that process and simply drawing the line.
    In the end, you have to choose a method and decide which compromises you're willing to accept.  Where the inharmonicity changes, such as over the break, that's where you are going to make your choices.  Smooth thirds may be more important to you, and you'll have to accept uneven fifths and fourths sometimes.  With the newest ETD's, these choices can be made easier and the results are much smoother interval transitions.
  • 4.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-07-2024 21:31
    Hee hee, you're about to get an earful I'm sure...  But here's my take.
    This is true for some but not all ETD's, depending on use... TuneLab absolutely works this way, so it's important to add extra measurements wherever there will be likely breaks in inharmonicity.  Other ETD's use a more "measure as you go" strategy, or have you play all 88 notes anyway.  I'm not deeply familiar enough with the alternatives to go into more detail.
    True, but small enough that it's gonna be pretty negligible.  Look at the inharmonicity graph in a scaling program, and try tweaking the lengths by a couple mm in either direction -- you'll find the change in inharmonicity is very small.
    Also true, but same response as #2.  Either one might be enough to make a unison a little less pure than it could be, but it won't dramatically affect the reading on an ETD.
    True, but again not as much as you might think on a well-scaled piano.  Those half-size wire changes just don't make that big of difference in inharmonicity -- even whole sizes don't cause a very abrupt change in the longer low tenor wires.  If it's really poorly scaled or they couldn't be arsed to use half-sizes in the treble, than _maybe_ it might be an issue.  But again I think this is mostly negligible.
    I think they're perfectly reliable for open unisons...  They seem to match what I hear as long the unison is clean.  Obviously if the unison isn't clean, or _maybe_ if there's a big string mating problem, you're going to get a more squirrely reading.  The pitch change from unison coupling will show up just fine on an ETD.  In fact it's one of the ways that the open unison pitch drift (aka "Weinreich Effect" aka "Virgil Smith Effect") was finally proven to be an actual thing, albeit typically very minor, in the 0.1-0.2c range.
    For what it's worth I routinely use the readings on open unisons to troubleshoot notes that don't sound good in my final listening checks (typically a lot of 5ths, octaves, and P12's).  Usually it's just an iffy unison anyway, but if it's not, I find I can almost always tune to the device and get a good result.
    You can actually play around with this experimentally if you're using an ETD that shows you the inharmonicity constants.  Find a spot in the piano where the wire gauges change, and measure the inharmonicity.  I think you'll find it progresses quite smoothly in most cases, despite the gauge changes.
    There was a thread started, I think, by Margaret Jusiel on this subject some months back...  We agreed there were at least cases around scaling breaks where the typical ETD tuning curve _might_ stand for some aural improvement to make a better compromise between the rapid and slow beating intervals.  But I remain of the opinion that that's more the exception than the rule.
    Nathan Monteleone RPT
    Fort Worth TX
    (817) 675-9494
    nbmont@gmail.com
  • 5.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 02:05
    Recently I wrote a thread about pitch measurement using not a frequency counter based device but an oscilloscope based device. Unfortunately it was pulled for political reasons but it explained the physics of frequency measurement methodology. Mods might consider reinstating it.  A Youtube video demonstrated lab frequency counters measuring two frequencies at 10,000,000Hz and it took an ultra sophisticated and expensive counter to determine the difference between them, however. But a dual beam oscilloscope triggered by one frequency easily showed the wave of the other frequency walking across the screen.
    Likewise in the ETD world there is frequency and phase. Most ETDs measure frequency. Our ears, when tuning pianos, hear beats and this is a measurement of phase. ETDs measuring frequency have to go through all sorts of hoops to determine what frequency to tune which string to according to a mix of measurements of harmonics.
    There are people addicted to frequency measurement such as https://www.youtube.com/@techniciendepiano using a magnetic pickup unknown to this forum who like to give me a good dressing down for my apparent ignorance acquired over 40 years with intelligent comments on https://www.youtube.com/watch?v=x5ttw0Bti4w but in physics a photon can be both a wave and a particle at the same time - so incompatible opinions can exist at one and the same time and both be correct.
    By using the other sort of EDT based upon oscilloscope technology one can visually see harmonic beats racing through the fundamental phase display and this can tell you to take another approach. One can also manually choose a harmonic to tune to by manually setting the machine to an octave or two above or below and if necessary adjusting pitch in that octave. One has full manual control getting it to be an addition to one's ears rather than taking the whole process merely into the magic of the machine.
    Personally I don't like machine magic and the ETD that I choose gives me that ear-assistance that I find helpful without taking from me an ounce of control. I don't have to create files for each piano - I just do them and the instrument sounds as I want it to sound with notes that I tune tuned as I want them tuned rather than what machine-magic tells me that I should.
    The success is audible on duets covering the whole range of the instrument such as https://www.youtube.com/watch?v=RXymuml03pE&t=1342s and https://www.youtube.com/watch?v=AHAZjcPmtrs&t=1565s
  • 6.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 02:53
    I use an ETD but consider it's value only good for setting initial pitch of the first string in a unison. I, too, disagree with what the ETD may be telling me in setting unisons more often than not. The unisons I always tune by ear because I have the ability to hear what sounds correct while the ETD does not.
    Inharmonicity is a crazy phenomena and I find it really interesting. If you consider only the string itself and not how it's terminated it's a bit easier to understand what's going on. As I understand it, because a string has thickness and is stiff it does not vibrate at it's harmonic divisions mathematically. In other words, the reason why A4 at 440 Hz does not have a second partial of exactly 880 Hz is because of the stiffness and the thickness of the string. It does not have absolutely defined speaking length points where the waveforms start and end because the nodes don't act like a finite point hinge. Instead, that node where the string divides itself for that second partial acts like a small curve, making the speaking length of that second partial shorter than the total length of the string by about the same length as the string is thick. On each end. When you have a string that has a first partial of 440 Hz and you measure the second partial it will wind up being a tiny bit sharp of the first partial doubled because the length of the vibrating portion of the string for that second partial is a tiny small amount shorter than the full length of the string divided by two. Every time you divide the string into it's next higher partial that happens again. Every higher partial winds up having a slightly higher frequency than pure mathematical division would suggest.
    Because of this, if you change the thickness of one string in a unison, let's say make it thinner, the partial divisions of that string will be longer, which make the partials of that thinner string divide into slightly lower frequencies than the other strings in that unison. Unisons would be very difficult to pull in, if not impossible.
    Also, increasing or decreasing the total length of one string in a unison means that the length of all the partials divisions in that string will now be longer or shorter and no longer match the divisions of the strings in the rest of the unison. Again, impossible unisons.
    Another thing that can contribute to unwanted beats could be a bridge notch that is not square with the string. If the horizontal and vertical movement of the string are not terminated at exactly the same point on the string you wind up with a string that is one length horizontally and a different length vertically. That single string winds up acting like two strings of different lengths and thus gives false beats.
    I thank Ron Nossaman for covering much of this in his three articles on false beats in the Journal in 2016.
  • 7.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 11:14
    Small addition: The first few partials can be a bit lower pitched than expected from the string inharmonicity forumula(e), and can even go slightly flat rather than sharp compared to their multiple of fundamental.  I've seen this attributed to bridge motion (I think that was in Physics of the Piano, but I don't have it in front of me).  Robert once mentioned that TuneLab uses a lookup table rather than a simple function, to calculate partial frequencies from the inharmonicity constant it stores...
    Edit: I believe this is the reason for the discrepancies between partials that Ron Koval mentioned.  I've observed that too, although I've only seen a few tenths of a cent in either direction.
    Fort Worth TX
    (817) 675-9494
    nbmont@gmail.com
  • 8.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 11:54
    OK I'm going to reproduce Robert's post that I referred to because it was on Facebook, and the search function there is absolute trash:
    (Mark Edwards):
    I understand that inharmonicity of a partial Fn is calculated using the following function:
    Fn = n . F0 . sqrt (1 + B . n^2)
    (Robert Scott):
    The formula cited here is for the ideal case of a string whose terminations are rigid but not against bending at the ends. There are several ways in which real piano strings differ from this model. One of them is that the bridge is not a perfectly rigid termination since it must move to transfer sound. The second is particularly a problem for wound strings because their characteristics are not the same throughout the length of the string. A small portion of the core wire is bare at each end. There is an alternate model that TuneLab uses that has been empirically verified to match better (although not perfectly) to the average piano strings. That model is
    CentsOffset = B * n^2
    The CentsOffset is with respect to the perfect harmonic, n * F0.
    And TuneLab uses a table for n^2 that is slightly lower than the exact n^2.
    Fort Worth TX
    (817) 675-9494
    nbmont@gmail.com
  • 9.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-10-2024 16:51
    Replying to Nathan's post about the inharmonicity equations
    Fn = n*F0 * sqrt(1 + B*n2)
    vs.
    CentsOffset = B*n2
    The two models are basically equivalent and you can get from one to the other with some log identities and the approximation:
    log2(1 + x) ≈ ln(2) * x   (for small x)
    The inharmonicity constants (B) in the two models are related by a factor of 1731.2.
    Anthony Willey, RPT
    http://willeypianotuning.com
    http://pianometer.com
  • 10.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-10-2024 17:10
    Thanks for the clarification Anthony, that makes sense!
    So I take it the improvement that Robert is mentioning here, comes solely from substituting n^2 with a smaller look up table value? Is that correct?
  • 11.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-10-2024 17:32
    It's probably best if I don't speculate on that because, aside from my obvious COI, I'm not very familiar with TuneLab's lookup table or the research behind it. I only wanted to point out the near equivalence between the two models.
  • 12.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 13:18
    There has been a long discussion on the minutia of various devices. Sometimes I feel like the arguments are nothing more than dancing on the head of a pin. But I'm ignorant; I'm neither an engineer or scientist. How about a more basic question; one that might appeal to beginning ETD users?. What's going to work best in the ETD era? I'd love to just see a list of ETD options as a starting point.
    It's been surprising to me how many ETD variants have come on the market in the last half century-all to service such a tiny market. Early on there were really only two and there were sales battles.  It would seem that it's time for an article reviewing the current options and how user friendly they are and how reliable they are.
    How is a a person to know when they're getting good, reliable results. When a customer likes the result, that's one thing. But what are the professional standards that we can use to measure the results of the various ETD devices? Certainly the PTG exam statistics speak highly of ETD results. Most ETD tests score very high. Are there other measures?
    Since many ETD users may not have developed good aural tuning skills, how do they know what they're getting or, more importantly, what they're leaving as they walk out the door? How do they evaluate a machine other than what makes it easy to use, or better able to work in a phone or tablet or with various external pic ups?
    As an example of what can happen, I knew of a tuner who missed moving the note up/down and ended up leaving all the notes of the top octave at a 1/2 step off. That's of course extreme, but it did happen.
    So how does the practical ETD world stack up?
    Richard West
  • 13.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 14:04
    Hi, Nathan,
    The title of the book you mention is:
    The Physics of Piano Unisons (Studies in Science and Philosophy), Capelton, Dr. Brian, Amarilli Books, 2015
    The ISBN (at least on the copy I have is:
    13: 9780992814168
    For my money, this is required reading.
    Kind regards.
    Horace
      Original Message
  • 14.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 18:44
    I find it amusing (at the very least) that this specific subject would come up "now" after all the related discussions over past few months (as if they never took place). Either eyes and ears have been "elsewhere" and not cognizant of relevant data presented, or perhaps it's due to eyes and ears NOT WANTING to hear it from the source it has come from. Hmmmm...LOL!
    I had the same question 20 years ago. It was recently clearly answered, experimentally proven, AND a viable solution devised and made available.
    I'm still shaking my head and laughing at this.
    Edit: GIGO
  • 15.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 18:53
    Peter,
    I'm about as opposed to the overuse of the "report inappropriate button" as you are, but could we please NOT go there in this thread?  Likely the question is being asked in a simpler, more high-level form because not everyone is willing or able to pick through 150+ post threads debating this stuff.
    Fort Worth TX
    (817) 675-9494
    nbmont@gmail.com
  • 16.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 02:54
    Ryan,
    A test: next time you are replacing a tenor or treble string on an inexpensive or old grand put in a wire that is larger or smaller than the original strings.  Listen to the tone differences (though there will likely be a difference between old and news strings).  Then see what your ETD thinks about the different strings.  Let us know.
  • 17.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 03:16
    I'm looking forward to this. You're committed now. When do we get to see it?
    ddf
    Delwin D Fandrich
    Fandrich Piano Company
    Piano Design and Manufacturing Consulting Services -- Worldwide
    6939 Foothill Ct SW -- Olympia, WA 98512 -- USA
    Phone 360.515.0119 -- Mobile 360.388.6525
  • 18.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 08:47
    I'll agree that there is way more variation between the results of tuning apps than tech may first realize...
    Another thing for you to research is the precision of using an inharmonicity constant, which seems to be standard for many of the apps. While the partial "locations" fall close to the line projected by the constants, there seems to be a bit of wiggle room in some of the testing I've seen. If your app allows for stepping through partials of a tuned note and the display moves, that shows that the calculations which should be able to predict the location of each partial isn't quite right. Multipartial tuning can help smooth this out a bit.
    I know Veritune uses a different model which claims to do a better job of predicting the exact location of one partial based on the location of another. I believe that is one reason for a much slower measuring time.
    Then there is the noise in the system - how repeatable (using what ever input) using the app are the tuning target results. They should be very close on repeated measures, but for those claiming absolut precision, they might be surprised to see .1 or .5 or 1 cent differences between multiple measures of the same piano. I believe this tends to actually be more apparent in apps that measure many notes. The ones that only measure a few can be more repeatable, but miss closely matching the piano scale because of having to 'fill in the blanks'.
    Like my mentors reminded me - unisons are the most important intervals in having clients happy with the tuning.
    Ron Koval
    Ron Koval
    CHICAGO IL
  • 19.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 10:40
    Ron - you raise interesting points. What worries me about the clever technology is that we've stopped listening and have become slaves to the machine.
    On another thread I posted a photo of a VISTA tuner from the 1970s, still working other than the mic preamp. With this technology the piano was right and there was no question about it. From memory it tunes the temperament octave C#4 to C5 and tunes all the below for their harmonics, I think, to hit those temperament octave harmonics. Perhaps that might lead to the bass being stretched flatter more.
    For octave 5 there is a fine adjustment. One moves to C#5 and plays C#4 adjusting until the machine is in tune with the 2nd partial of C#4, and tunes up the C6. There's another fine adjustment for C#6 to be tuned to C#5 2nd partial and a third for the top octave tuning C#7 to C#6 second partial, and so getting a reasonable handle on the stretch in the top three octaves, the machine listening to the octave below and with a methodology which follows what we might do listening by ear.
    Music is about what we hear and in my opinion being a good tuner is about choosing what we tune to, hearing it, rather than merely relying on the dark arts of software. We can then tune with intent, with a deliberate consciousness rather than merely an animal consciousness of being subject to whatever the machine decides to tell us. As we move into a more automated age, it's that deliberate consciousness that will be increasingly important to the human race in being human. The machines might not always be right even if they tell us they are.
  • 20.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 21:53
    Just yesterday in an online conversation with a colleague, I commented...
    We are way out in left field with the level of precision we're talking about in comparison with the rest of the acoustic musical world. Being concerned with 1 or 2 thousandths of a semitone is quite ridiculous. Ron Koval made a comment a few months ago about how we (tuners) are in an age of hyper precision, and that's a salient point. These distinctions are only important to us, and even at that only because we have these tools. When I started in the mid 70's and tuning was basically an aural craft, no one talked about cents, everything was parsed in relative beat rates within intervals. And likewise, the way I was taught, piano technology in general primarily relied on the senses. Hammers were hung by eye using nothing more than a straight edge and the discourse over all was in the context of hearing, seeing, and feeling. Intervals were set to "about" this rate or that with the understanding that the fine work was essentially a matter of feel. Relative quality hinged upon individual craftsmanship.
    Now things have changed and we have a much stronger conceptual sense of milliseconds and minute measurements in general. We rely much less on our senses and that manifests in our discourse. What can I say? Time and Space aren't what they used to be. We've all become Mr. Spock! Your friends in Texas  have invented an electronic finger that quantifies touch. Someday we might just send the droid out to service the pianos.
    The arts are one of the few domains where the senses still have primacy, even though many artists are greedy for what new tech has to offer. But in the orchestra pit it's still about touch, feel, and listening. I think we as piano technicians have drifted away from that.
    Notes: *For those that didn't see this at the convention, there is an 'electronic finger' that depresses a key and delivers all of the metrics-key height/dip, I think after touch, up/down weight, and perhaps other parameters and can produce a spread sheet for all sampled keys. I'm sure we will all be seeing it soon.
    When tuning, I'm thinking about 3 days, 3 months and on down the road about how durable the tuning will be, given the circumstances I might not leave the piano in "perfect tune" at that moment when we're talking about fractions of a cent. Even with concert tuning a certain piano I tune often, I know that the room temp. is going to be 4 to 8 degrees warmer in performance than when I'm tuning it and even good pianos don't change evenly across the different sections.
    It's completely appropriate for us as technicians to be having this conversation and talking about the issues Ryan raises and the different approaches one might take. It's also my view that in the end, musicianship of the player far outweighs the subtleties that we are talking about as tuners. The gamut of what's acceptable intonation is wide indeed, even beyond our commonly held conceit of "equal temperament".
    By saying that we as technicians have drifted, I mean that we tend to fixate on the quantitative as if it's an end-all. Our vocabulary for the qualitative seems to have diminished.
    One word/concept we don't hear much in these discussions is beauty, which is different than quantitative perfection. We aren't servicing copying machines here, we are servicing tools for making art.
  • 21.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-08-2024 22:47
    Steve,
    All tuners who have gone down the ETD road should still keep a close eye (ear) on their analog skills and if they find they are rusty they should regularly exercise those skills for their own good as well as that of those whom they serve in the music world. The Doc (Sanderson) admitted publicly that one gets dependent on the machine. This is the Achilles heel of the digital world...once you get used to having your thinking done for you it's hard to get it back. You can but it takes WORK and persistence.
    The aural answer to Ryan's question is that you need to KNOW aurally what you're doing and always supervise the machine (rather than it supervise you). The digital answer to his question is that you need a more accurate input device so that the "little" digital brain can work it's magic and give you a more accurate output. It's as simple as that, IMO.
    And I'll take beauty over power any day of the week.
  • 22.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-09-2024 00:04
    Steven - I'm entirely with you - helping instruments achieve beauty rather than servicing copying machines.
    Perhaps https://youtu.be/90964qqS3Q0?t=1344 might exemplify. One of the purposes of tuning is also not to enable musicians to follow the trajectory of the past 50 years but actually to wake people up and reward musicians for making a beautiful sound. Without rewarding sound music has become a sport, merely of "accuracy" but not of emotional communication.
    At https://youtu.be/90964qqS3Q0?t=2227 the instrumentalist actually has an instrument of beauty to accompany rather than merely the piano being the accompaniment. The music is a partnership of instruments, not merely of performers.
    Potentially I don't believe this tuning can be done without an ETD but I'm with Peter that one needs full control of what the ETD is listening to.
    David Pinnegar, B.Sc., A.R.C.S."
  • 23.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-09-2024 00:17
    Peter, you've got that right!
    I took a seminar with Dr. Sanderson on interval checks. No Act tuner in sight, he knew the checks backwards and forwards and could tune with them.
    And a real gentleman.
  • 24.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-09-2024 20:40
    Bill Garlick once told me that Doc Sanderson was the best tuning student he ever had.
    What a high compliment!
    Ruth
  • 25.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-10-2024 07:20
    Ruth,
    I never knew where the Doc got his tuning training specifically, but that now makes sense, and in retrospect I "see" similarities between the two.  Wow, nice compliment!  I miss his calm (yet authoritative) demeanor.
  • 26.  RE: ETD Discrepancies and limits of accuracy
    This message was posted by a user wishing to remain anonymous
    Posted 11-20-2025 11:58
    This post was removed
  • 27.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-09-2024 01:41
    What is wrong with a simple tone generator that produces the middle or only a few middle octaves and tuning to a pitch?  If the temperament is good then wouldn't we automatically apply appropriate stretch when we tune to the pitch, whether as a unison pitch or within one or two octaves?  It seems that every one of our current ETDs should be able to incorporate this as a new feature very easily.
  • 28.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-09-2024 04:28
    Blaine - yes this is built in to the CTS5. And the 1970s VISTA tuner which I mentioned also has a headphone output which mixes the piano signal with the set frequency so that any beat is more audible. This also applies to the octave harmonics
    The detractors say that modern technology takes all harmonics into account so produce a more comprehensive and holistically better sound but  . . .
  • 29.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-09-2024 02:42
    Judging from what I hear at the top and bottom of the scale from strictly aural tunings that I follow, I would say the ear is subject It's own "illusions".  We certainly, and demonstrably, see that when we compare harmonic versus melodic interval judgement,
    The area of most of interest to me in this thread is that ETDs focus on pitch while the tuner's ear doesn't. Instead it focuses on discrepancies between coincident partials in the form of oscillations or beats.
    The weakness with ETDs is the ability to detect those oscillations or beats through and comparing those with pitch measurements. The strength is its ability to put side to some degree those oscillations in the form of false beats and determine the likely pitch whose target it has calculated based on measurement and its own particular algorithm.
    The ears have their own strengths and weakness as well, but those abilities are somewhat reversed.
    Bottom line is that because the ear and the ETD come at this from different sides, when used together, they offer a nice combination of checks and balances. Thus, I would say, on average, a hybrid style using both electronic measurements of pitch along with aural perceptions of coincident partial disparities will produce a superior result, speed notwithstanding where the ETD has a distinct advantage.
    That's why I would always choose a hybrid option. Typically, that means unisons by ear or about 2/3s of the piano with some crossovers in different parts of the scale.
    Why do we always present this as a choice we have to make?
  • 30.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-15-2024 16:06
    Ryan (responding directly to the original post),
    You posit experience where you disagree aurally with what you believe to be the "decision" of the ETD. This is pretty amorphous stuff. I can't really respond to your questions based on your personal experience without being there, observing you tune a piano with an ETD, and then checking with you, comparing notes.
    What I CAN do is share my own initial experience tuning with an ETD, 30 years ago (following 15 years of purely aural tuning). I got an SAT so that I would be able to give tuning tests, and decided to try it out, though I was very skeptical. I tuned a couple midrange octaves with SAT, then checked that aurally, and found "errors." But then I looked at each of the error notes, with the ETD, and found that they were not zeroed. (I had just been through lots of CTE training on zeroing the display, so I was well aware of what I was seeing). When I zeroed the notes, all the errors went away. (This kind of experience was repeated time and time again).
    So as a first response, not wishing to cause offense, I would first ask you to do precisely the same thing. Recheck the notes you object to. What does "zeroed" mean on your device? I don't know, not knowing what device you are using. To be successful at tuning with an ETD you need to figure out what zeroed means, how to see through any "junk" in the display (in many cases, use the strobe emulator, moving gray rectangles, as the most reliable factor), and then execute to zero out. As an exercise. take a note, zero the ETD on it, set an offset to plus or minus 0.5¢. Now tune to that new, slightly changed pitch target. Can you zero to it? Try again with 0.3¢. If you can't match the ETD's template to that degree of accuracy, how can you judge what the ETD has calculated?
    As I took up the SAT, and very rapidly decided not to tune without it (for reasons I'll describe later), I certainly had quarrels with it, particularly with respect to stretch. I won't bother going into details, but I found ways to make it do what I wanted to do for that purpose. But there were inharmonic gaps to get past, particularly on my fleet of Hamilton studios. Nasty gaps of inharmonicity. I had never been able to be satisfied with how intervals progressed across them.
    So I analyzed them, and realized that if I wanted smooth M3s I would need to lower the plain wire pitches and raise the wrapped for the notes involved in the M3s across the break. So I experimented with that, and found that if I did enough to get good beat rate progression of M3s, all kinds of other things fell apart, and they were magnified when I expanded outwards into bass and treble. I came to the conclusion that the algorithm of the ETD actually was better in the long run when I was looking at wider intervals like 19ths and triple octaves. And the piano didn't really sound better with improved beat rate progressions.
    I could write more along these lines, but I think this much provides some pertinent ideas.
    More to the point, the reason I have used an ETD for all my tunings for 30 years comes down to unisons and stability. Pitch isn't all that important. Violins, voices, clarinets, oboes, full orchestras are all over the place, even the very best. All over the place relative to our cents and fractional cents. And that's if they aren't intentionally bending pitch, which they are doing all the time.
    For the piano, timbre is entirely dependent on unisons. (Yes, lots of other factors, but even if they are all perfect, including mating, bad unisons will overcome them). And a perfect unison is nothing if it doesn't last. Use of an ETD enables me to focus on the feel of the pin moving in the wood, the sound of the result, and the movement of pitch, simultaneously. When homing in on the pitch of each string, it is possible to make tiny, real-time manipulations of the tuning pin that don't move it in the block, and find out whether the pitch is solid or not. This is more complex than I care to go into, but in a nutshell, if you can make minute motions of twist and flex of the pin in both directions, and see (in the ETD display) the pitch move slightly sharp and flat evenly in response to those moves, and if playing the note a few times results in no pitch change, you know you have nailed it. (Bearing friction means that it ain't that simple :-)) That's the most important reason I use an ETD: ability to achieve stability efficiently.
    Bottom line, I'm guessing you are coming at your question from the point of view that ETDs really don't work that well, that aural is better, and wanting to justify that position. I also have the impression that you haven't done a lot of ETD assisted tuning, just fooled with it a bit and didn't like it. Am I wrong?
    fssturm@unm.edu
    http://www.artoftuning.com
  • 31.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-15-2024 20:19
    Interesting that Ryan's only post is the first one.
  • 32.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-15-2024 22:08
    I'm still here Larry! I knew someone would call me out about my "post and run" behavior. I was still on the tail end of my vacation time when I made the original post and then quickly got swamped! I'm going through all the posts and will respond ASAP.
    Ryan Sowers RPT
  • 33.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-15-2024 23:07
    I'll just add one thing to my post. I have actually compared aural tunings with those executed using ETD, and have done so using aural means: beat rates. I published an article telling how to do that in May, 2022, then a followup article comparing a master tuning (freshly recorded after it was completed) with a tuning I had executed using RCT (without using any aural checks, just "stopping the lights") on essentially the same model piano (both Shigeru Kawais). Please read that article. You will find that the tunings were near identical. Where there were discrepancies with the kind of beat rate pattern we try to create, neither was clearly better than the other. If either, it was the RCT tuned piano that was marginally better.
    I did a number of other RCT tunings, recorded and analyzed them, a couple years before the articles were published (while I was still working at UNM and had ready access to many models of piano). Baldwin 243, Baldwin 6000, Kawai GE20, Kawai UST9, Steinway D, Mason BB, Petrof 125, Yamaha P22, Yamaha U1, Yamaha C2. All showed clearly that the ETD tuning did quite well at creating the progressive beat rates we aim for in aural tuning. (I took video of each tuning, showing the ETD display, to demonstrate that the notes were quite well tuned to the ETD).
    I would welcome anyone's submission of real data showing the superiority of an aural tuning. I have provided instructions for how to do it. Let's be objective, not just "argue by anecdote." I'm happy to share my original audio/video files, should someone care to examine them.
    fssturm@unm.edu
  • 34.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-15-2024 23:18
    Thanks for the thoughtful reply Fred, and everybody else as well. I originally posted right before I got caught up in flurry of activity and am now trying to catch up.
    You said: "You posit experience where you disagree aurally with what you believe to be the "decision" of the ETD. This is pretty amorphous stuff." The decisions don't feel amorphous - a fifth should be almost pure but not exactly. Octaves in the midrange need to be reigned in by the faster beating intervals so they don't get to "edgy" sounding. It's  pretty straightforward. But I'll have to agree that if you aren't in the room when I'm going through my temperament and midrange, then my claims are pretty much heresay.
    You said: Bottom line, I'm guessing you are coming at your question from the point of view that ETDs really don't work that well, that aural is better, and wanting to justify that position. I also have the impression that you haven't done a lot of ETD assisted tuning, just fooled with it a bit and didn't like it. Am I wrong?
    You are only partially right (no pun intended).  ETDs work extremely well at measuring pitch. They do a reasonable job at temperament and stretch if you know how to keep them on track. But I find that as unisons are pulled in, it is always important to keep checking and rechecking the intonation of the intervals. I have not found I can rely on it, and constantly second-guessing the ETD interupts my work flow.
    I also wouldn't say aural is better: I have a thought experiment that goes like this: For some reason I am no longer able to tune my piano and have to choose between two other tuners in my area. Tuner one, is not an RPT because he failed the aural midrange portion of the exam but scored 100% on everything else including unisons and stability. The other tuner is an RPT who squeaked by with scores in the 80's including unisons and stability. Which do you think I would choose? It's not a difficult decision at all.
    My orignal post mentioned that I'm working on a hybrid tuning class. "Aural tuners without an ETD are lacking a valuable tool, ETD users who lack strong aural abilities are lacking an invaluable skill" is the subititle. I'm trying to figure out where the best of both worlds is. What are the strengths of the ear and where can ETDs serve us best? So I'm certainly not "anti-ETD". But I'm also a little heartbroken to see talented young tuners who have become dependent on their ETD and are failing to learn how powerful aural tuning techniques can be.
    My first use of ETDs was when I was in CTE training back in the late 1990's when the Accutuner II was the standard. I know exactly what you are saying about "zeroing out" the machine being a leaned skill that requires a somewhat nuanced technique and plenty of practice. Different examiners may have different interpretations of the display when the rotating lights did not give a steady signal. It's particularly tricky when one or two tenths of a cent can be the final straw for that examinees score.
    I purposfully did not disclose what ETD I've been using because I'm not entirely sure how relevent it is. But for full disclosure, I mainly use Tunelab as my ETD assist. I also have an upgraded version of Pianometer that I've played with as well.
    One thing I'm very curious about is how ETDs are being used in Master Tuning exam pianos these days. Is anyone able to use a stock ETD midrange as a mastertuning without having to make a few tweaks here and there? If tweaks have to be made: why?
    You also made an interesting point in your post that "When I zeroed the notes, all the errors went away. (This kind of experience was repeated time and time again)." Yet, how did you know the errors went away unless you could aurally verify? One of my points about aural tuning, is that it make you better at interpreting the display.
    I've been meaning to borrow cybertuner and a SAT IV to compare the results I get from Tunelab. I've heard Cybertunings that I thought were overstretched - yet that can be largly a matter of taste and the stretch settings. Which begs the question: What's the best way to develop taste from a tuning perspective?
    Of course you are absolutely right that it comes down to unisons and stabilty. This is the reason why I currently prefer open string tuning and mostly just use one mute when tuning grands. It forces you to be picky about unisons, and it puts you in "unison headspace" much more frequently than other approaches. Unison shimming because extremely useful and important in addition to being very effecient. I now percieve the single string of a note to be like the "course adjust" on an old shortwave radio and the "shim method" as the "fine adjust". I have to thank David Anderson and Rick Butler for the "one mute" tuning advice. I resisted for many years, but am now a believer.
    I find the most powerful use of an ETD is in "direct interval tuning" which it turns out goes back to site-o-tuner days. For example: When tuning F7, have the machine listen to F7 but play F6 and F5 and A#5 to see how the display behaves with the single octave, double-octave, and twelth. It's very educational to see how these things line up and to observe inharmonicy somewhat directly.
    We will definietly have to get together in Iowa, Fred, and work some of this out on a real piano!
    Ryan Sowers RPT
  • 35.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-15-2024 23:35
    Ryan, would you please explain "shimming"?
    Also, am I to understand that you are aurally laying in temperaments without a temperament strip?
    Thanks.
  • 36.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-16-2024 01:05
    Hi, Steven,
    While I, too, am interested in "shimming", I can speak (at least a bit) to single-mute tuning:
    While I do not know about current practice, I do know that, for some (long) period of time, both the graduates of the London College of Furniture program in Piano Technology, as well as folks at Steinway's London branch had to have that arrow in their quiver. ("After all, when one is tuning ET, there really is only one place for the pitch to go" ...Bob Glazebrook, former head technician at Steinway, London, circa 1974.)
    In my own practice, I worked with one mute long enough to get familiar enough to feel confident in using that method; and then went back to using the more traditional approach I had been (and still am) using. While I think it's handy to have; for me, it's not mandatory.
    Kind regards.
    Horace
      Original Message
  • 37.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-16-2024 10:33
    Another term is "cracking the unison". People might be more familiar with that term. For those who aren't the technique is this: you are tuning a fifth but the string you've tuned is ever so slightly lower than you ideally want it. Instead of continuing to fool with that string, you tune the second string so that it's beating ever so slightly to the sharp side. When I say ever so slightly, I mean right on the verge of human perception. You stabilize that and then bring the first string you tuned up to make a clean unison. If you want to bring it up just a slight amount more you can slightly detune the unison to the sharp side once again and then bring the other string up to match.
    The term "shim" is descriptive because the shim is the amount of out of out of tuneness of the unison. You are using that barely perceptible out of tuneness to leverage multiple strings up. Most professional tuners can tune unisons within two or three tenths of a cent. So shimming is a way to move an entire note up or down by a few tenths of a cent. Since you are moving the whole unison up and purifying it you have a very stable reliable subtle note change.
    Ryan Sowers RPT
  • 38.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-16-2024 05:15
    "I find the most powerful use of an ETD is in "direct interval tuning" which it turns out goes back to site-o-tuner days. For example: When tuning F7, have the machine listen to F7 but play F6 and F5 and A#5 to see how the display behaves with the single octave, double-octave, and twelth. It's very educational to see how these things line up and to observe inharmonicy somewhat directly."
    Yes - this is what I have been advocating as it enables one to have a personal intention and choice on stretching rather than being the robot of the superclever machine nowadays.
  • 39.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-16-2024 08:24
    Ryan,
    I have been advocating VERY GOOD aural/analog tuning and analysis skills as a prerequisite for digital assistance fir a long time. Why? Simply because everything an ETD does (algorithms, etc.) is based on what good analog tuners are capable of achieving. Like everything else in the digital world, the goal has always been to remove decision making (a.k.a. "making it easier" is the mantra) and mental effort from the operator (if you carefully analyze everything digital you will see the above to be true).
    It is imperative to be able to verify that the primary decision maker is doing so as intended. If one cannot do that, one's qualifications are seriously called into question. This is the OVERALL THRUST of the exam requirement to tune the midrange (at least) without digital assistance and the AURAL VERIFICATION portion...to answer the question: "Does the applicant really understand what they are doing?"
    I'll leave it at that for now but I have much more to say on the matter.
  • 40.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-16-2024 12:30
    Ryan,
    Since you are "pulling unisons as you go," tuning the first string to the ETD, then the other strings to the first one, there is a good possibility that the pitch of the first string shifts a bit during the process of pulling the unison, especially if there is any pitch change involved. So the resultant unison pitch may or may not be what you originally tuned, especially if you add the possibility that it wasn't solidly placed - which is quite likely unless you have been concentrating on doing ETD assisted tuning.
    So before "blaming the machine," you should go back to each of the original strings you tuned to the ETD, and see whether they are, indeed, precisely where you placed them. I think you might be surprised.
    I really don't think all your speculation about notching, terminations, gauge changes, Weirich effect are warranted. Granted that at the very edge of precision, we find out that it is an illusory goal, because tone production of the piano is not precise. There is no such thing as termination in a piano when you examine it closely enough (the Phoenix system bridge agraffe comes closest). Lots of other factors like mating come into play: the number of pianos we tune that have meticulous mating is vanishingly small, unless we were in the position to "make it so." (somewhat the case in my university situation), so we are constantly dealing with out of phase. This is far more disruptive to the pitch of the unison vs single string than the Weirich effect. Effects of notching, gauge changes, etc., are, as Nathan pointed out, similarly insignificant.
    In approaching the integration of aural discernment and ETD tuning, I would focus almost entirely on stretch, on coming to an understanding of how the partials on the whole piano line up. What are we after? How can it be achieved with the inner algorithms of the particular ETD? SAT II (the one I used) had a miserable stretch for octave 5 and above, but I learned a tremendous amount about stretch through use of that SAT, particularly as you describe: direct interval tuning. Where is the top note relative to the notes below that share it as a partial?
    Very early on, I took an inverted partial series as my template for stretch, eg C7/C6/F5/C5/G#4/F4 (octave/5th/4th/M3/m3). It consists of a 19th with the five notes that each focus a partial on the top note. I like to expand that to the triple octave, adding the C4 in the above example. To me, it is the large intervals that determine the overall sound of the piano, up to quadruple octaves on concert instruments. And I believe the large intervals should determine the size of the intervening single octaves, rather than trying to adjust each single octave to "sound best." When I first started with RCT 20 years ago, I wanted more stretch for the top couple octaves (which I could get to some extent by inner tweaking). Now, the style 5 essentially matches what I want, as does P 12 (they are nearly indistinguishable).
    That is one approach - and I can attest that not once have I had a complaint that my stretch was too wide (and I have done a lot of concert work for discerning artists). I take it this is probably more stretch than you and many others want, and that is another aesthetic choice, but it should be a choice made consciously.
    The various ETDs have different possibilities for choosing/generating stretch, and it isn't obvious which if any will serve the needs of an individual tuner. I think that is where an aural/ETD hybrid class should most profitably focus attention. I don't see much if any value in fussing with progressive beat rates in the mid range. Yes, you should be able to hear them, but no, you don't need to "check your ETD's work" with respect to that factor. Rather, you need to be certain you are able to execute what your ETD is suggesting. I think I can say with assurance that all professional level ETDs produce a very good template for the mid range (I've tried TuneLab, PianoScope, PianoMeter, OnlyPure, VeriTuner, etc.) If you wish to question this statement, please follow my example and test it objectively (a la my articles Measuring How We Tune). We don't need any more beating of this dead horse. It is dead.
    "We either make ourselves happy or miserable. The amount of work is the same." - Carlos Casteneda
  • 41.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-16-2024 14:30
    To Fred's point in the first paragraph ("there is a good possibility that the pitch of the first string shifts a bit during the process of pulling the unison, especially if there is any pitch change involved"): this is exactly my experience with using an ETD to measure open unisons, a good 95% of the time at least.  In particular, when I use the overpull function in TuneLab, I find the greater part of the pitch drop that it's compensating for, has already happened by the time I tune the rest of the unison.
    Fort Worth TX
    (817) 675-9494
    nbmont@gmail.com
  • 42.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-16-2024 14:49
    Thanks for this- I have often noticed it and ascribed it to my own incompetence... so I always check and come back to that middle string
  • 43.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-16-2024 19:53
    As we know too, the mic based input on these units varies in its accuracy. I have had the situation where I zero the display, then move the unit, read the same note and it has "moved" (according to the ETD), then move it again and the note had "moved" again, but in the opposite direction. Hmmm.
    And, as I have mentioned before, I asked Jack Stebbins if he's ever been able to recreate a "master tuning" acceptably from the saved data alone. His reply was: "With great frustration...NO!"
  • 44.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-17-2024 04:47
    Peter - I've tested for movement of pitch measurement with my machine and not found the problem. If the unit is measuring just the fundamental or one harmonic alone, as I believe the ETD that I use does, then I don't think it's possible for that movement to change. However the problem might be with modern apps processing a bunch of harmonics being too clever. When the machine or mic is moved there's a different harmonic which will come to the fore or be suppressed and alter the balance of what the too-clever stuff is measuring. This might well be what the Petersen Pitch Grabber might address.
  • 45.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-17-2024 07:47
    You may in fact be correct that the issue arises due to the multi-partial analysis of these more modern units. Yet, this is the general direction things have been going in the past 10-20 years. Why? Certainly the exponential increase in computing and processing power available to programmers is tantalizing to them to somehow put it to use, however ultimately it is a function of (I posit) biomimicry of a high order.
    ETD designers (from the very start) had to ask the question: "How can we emulate (digitally) what a highly skilled analog/aural tuner can accomplish on a  good instrument?" And in elementary ways they figured out how to somewhat synthesize the process, or at least expose some of the process to a visual medium. These were nothing more than a visual "assistant", the SOT being obviously the most sophisticated at the time, yet requiring much manual attention to do anything useful. However, with that, the fascination that programmers have with "replacing the human brain" was born in the realm of piano tuning. (I have a story about Steve Fairchild that I've mentioned before but will not relate here).
    As computing power increased, designers again were asking: "How can we more closely emulate what a good analog tuner can do, since they're listening to not just one partial but many partials together?" Dave Carpenter is perhaps the first to have captured much of this with his Verituner, and now the race was on. Algorithms have become increasingly complex, and device's ability to run them at high speed has become more and more realistic. Nonetheless they are competing against the vastly superior human brain (clarification...the well trained human brain), and although the speed at which these devices can operate, and the amount of data they can expose visually gives them a deceptive appearance of superiority over the ear/brain/hand/ experience combination. Yet, they still have their limitations, one of which is their "decision-making" in selecting which partial(s) under which circumstances to make their final "decision" and show you what they think. (Yes, the ear/brain can have this difficulty as well...that's a given).
    The problem arises though that the sense of sight trumps the sense of hearing (this is a well known fact). Therefore there is a strong tendency for the tuner to assume that (at least initially) what the ETD shows is correct, and what is heard is defective somehow. This creates conflict when the tuner has the capability of discerning a difference (if the tuner does not have this capacity there is no conflict and thus becomes a slave to the digital brain which makes the decisions for him/her). Only with determined effort can the aural/analog tuner discern (and thus execute) any differences that may appear. This is what I believe Ryan is referring to in his OP. Unfortunately though, in time the vast majority of tuners in this predicament gradually decide that the differences expressed are essentially trivial and succumb to the "ease" of letting the device do the thinking for them and let it go at that. (Al Sanderson was well aware of this fact and humbly admitted it. Some other designers are 100% intent on eliminating our thinking ability [I have this in writing from one so I'm not making it up]). But anyway this is the overarching intent of the digital world (AI being the obvious result of this thinking which has in fact been the behind-the-scenes goal of programmers from the days of ENIAC in 1945).
    Enough of that...my experience has been that, although these ETD's have amazing capabilities, they are slightly handcuffed by their internal microphones. If that could be fixed such that the input received was consistently (repeat: consistently) accurate...you'd really have a tool to be proud of.
    Sorry for the long and rambling post.
  • 46.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-17-2024 14:00
    Peter Grey said "The problem arises though that the sense of sight trumps the sense of hearing (this is a well known fact). Therefore there is a strong tendency for the tuner to assume that (at least initially) what the ETD shows is correct, and what is heard is defective somehow. This creates conflict when the tuner has the capability of discerning a difference (if the tuner does not have this capacity there is no conflict and thus becomes a slave to the digital brain which makes the decisions for him/her). Only with determined effort can the aural/analog tuner discern (and thus execute) any differences that may appear. This is what I believe Ryan is referring to in his OP."
    100%. Even though I consider myself an advanced aural tuner, I find the visual display very compelling. You have to have a certain amount of confidence and competence to overide that display.
    Fred's point about the ETD not being in error, but just "different" but equally good, implyes that the tuner is able to make that discrimination. I've also heard the argument about the advanced ETDs listening to more than what we can here so the so-called "errors" become "features" in the context of more expanded multi octave intervals. I'm hesitant to disagree with Fred, as I admire his clear thinking and skills both as a technician and as a fantastic musician. However, in my mind a fifth should sound like a fifth, and the octaves need very precise stretch, especially in the midrange. I still need to go and look at the materials Fred referenced.
    Ryan Sowers RPT
  • 47.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-17-2024 06:38
    "...this is exactly my experience with using an ETD to measure open unisons, a good 95% of the time at least.  In particular, when I use the overpull function in TuneLab, I find the greater part of the pitch drop that it's compensating for, has already happened by the time I tune the rest of the unison."
    Hi Nathan, please explain how you are measuring the open unisons, what you're looking for and why?
    Mark Davis
  • 48.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-17-2024 10:23
    Hi Mark,
    "Measuring" was probably too fancy of a word ��. In this case I'm just looking at the pitch -- same as you would do for a single string. I'm almost totally relying on my ears to tell me if the unison is right or not. I.e. I'll look at the phase display and make sure it's mostly stopped (or wiggling back and forth - I set the sensitivity REALLY high, so the thing almost never totally stops). I'll also look at the spectrum graph at the bottom, expecting to see the peak close to center, and the numerical readout close to zero. How picky I need to be about this is very situational.
    That being said, one does learn to spot certain patterns on the phase display especially, that tend to identify an out of tune unison. It does a certain jerky thing as it bounces between the two pitches. But it's not very reliable.
    Let me know if that clears it up. If not I can shoot a quick video later of what I do... Maybe someone will show me a better way!
  • 49.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-17-2024 12:28
    Peter - yes - I think you hit the nails well on the head - although microphones aren't the issue. There are, however, differences between omni directional and cardioid and this gives spatial differentiation in positioning. I'm resurrecting a 1979 VISTA tuner at the moment to demonstrate on video and trying different mics and the directionality of their response becomes quite critical. That device, however, was built for use with a high impedance crystal mic so I'm looking forward to the Pitch Grabber.
    Nathan "one does learn to spot certain patterns on the phase display especially, that tend to identify an out of tune unison. It does a certain jerky thing as it bounces between the two pitches. But it's not very reliable."
    Yes - when there are two near frequencies close to each other one hears the beats as at some stage the + and the - of the vibrations goes out of phase and they cancel. That's exactly what we see when the display jumps on the cusp of that phase cancellation and phase change. It's a really helpful indication and . . . . I'd think it a reliable indication and have found it such. However it also happens with false strings as well as the change from vertical to horizontal vibration modes of the string. It's in hearing and seeing this that I refer to a partnership between ear and eye.
    These discussions are really helpful in refining what we see and relating it to what we hear and do.
  • 50.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-17-2024 14:38
    At Reno, Frank Illenberger showed me an off the shelf mic unit with seven mics, each looking in a different direction, that he is beta testing. He has configured PianoScope to accept and input seven simultaneous inputs. Might be a promising solution - but probably only for PianoScope, as it does require the ability to take all those inputs.
    That said, I have never really had a problem with mic and directionality. That is, the issues, when there are issues, show up when listening to the unison, and they can be solved by moving the mic (ie, the phone) until another reading is found. And they only occur on a scattering of strings, usually in octaves 5 and up. (This is based on using RCT, earlier with SAT. Other apps may behave differently).
    fssturm@unm.edu
    Youtube Spotify Deezer Apple Amazon
    "Art lives from constraints and dies from freedom." Leonardo
  • 51.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-17-2024 13:34
    Thanks Nathan, that's helpful! Just two more questions, what do you set the spectrum display to, 6 or higher, and what do you set the phase display to?
    Mark Davis
    Mark Davis Piano Service
    Cape Town
    South Africa
  • 52.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-18-2024 18:10
    I have the phase update set to 1.95 right now. It's probably kind of overkill to be honest - I may lower that a bit.
    I actually forgot there was a setting to increase the spectrum update rate! I just had it at the default which was 2.7 I think? I'm gonna try the faster settings.
  • 53.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-18-2024 11:11
    One aspect of this that might also be considered, especially when it comes to aural versus ETD unison tuning, is that that ETDs mostly listen to a single harmonic (I suppose depending on which device) but that single harmonic listening is what allows for "direct interval tuning".  With unisons, that can be misleading.  Aurally, we listen to the entire range of harmonics, or at least we hear them even if we don't focus on all of them.  But our perception of a "clean" unison takes into account all the harmonics that are within our perceptual field.  This problem is seen most noticeably in the bass where the harmonic series between, say, a pair of bichords may not exactly align.  This is likely due to the handmade nature of the strings.  But I notice that when I have mismatched bichords, the ETD usually produces a final unison which is worse than if I do it by ear.  I believe that's because it's only focusing on one of the harmonics and ignore all the other conincident harmonics.  My ear is trying to find the best place that accounts for all the harmonics that I can hear.
    Does that same discrepancy occur in the plain wire section?  Clearly less because the manufacturing is more precise.  For that same reason, ETDs tend to do pretty well (for me) in the midrange and, as Fred suggests, if I'm conscientious about accuracy with the ETD, I rarely find a problem in the midrange, two octave temperament section.  This would agree with many ETD users who say that they tune aurally going down in the bass.
    The treble adds its own unique problem to aural tuners because of the greater difficulty in hearing multiple high partials and also due to clarity issues that often plague those sections.  Aural tunings that I follow show most of the inconsistencies, if not downright bad choices, in that area, I find.
    Leaving the center octaves then the ETD becomes more of a victim of its own preprogrammed stretch calculations.  Thus, we are able to change the stretch to accommodate what our ears tell us.  Of course that can have an effect in the midrange, temperament octave as well, though the discrepancies in stretch don't become that as apparent until we move away from the center section.
    ETDs all have stretch options and I have certainly found that some stretch options work less well on certain pianos.  In such cases I'm certainly making an aural judgement and adjusting the stretch accordingly.  Some folks using RCT (for example, which is what I use) have tried to determine a universal stretch setting that works on all pianos.  Many have settled on a P12 option.  I don't really find that works very well as a universal standard.  Often it creates too much stretch, especially in the treble.
    The bottom line is that ETDs were designed to be used in conjunction with aural tuning for these very reasons.  I don't think the issues are inconsistencies in bridge notching or changes in wire dimensions.  Obviously, stability can distort our perceptions and every pitch change we make affect the final pitch by a factor of some 25-30% through most of the piano.  Thus the only way to achieve a truly stable tuning, from the point of where we start, is to have the piano in perfect tune to begin with or to do layer upon layer of fine tunings until the changes we are making are marginal.  That's not really practical.
    Plus, there may be a point where too much information creates a problem as well.  A device that measures each note and its partials and then calculates a trendline from that may be trying to accommodate too many small differences and the overall curve may end up being a high order polynomial (5th or 6th order) rather than a simpler but more contiguous 2nd or 3rd degree.  That may be counterproductive.
    So, I think it's best to simply treat the ETD as a tool and like all tools it's only as good as the skill of the user allows.  It doesn't allow us to abandon those skills largely because pianos are not perfect and there are always judgement calls to be made.
    Even the sharpest, well-honed chisel doesn't cut the wood by itself.
  • 54.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-18-2024 11:51
    Excellent post, David. Although we are definitely in the ETD era and there's no turning back, your post tells us why aural tuning is still at the heart of what we do and cannot be passed over. For me, aural tuning is not only necessary; it's fun and challenging and provides me the opportunity to engage in an art that will be lost, if reliance on ETDs is the sole or even the primary tuning method.
    Aural tuning offers me the opportunity to engage with each individual instrument and to hear how it wants to be treated. I've always told students that no two pianos are exactly alike and engaging with each one allows us to bring out the best in each encounter. But only if we listen carefully.
    Thanks for showing why we shouldn't brush off aural tuning as anachronistic and unrequired.
    Richard West
  • 55.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-18-2024 13:56
    Thanks Richard.  I hope there's no sentiment that ETDs will replace aural skills.  Even with devoted ETD users 2/3 of the piano is tuned by ear (unisons) with the possible exception of the very high treble where an ETD can be useful in hearing through the noise.
    I do think, however, that in the temperament octave, or two octaves, that ETDs are just better and more consistent.  I agree with Fred here, that if used properly, and assuming good hammer technique (that skill doesn't get enough attention IMO), on a reasonably well scaled piano, that ETDs will outperform the ears in this section when measured over many tunings.  That's not surprising really.  There is a science to the division of a single octave into 12 equal parts and, when you think about it, our aural methods, while effective, are pretty crude.  We get good at it through hours of practice but even the best aural temperaments will have greater deviation than those produced by ETDs.  This is also a pretty easy thing to test and verify using scientific methodology, if it hasn't already been done by the countless examinations  over many years.
    But to your point, Richard, I absolutely agree that aural skills are very important and should not be ignored even in the case of advancing technology.  However, assuming equal skill with the tuning lever, if I had to choose between a hearing impaired person tuning with an ETD (including unisons) and someone not so skilled at aural tuning, tuning everything by ear, I'd probably choose the hearing impaired person with the ETD.  Better odds.
  • 56.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-18-2024 14:27
    David: Thou doest equivocate. It takes a bit away from your less equivocated first statement.
    Here's something to consider. Do our crude methods really make it impossible to tune ET? Certainly the ETD's slice the octave into precise equal algorithmic pieces, but that may not be what the piano itself wants. That is, we may find that a slightly slower M3rd may actually improve the sound of a fourth, or fifth, or sixth. In that case we'd have to dare to deviate from what the ETD may be "saying." Early on I used to believe the ETD over my ears. And most of the time the ETD was right. But I've tried to allow my ears to have equal status in the argument, Not doing so lessens and demeans the importance of aural tuning and its future..
    Not to undermine what you and Fred have stated. To a large part I agree. But, my argumentative side wants to stand up for aural tuning in general so as to not allow time and neglect to make aural tuning slip into irrelevance.
    Richard West
  • 57.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-18-2024 17:13
    Not to mention "losing your chops". Analog tuning is a "whole body experience".
  • 58.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-18-2024 21:51
    Not equivocating at all. I've stated many times on these discussions over the years that etds do a better job of setting temperaments generally. That we can find isolated examples of a modified temperament sounding "better", whatever that actually means, doesn't change the fact that they generally do a  more consistent job. The evidence of that is likely right in front of us in the RPT tuning test. Usually when a modified, slower third is necessary, it's when bi-chords intrude on the temperament octave.  Almost always those pianos are spinets with very flawed scaling that are full of compromises no matter which way it's done.  With most ETDs those flaws are compensated for in the original reasons or by adjustments to the stretch.  Of course mastering the device you use helps.
    My post was primarily in response to a "one or the other" theme that seemed prevalent through this thread.  Honestly I think many techs are locked into 19th century thinking on this.  Technology and AI are fabulous tools and getting better all the time. They on average reduce the margin of error prevalent in aural tuning, or bad judgement when it comes to tuning  the extremes, plus compensating for pitch corrections in a way that the ear simply cannot do with such accuracy and predictability.  Plus, in any pitch correction situation with an ETD that compensates for that you are actually tuning to a target which is not the final target, but rather the compensated pitch in anticipation of where the pitch will ultimately settle. So then what are you listening for really?
    When it comes to unisons I prefer aural methods for speed mainly but because I like my ears to be the final arbiter there and because with unisons there are no interval checks required as there are with temperaments or octaves.  And I always do a critical but holistic listening at the end to see how the piano presents. Aural skills are importance too,  as I mentioned.
    BTW all tunings I do are two pass tunings so after the first pass I'll listen generally to octaves to see if the stretch is ok for me.  If I detect too much movement I correct that on the second pass but rarely does that encompass the whole piano.  Most often it's in the tenor bass transition.  I hardly ever, if ever, find problems in the temperament octave that aren't my fault for missing the target.  That could happen either way.
     And then there's another aspect to this that I've wondered about.  No question I can do a tuning with an ETD that also includes pitch corrections in about half the time of an aural tuning if I'm really trying to be precise (I use RCT fwiw). And probably even faster in the case of extreme pitch corrections.  So if a customer is paying for my time, and in 90 minutes, with an ETD, I can do a tuning with pitch correction and still have 45 minutes left to touch up the voicing, check some aspect of the regulation, lubricate the action, adjust the pedals and do a minor cleaning, do I tell them, "well I really like to tune aurally but it takes me twice as long so I won't be able to do those other things but you still owe me for a 90 minute appointment." What is our obligation to the customer in terms of providing the best service possible if that includes the use of technology against our personal preferences?
    The fact is, my prices are fairly high but I get a lot done and part of that is because I treat this like a business to deliver the best and most comprehensive  service consistently and not a hobby where my goal is to satisfy my own personal preferences and stubborn beliefs.  That might seem harsh but it's worked well for me in one of the most expensive cities in the world.  But this is another topic, I suppose.
  • 59.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-19-2024 16:50
    Unlike David, I generally tune (or at least check) all three strings of the unison using the ETD for reference, with the aim of more securely being able to guarantee stability. Feeling the pin, watching the display move, adjusting the lean of the pin so that pitch follows the pin (when the pin starts to move in the block, pitch starts to change), and challenging pitch in both directions when I am spot on, wanting to see barely discernible movement sharp and flat when I twist/flex the pin in either direction. When the pins/strings are behaving nicely (meaning no bearing friction problems, and pin moving smoothly in the block), I may do the unisons aurally, but when it becomes difficult to get the final polish, I simply do all of them to the display. This almost always happens by C5 or so.
    Of course, the ear decides if the resultant unison is good. If it isn't, I mute each string in turn to see where the problem may be.
    I do one pass tuning, even for fairly large (~20¢, even 30¢ for particular notes/areas), using an offset I enter manually. I don't like the offsets any ETD sets, as it is too much for my tuning style: they assume you will roughly set the first string, then tune the remaining strings to it without reference to the display. But that defeats my purpose, which is to use the display to achieve far better stability than I can get without it. I set about a 20% overpull. I started doing this while doing mass pitch changes seasonally at the university. I found two passes was simply too much stress on the aging system (my body and soul), and I found I really didn't need to do much on the second pass. So I wondered if I could nail the tuning in one. I was pleasantly surprised that, yes, I could.
    For large pitch changes, I move the first string a little beyond my target (set to 20% overpull), tune the middle string quickly/aurally/roughly to that, then tune the third string quite carefully. I now refine the first two strings I previously roughed in. It took some practice to get good at it, but it was well worth the trouble.
    This is just to give the perspective that there is no law, physical or moral, that says you have to tune your unisons "entirely by ear." You do have to listen, and decide whether they sound good enough (and my standards are VERY high), but how you get there is negotiable.
    BTW, even badly mismatched bichords can benefit from use of the ETD. When faced with one, after having tuned so that the two strings claim to be in tune according to the display (IOW the partial being read is matched), I set the display up an octave and play each string. This reads a higher coincident partial. Invariably the two strings give obviously different readings at this partial. I triangulate, raising one and lowering the other to come closer to matching at this higher partial. I listen and decide. (This may be troublesome on some apps, requiring you to turn off automatic note changing, and I'm not sure to what extent they are listening to a single partial).
    I find this can be faster than trying to decide entirely by listening, as I find it psychologically difficult to accept the compromise: it;s getting better, and then its getting worse but better in a different way. Having some objective data makes it easier to say "That is good enough."
    fssturm@unm.edu
  • 60.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-19-2024 18:44
    Whether or not I had a bad day today or whether I was spending too much time making a video rather than giving to focus to the instrument, I don't know, or perhaps it's because it was a Steinwas with replaced wrest plank, tuning pins leaning towards the agraffes, and anything else that might have happened in the rebuild . . . but the result wasn't my normal concert standard. If I can't cope with an instrument, it's my fault, not the instrument's. However, it's a practice rather than a concert instrument and the video demonstrates
    - possible stability one can expect over a year
    - Weinrich effect and
    - futility of measuring down to the last 1/10 of a cent as the instrument varies
    Perhaps it's because every instrument one meets is different and next time I'll have got to know it better . . . and possibly I should shim up those unisons to get them to pitch . . . but perhaps the video might demonstrate a few things that others experience - and if anyone wants to say that it demonstrates good reason why I should fail a PTG exam on this occasion I'll agree with them. Perhaps this is not how to tune a piano.
    To save time
    00:00 Introduction 01:03 Stability after a year and demonstration 01:25 The Unequal Temperament 04:30 Resonating 05:06 Weinrich effect 08:16 Tuning many of the notes and using a phase display ETD 16:59 Hammer technique 18:46 Indication of faulty unison 19:53 A note that just can't be perfect 26:42 The result 27:04 Frustration 30:55 Final test 34:39 Is it musical?
  • 61.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-19-2024 19:56
    This is a little tangential  but forward looking.
    Fred's detailed description of the mechanical process of tuning a string makes clear that to a very large extent what we are talking about for practical purposes is manipulating the tuning pin. The overriding concern when placing the pitch is getting it to stay there.
    At the convention, Larry Lobel gave a seminar on Pianos Without Pinblocks. He outlined the many designs implemented from the 1850's up into the 20th century in addition to the M&H screw stringer that many of us are familiar with. And many of these designs worked, in fact, there are screw stringers still in use today and I met some technicians that are enthusiasts, seeking them out to service and in some cases buying them to sell and then service. They report that they often stay in tune significantly better than our traditional "pin in a plank" system. Indeed, I have often wondered why this, perhaps the oldest and most primitive piece of technology is still the industry standard. Surely some of the larger manufacturers have done the R&D, but have not elected to pursue it at this time. It's kind of a no-brainer. To date, it seems they have opted for hybrid, stringless pianos.
    Larry finished up his talk saying that often a technology will recur over long periods of time until it actually takes root. He gave the example of electric powered cars, which were successfully made at the dawn of the auto industry (I think he said 1,000 miles to a charge), only to disappear and reappear successively over the decades. And then he finished with a picture of a Tesla as an idea whose time has come. What he didn't mention is that the Tesla is expected to be self-operating within the next ten years.
    I bring this up because it should be recognized that we owe our bread and butter to this industry standard that is primitive, inherently unstable and requires a high level of technique to control.
    We periodically have these conversations, always educational, and always conclude with a fair amount of ambiguity. But perhaps we should count our blessing for that. 100 years hence, probably much sooner, pianos likely will be able to tune themselves, thank you very much. Given the longevity of existing pianos, we need not lose any sleep over it.
  • 62.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-19-2024 20:34
    Nice post by Fred here outlining his process. I agree with most of it even though I tune unison by ear. I have certainly tuned unison electronically, especially in noisy environments and it does take a lot of pressure off trying to hear through the noise. It can be very useful in churches with lots of reverberation, or with treble sections that have focus problems, and certainly in the high treble.
    I probably disagree with the pitch raise functions. I find using RCT that the smart tune function works extremely well whether you're tuning unisons aurally or electronically. I rarely find a major discrepancy event with larger corrections. Of course, beyond a certain point I think it makes more sense to just do a very quick pass to get the piano at pitch and then do the fine tuning later.  In part that's because of the phenomenon of just noticeable difference, which can be best described as the narrower  the field the more you can discern small differences within that field.
    It does bring to mind one other issue, though. I've often wondered how I would teach tuning if I were to do so. The old adage is, unisons are the first thing we learn and the last thing we master. I would change that say that stability is the first thing we should learn and is probably the last thing we master. For that purpose I think ETDs have a really important role in giving us spontaneous feedback on stability as Fred outlined in his post. Without stability there isn't much point in learning to hear beats, to tune narrow fifths, wide fourths, octaves of various widths, contiguous thirds, etc. If you don't know if the tuning is staying where you put it, it doesn't really much matter whether you can hear it.
  • 63.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-19-2024 22:00
    I probably didn't state the reason the RCT (and other) pitch rate offsets don't work for me with enough clarity. They assume pitch will change while you tune the unison, and they are correct. As the pitch is changing, you can no longer use the device's target pitch as your guide to achieving stability. Which is why I need a smaller offset.
    When I do one pass pitch raises, I am essentially doing two passes, but doing them all at once. I expect my first two strings to sink or rise (depending on the direction of the change, and the largest of my pitch changes were lowering pitch in the fall before classes, so rising was pretty normal) while I am tuning the subsequent strings. So one quick pass on the first two strings, then a second precise pass on the full unison. I couldn't have predicted it would work as well as it does. It doesn't fit with what everyone says is going on.
    Doing that based on the offset pitch created by the ETD would consistently leave me a couple cents beyond pitch. So I experimented with just how much offset would leave me at pitch, using my own technique.
    Perhaps it's not for everybody. I know that I kind of had two modes of hammer technique, one for large pitch change and one for fine tuning. Trying to combine them right next to one another was a learning curve, but well worth learning.
    Al Sanderson speculated that the major reason for pitch drift during a large pitch change is actually to be found in the plate. Over the years, I have come to think he had it right. It is similar to what happens when a string breaks. The immediate neighboring strings go sharp. Replace the string and pull it to pitch, and the neighboring strings go back to pitch. It's a very localized thing. Counterintuitive, I know. "Everybody knows" it has to be mostly the soundboard, the pin block, some big wooden parts. Maybe not.
    In any case, I think that this may at least partially explain why my technique works. Much of the settling of pitch is localized and plate related. Subsequent tuning of the rest of the piano doesn't disturb the unisons (at least not for most purposes), and in my experience tunings done that way lasted quite well for the couple months before I got back to the pianos.
    fssturm@unm.edu
    www.artoftuning.com
    "Tradition is not the worship of ashes, but the preservation of fire." -Gustav Mahler
  • 64.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-19-2024 22:52
    Fred,
    This leaves me wondering if an ETD couldn't let you have your cake and eat it too, so to speak. What if one offered, for example, two indicators at the same time during an overpull -- one that showed the overpull target for the first string of the unison, and another that showed the final target for the open unison, presumably with a much milder overpull?
    For example in TuneLab that might have two phase displays at once, or even just an extra line on the spectrum display indicating the secondary target...
    I've sometimes found myself wishing for something like that. Maybe if enough people are interested we could pitch the idea to one of the developers...
    Nathan Monteleone RPT
    Fort Worth TX
    (817) 675-9494
    nbmont@gmail.com
  • 65.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-19-2024 23:27
    Nathan,
    You do need to do an overpull when doing a large pitch change. The pitch will continue to change after you fine tune each unison. But the overpull from having tuned all three strings is less than the one preferred by ETD programmers (and which seems to work well for most). There is sometimes an option to modify the overpull, which could solve the problem depending on the ETD.
    I find it simpler on RCT to just observe the spinner relative to target, which tells me roughly how far off the pitch is, and then enter my own offset number, generally 20% of the pitch change (none for the bass). And I modify as I go (the degree of pitch change varies quite a bit depending where you are in the scale).
    fssturm@unm.edu
    www.artoftuning.com
  • 66.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 11:01
    Fred,
    Understood.  And of course there's nothing wrong with just eyeballing the change...
    But It seems like it would be really quite simple (with maybe a little experimentation) for an ETD to calculate _both_ overpull offsets -- single string and final unison -- and at least display the latter some kind of way.  Right?  I know I would use it.
    Fort Worth TX
    (817) 675-9494
    nbmont@gmail.com
  • 67.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 11:35
    I see what you mean.  A second offset, not one offset and the final target pitch. But the offset needs to be THE target in order to use it as an aid in achieving stability. IOW, it has to be the pitch on the basis of which the ETD is generating real time, analysis of where you are.
    So a better option, from my point of view, would be to provide a choice between two styles of offset.
  • 68.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 14:23
    Oh, good point.  I agree, for your workflow it would be best for the final (unison) offset to drive the indicators (spinner / phase display / spectrum / whatever, depending on the ETD), and just display the initial single string overpull as a number in cents.
    Fort Worth TX
    (817) 675-9494
    nbmont@gmail.com
  • 69.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 14:52
    One of our members in the Montreal Chapter (our new RPT Émile Beaudet) asked the Tunelabs developer, and apparently, the recommended pitch of the first string is set with the understanding that it will drop as the other strings are brought up. The final pitch should be accurate, even if it currently appears lower than the initial pitch raise target.
    I was surprised to learn that...
    Allan Sutton, m.mus. RPT, TEC
  • 70.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 15:22
    Allan -- Yep that's correct!  I was brainstorming as to whether a second offset indicating the final target, would be useful :)
    Fort Worth TX
    (817) 675-9494
    nbmont@gmail.com
  • 71.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 15:58
    There is another aspect to this that we haven't really discussed, and that is the coefficient of friction at the hitch pin. Because there's another phenomenon that takes place and that is when you're pulling the pitch up quite a ways on a string that has a partnered speaking length, you are actually increasing tension on that other speaking length. That change will probably depend on the coefficient friction at the hitch pin and the degree, to which you are changing the pitch.
    So I was experimenting with your (Fred's) system on a Bechstein that I was tuning today and when I tuned every string in the bass that was about 8c flat, I noticed very little change in the pitch of the first string tuned after tuning the second. In the mid range, which was marginally flat, I also noticed very little change if any on the first string tuned after tuning the other two strings in the unison. However, in the table where the pitch was 20-25c flat, when I tuned the first string and then the other two and went back and measured the first string, it had actually  gone sharp!  And that was only the case where the first string tuned shared a speaking length on the other side of the hitch pin. Clearly the coefficient of friction was not sufficient for that level of pitch change to prevent tension from rising in the partner speaking length.
    What's clear in all this is there are a number of factors conspiring against us to affect stability and I don't think we can make any simple assumptions that it's only one thing that's impacting stability.
  • 72.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 16:25
    ...What's clear in all this is there are a number of factors conspiring against us to affect stability and I don't think we can make any simple assumptions that it's only one thing that's impacting stability.
    Yes, I suppose that's why these discussions tend to get so murky. Really good point about the hitch pins, I always find pianos that tie off all the strings to be more stable, short and long term. As to Fred's notion about pitches falling quickly enough to skew the unison tunings, I've found that to be true inconsistently from piano to piano, perhaps it's the "hitch pin friction" that is determinant. Also Fred seems to say that a lot of his pitch changes are lowering the pitch, something I rarely encounter but pianos do not seem to respond to lowering in the same way as raising, especially in regard to overall targets. A good pounding in between passes seems to help.
    Btw, for some reason, in the last 10 years or so I've run into some Asian pianos where, when doing a 20 cent or more pitch raise, the area between about A4 and the treble break either doesn't go down at all from my over pull or actually goes higher than where I set it by the time I've finished my first pass. I don't think it is the result of faulty sampling as it is often in the range of 4-6 cents. (the over pull presets I use are at the upper end of what is recommended.)
  • 73.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 18:06
    Stephen,
    Yes there are outliers that behave weirdly. I have found Steinway uprights to be some of the worst offenders. I would use the built in pitch raise function starting at 25-40¢ flat, and it would create an offset in perhaps the 8 - 10¢ range. When I was done, I had to lower pitch by 15¢ (these are rough approximations, but you get the idea - it ended up higher than the offset). I stopped using any pitch offset for Steinway uprights, and problem was solved. Going over it a second time without offset was fine touch up, not another major pitch change.
    I am skeptical of creep around hitch pins occurring in the normal ranges of pitch change. Maybe with 100¢ and more. Lower pitch on a string and observe how far it has to go before the string sharing the hitch goes flat. Do the same for raising pitch. I think you'll find it takes a pretty drastic change in tension. The strings have to creep through/around the bridge pins as well.
    You're lucky not to have much pitch lowering to do. Seasonal swings of RH rising from 10% to 60% is what does it here in NM. It's worst in the institutional setting, where air exchange is so rapid.
    "I am only interested in music that is better than it can be played." Schnabel
  • 74.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 20:22
    I would agree that hitch pin creep is unusual but it seems likely that's what was happening today on the piano was tuning. One thing is certain, The pitch was not going flat.  There may be something in the design of those hitchpins or the angle or something that allows that to happen more on that piano than on other piano because I don't generally experience that, but in this case I did for whatever reason.
    It's not really hard to test that by the way, just set a string on one side of the hitch pen with a measuring device and start moving the other string and five cent increments then go back and test each time and see if there's any creep at all it doesn't have to be a lot.  See if a trend can be established.
    by the way, I agree with Stephen on many of his points the  least of which not being that there is a reluctance to abandon the analog methods--a kind of sentimentality that doesn't seem all that grounded in reality.
  • 75.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 16:57
    I have observed with TuneLab pitch raises that the first string usually starts to drop when strings 2 and 3 are brought up. So, I tune one string to the ETD and then make a good unison, knowing that it is changing immediately as more pressure is added to the bridge. Starting with A0 and proceeding to C8, when I get to the plain wire my method is this:
    1. Rubber mute between strings 2/3. Tune string 1 to ETD.
    2. Move mute to right side of string 3. By ear, tune string 2 to match string 1. Ignore the ETD.
    3. Move mute to left side of string 1. By ear, tune string 3 to match string 2.
    4. Check the three strings together while moving the mute to next set of 3. If it's not quiet, bring back the mute and identify which string is out of sync with the other 2 and fix it, regardless of the ETD. Get the unison clean wherever it is.
    Then proceed with the next note.
    Jason Kanter
    Lynnwood WA
    (425) 830-1561
  • 76.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-19-2024 23:32
    I agree with the plate contraction theory and have gotten push back on that for years.  Arguments in the past have put the emphasis on soundboard crown compression. I've never bought that since pianos with no crown react the same way as those with crown.
    I think our experiences are different when it comes to pitch correction and I can't explain why since we both use the same device, it appears. But something that doesn't quite make sense to me is that if you're  tuning each string of the unison separately and to the device, and the pitch on the previously tuned strings is changing as you tune each subsequent string, then the first string you tuned would end up flatter than the last string.
    When you look at the over pull numbers that are displayed on the RCT they not only vary considerably between sections but  within sections as well when you approach the struts. Moreover, pianos that are off pitch most often are off to a greater or lesser degree between sections. So while the RCT accounts for that by the trailing average function, using a flat 20% doesn't seem to compute, or I'm not understanding the method.
    FWIW I have not found any difference for normal range pitch corrections between tuning unisons aurally or with the ETD. I would say that's true up to about 25 cents correction certainly. Beyond that I'm usually doing a quick first pass.
  • 77.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 01:30
    Let me just add, Fred, that one reason I'm dubious of the theory of tuning single strings with the ETD method requires compensation for the effect on the other strings is that in a typical piano, increasing the pitch, say from 435 to 440, only adds about 3 lbs of tension to a single string of the unison (calc'd at C4at 152lbs per string and according to my scaling spreadsheet), 9 lbs for the entire three-string unison.  You could add that much pressure by simply pressing on the string seemingly without any measurable effect on plate contraction meaning no appreciable change in pitch of the strings already tuned.  When a string breaks it is an order of magnitude different as you are experiencing a sudden loss of tension of around 300 lbs (two strings at 150lbs each, so a change in plate contraction there makes more sense and we do see the adjacent strings go sharp. Otherwise, it's a pretty small fraction.  (For those who argue it's crown compression that's even less change since the change is then a function of the change in tension * the sin of the angle of downbearing.  A very marginal difference.)
    I think something else is at play here and I am not convinced that tuning unisons aurally verses electronically yields any difference.  Having done unisons both ways with RCT I have not seen that.  Over the entire piano, of course, 3 lbs over 236 strings in a normal 20 bass piano is 708 lbs.  That is significant in terms of plate contraction.  But in a three-string unison we're talking about ~1.5% of that and for each string about .5%.  I suppose if you are doing very large pitch corrections, say from 410H to 440H where each single string is increasing by 20 lbs or more, it could make a difference, especially when you consider the adjacent note often shares a string with its neighbor.  But I would never attempt a single pass tuning in that situation unless I wasn't concerned with the outcome.
    Just FWIW RCT doesn't recommend single pass tunings using smart tune of more than 10c (if I recall correctly--though I've done single pass pitch corrections with double that change) but I don't recall them indicating that aural tuning of unisons yields a different result than tuning each string with their device.  Perhaps they can clarify.  I would guess they have tested that.  Maybe Dean can weigh in.
  • 78.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 08:07
    From what I am reading, I would categorize Fred's approach here as a "quasi-analog" technique. In essence he is telling his digital assistant: "I don't want you to make all my decisions for me...just get me into the ballpark, and I'll take it from there". I find this to be a very good (and brain-preserving) approach. It is comparative (analog). I like it it.
  • 79.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 11:49
    With a pitch change of 20¢ or so, if you tune one string of the unison very precisely and with good stability to a target pitch, then tune each other string of the unison individually to the same target pitch, then play the unison, you will discover it isn't very good. Why? Because the first string you tuned will have moved. Why? I speculate it is because of the plate. We're talking about a cent or two, not the 25-50¢ when a string breaks.
    So for a largish pitch change, I rough tune the first two strings, then fine tune the third string, then fine tune each of the first two strings to the target pitch. Now I have a clean, stable unison.
    Tuning one string to a target, then aurally tuning the other two strings to the first, your target string will be changing while you are tuning the second and third strings, and your unison will be flatter or sharper than the ETD target.
    That's why I need a smaller offset to tune all three strings to the ETD. It does require going back over each string. OTOH, I have been able to verify that each of the strings is stable, as stable as I can make it.
    Does that clarify things?
    "Travel is fatal to prejudice, bigotry, and narrow-mindedness." Twain
  • 80.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 12:51
    Fred, I understand what you're saying but it hasn't really been my experience when tuning each string separately with the ETD. Admittedly I don't count on a 20c pitch correction to be satisfactory with a single pass so we probably work differently there. But 10c or less, whether I tune unisons aurally or with the ETD I'm hearing unisons just as tight. As I said, though, I always do a second pass to check unisons. I don't necessarily put the tuning hammer on each pin but I'm certainly listening for small discrepancies.
    And then the other question is why do it your way?  It seems that for the sake of being able to tune each string separately with the etd it's a lot of extra work.
    Of course I don't begrudge anybody working however they want. I'm just wondering what is the benefit, other than being able to raise the level of attenuation with hearing protection, not  a small consideration
    I will add that I've gone through a couple of different devices, now many years ago, starting with SAT and then Verituner before settling on RCT. And a lot of the reason that I settled on RCT was their pitch raise  function, which I find  superior to anyone else's. The Verituner does allow you to pre-program different over pull percentages in each section which I tried but because of the way RCT uses trailing averages it wasn't as effective or I didn't work hard enough to get the right percentages without that particular trailing average feature. I think I got the RCT originally when I started doing some institutional work and had lots of pianos  to do and didn't want to have to be bothered with pitch corrections and doing two pass tunings. So RCT allowed me to basically do a one pass tuning on these institutional instruments and made the time, extremely consistent no matter how far out the piano was really.
  • 81.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 13:11
    Let me also say, Fred, that I'm not meaning to challenge how you work, we all find our own way in this process and invariably there will be slightly different approaches.  Where we do agree, and this is applicable to the subject line, is that ETDs are capable of delivering extremely high quality tunings as good, if not better, than aural tuning, with less stress on the ears, on the brain and, for me, a distinct time advantage.  The reluctance to embrace these tools I find somewhat baffling especially when arguments are presented that the aural tunings will be better for whatever reason.  I can't help but think this is clinging to the past a bit and/or not understanding how the devices work exactly, or how to use them properly.  In fact, my experience is that the current devices deliver more consistent results and I say that as one who sometimes follows aural tuners for various reasons and as someone who developed a high level of aural tuning skills before purchasing my first device.
    But, to my earlier point, everyone has their preferences, and I certainly don't begrudge anyone from clinging to the style and method they choose.  Where I do object is the attempt to denigrate technology advancement as somehow inferior.  I think that's self-defeating and perhaps it's driven by this fear of the loss of the "art" of what we do.  I think there's still plenty of room for that even as we make greater use of technology,.  That's true not just for tuning but in every other avenue where increasing sophistication in tools and methods has yielded better results and in which we seem to find no objection.
    Now let's talk about voicing--there, the technology has not caught up with the art, IMO.
  • 82.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 16:20
    We are definitely mostly on the same page here.
    My first response on this thread was aimed at moving beyond the notion that the calculated tuning templates of quality ETDs are somehow defective, and so we have to check them aurally. Frankly, I believe that attitude arises from decades-old prejudices, some of which were originally well taken (eg, with respect to tuning to the Conn Stroboscope or Peterson Scope without any stretch, and only with reference to first partials). But that is truly ancient history, even if it is within the memory of those of us pushing our way into our eighth decades.
    There is a lot of mystery and wonder in the initial approach to aural tuning, in the magic of figuring out the relationships between intervals and approaching the creation of a perfect web of pitches. Having devoted oneself (as I did for 15 years) to developing those skills, it is surprising and perhaps devastating to find out that the same and better results can be achieved so much more easily and efficiently by using technology. Kind of like going from being a whiz at a slide rule, and along comes the electronic calculator (not to mention the supercomputer - one of which is possessed by each of us in our phone).
    In any case, the real puzzle before us is how to teach tuning today. What actually makes sense? I believe we need to teach aural discernment, and Jason Kanter of the education committee is hard at work creating ways to develop those aural skills. See https://my.ptg.org/ptgeducation/discover-more/modules for some of the earlier modules. More and improved versions have been made, but we are working on technical issues connected with presenting them directly on the web rather than through the Articulate review site.
    We also need a way to teach how and why to use the various customizing settings on various ETDs, as in setting stretch, for instance. And that is problematic, because rarely is anyone proficient at more than one ETD. The developers are typically very helpful, but many aren't actually piano tuners.
    Reading and interpreting displays is a challenging skill. This is because it is quite challenging for the software involved to interpret the aural data in an accurate and consistent way, due to the fact that this aural data turns out to be less consistent as you focus in on more and more accuracy. Each display has its own quirks. Customizing can smooth the display, but at the expense of immediacy and precision. How is the novice to figure this kind of thing out?
    fssturm@unm.edu
    www.artoftuning.com
    "All of humanity's problems stem from man's inability to sit quietly in a room alone. " Blaise Pascal
  • 83.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 17:40
    Yes indeed. And don't forget hammer technique. Without stability the rest of it doesn't mean so much!
  • 84.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 13:23
    It's a question not so much of verifying pitch as of verifying stability. If I manipulate the tuning pin using the ETD display, I have considerably more confidence in exactly where the pin/wire/pitch are relative to one another than if I do the unisons aurally. It isn't a matter of what I hear at that moment. It's a matter of feeling secure that it will stay no matter what. And for that to work, you need to be aiming at the target being asked for by the ETD.
    When everything is behaving nicely, no problem doing it aurally. When there are little glitches, like the pin doesn't want to move a tiny amount from a particular spot but instead wants to jump, or there is significant friction so that when turning the pin in the flat direction (even with the help of flex and twist) the pitch isn't following, that's when I find it essential to do each pin/string separately.
    It's really just the final polish: "Sounds good, but is it going to stay?" That is why when I started tuning with an ETD (initially SAT), I never looked back (though I modified what the SAT calculated): It was the ability to achieve far more precision far more efficiently, and have assurance of stability. The ability to make a 0.3¢ or less change and know you had made it so it would stay. I couldn't do that aurally, or certainly not with the same degree of assurance.
    fssturm@unm.edu
    "Education is not preparation for life; education is life itself." John Dewey
  • 85.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 17:46
    Some reasons we have so much diversity of 'opinion' on tuning and the use of ETD's and scientific devices vs human tuning perception:
    We have no universally agreed standards for how to measure tuning frequency. This is because we hold many ideas that long outlived their time and are now verified scientifically and should be universally 'convincing,' having huge consequences on the outcome of tuning, such as:
    1) Not understanding that we cannot measure 'frequency' instantaneously, but need a defined window of time.
    2) Not agreeing that the piano sound is a moving target of frequency (non-stationary) wherein the partials are all constantly moving up or down somewhat independently over time after the attack, and enough that it makes a difference in measurement choices.
    3) Not agreeing on the fact that piano music moves quickly even in slow moving passages, giving credence to tuning in the first second of time window after the attack, but instead tuning with the long delay (a few seconds later) measurement after the attack when the piano pitch has moved significantly enough to make the attack out of tune and when the amplitude is 40 dB (100x) lower in amplitude. Why? This is an old disagreement and there are two camps and yet we can't agree, still? Because until we had better scientific equipment we could not measure fractions of a cent differences in the first one second time window. That is a 'fact.' Now we can.
    4) Not agreeing whether 'input devices' (mics, sensors, and human ears) give different frequency measurements based on spatial position or proximity.
    5) Hanging onto older ETD's that have long out-lived their time and pre-date modern signal processing algorithms that the engineering community has universally adopted in all modern technology. Not understanding that it really makes a huge difference in the outcome.
    6) Resistance to scientific and engineering knowledge that would produce superior tunings, but hanging onto ad hoc methods with a lack of willingness to change, because "… my customers like my tuning after 40 years and why would I want to change now…"
    7) Pride in the Artistic aspects of the tuner: "My ears are my ultimate measure." Well, what about your colleague's ears, what if he/she hears it differently, is there any such thing as an 'ultimate' then? Of course not!
    A final thought: Gary Kasparov was the world's greatest chess player, and he could beat chess computer programs until about the year 2006, at which time IBM-Deep-Blue exceeded him and all others. Today, with iPhones that can compute billions of operations per second, an iPhone chess program can beat any human chess player easily. Has that day come now to piano tuning? If not, then soon? Will we live to see this transition? Will the current generation who uphold the traditions of aural and artistic tuning need to retire before we see a younger generation make this happen?
    Steven Norsworthy
    Steven Norsworthy
    CEO/President
    RF2BITS, Inc.
    Cardiff CA
    619-964-0101
    steven@rf2bits.com
    http://RF2BITS.com
    http://PianoSens.com
    https://www.youtube.com/@PianoSens-ey8jb/videos
    https://www.facebook.com/profile.php?id=61554763029258
    https://scholar.google.com/citations?user=vFTmO6IAAAAJ&hl=en
  • 86.  RE: ETD Discrepancies and limits of accuracy
    Posted 08-20-2024 11:33
    "I know that I kind of had two modes of hammer technique, one for large pitch change and one for fine tuning. Trying to combine them right next to one another was a learning curve, but well worth learning."
    In the video https://www.youtube.com/watch?v=9DmcV-_FHbk (broken down into sections) I've covered many of the ETD issues of limits of accuracy, and on this instrument tuning each string by ETD or one string by ETD and the other two aurally and assuming that the Weinrich effect gives even drop. Perhaps on another occasion I'll shim the note up to get the notes properly up to pitch but think that the top three octave treble I experienced here was using a hammer technique that didn't take the friction points into account in the treble.
    Yes, different hammer techniques are appropriate for large pitch change and for fine tuning, except where there's a duplex scale one should use the technique that friction is broken for fine movements.
    I put the video together as an example of working with imperfect result there in the treble as a potential help to others with pitfalls to avoid. People familiar with my concert videos know my standard of tuning but doing a video of tuning getting it right isn't really helpful. It means that we've got it right intuitively and as a result of experience which perhaps won't help others getting it right but documenting a less than happy result might help others to be getting it better.
    In what situations does working with an ETD enable us to overcome physical limitations on achievement of accuracy?
