I have used the products from this company when I needed to identify mold / mildews on the beams and plate of a Yamaha C7. They will also provide free consultation and referrals to professionals. It would be an excellent idea to install data loggers that will continuously monitor temp and rh as well as dew point
24 hours a day. The loggers can be set to send alarms out when the temp and rh are above or below the limits you set. Plugging the loggers into a computer can chart out all of the info collected and show graphs of what really happens in the wee hours or how big swings in the weather change the environment . I believe that loggers now are bluetooth capable and can transfer data to a smart phone or laptop app
Sent: 03-05-2023 11:09
Subject: Help! Moldy Steinway D in concert hall with little time.
The venue would putting you and others at risk if they insist on going through with this. The professional thing to do is advise and decline.
Sent: 03-05-2023 10:15
The last two posts should convince you to step away. Recommend a rental, take pictures, write a report. Yes we all feel an attachment to loyal customers but your health and the health of others is more important. Even if you could treat the visible mold too much is unknown. I am willing to bet that many things in this piano are compromised especially hammer felt glue joints, keys, whippens, perhaps rusted strings, tight damper guide rail bushings. If the pianist puts the piano through its paces it will be sending spores all over the venue and hammers are likely to unravel. This piano is an insurance claim . The venue should have had a better system, of monitoring with alarms, weekly inspections, preventive maintenance. I have had several church clients that neglected their C7 Yamahas . Two cases involved underpowered , old ac equipment. Another church shut off the ac in the summer for 3 months to pull up and replace the carpets. A church had brrn hit by a lightening bolt on the steeple and wiring throughout got fried. To save money they hired a handman who replaced the ac thermostat with an off/on switch. Carpet , seating, instruments including the C7 suffered big time. Many choir members got sick from the mold and dampness. I had to put a new top stack in and major work mating hammers, papering flanges, regulation, easing keys.
Sent: 03-05-2023 08:47
Tim,
I am not as experienced as many here with mold, but I will add my two cents. I have tuned my fair share of musty pianos, being in central NC and having fairly high humidity to deal with a lot of the time.
But there is one memory that sticks out to me regarding the dangers of tuning moldy pianos.
I was tuning for an elderly woman and her childhood piano. I opened it up and the hammers were evenly and completely lined with lightly fuzzy white mold. I thought the same as you - well, this isn't the dangerous kind so I guess I will proceed with the tuning.
I have asthma, well-controlled, only flares up when I am sick and have allergy issues (seasonal environmental allergies) - I wouldn't classify it as severe.
Halfway through the bass my lungs started to protest, and by the midway point of the pitch correction I had to take my emergency inhaler because I was starting to have trouble breathing.
I hardly ever take that inhaler - maybe 3-4 times a year. Thankfully I had a good quality mask in my car, and i wore that for the duration of the tuning.
If asked, I would not tune that piano again. And it has made me think twice about a few pianos since.
We never know what health conditions a pianist may or may not have, and asthma is very common. If you need to share this anecdote with the concert venue as a reason for caution, I don't mind.
Mold is so dangerous and I fear that we often underestimate the white and green versions.
I hope it goes okay and that they will listen and respect your expertise!
All the best,
- Hannah J.
Hannah Jones
Joyful Noise Piano Service
Siler City, NC
336-609-4029
joyfulnoisepianoservice@gmail.com
"Make a joyful noise unto the Lord, all the earth!" - Psalm 100:1
Sent: 03-04-2023 19:00
Wow!?? So much to digest here.?? I will examine the piano on Tuesday and make a decision.?? If black mold is present, I'll decline to work on it until remediated.?? If it mostly just cosmetic "white" or "green" mold, I may see what I can do with it.??
It's my understanding that some black molds are toxic, but not all.?? If that's present I'll want it evaluated by a pro before continuing to service that piano.??
Thanks everyone!
-- Tim Edwards, Piano Technician 740-593-3998 Piano Tuning and Repair since 1977 timdepianoman@gmail.com
Sent: 3/4/2023 4:03:00 PM
Subject: RE: Help! Moldy Steinway D in concert hall with little time.
I will repeat my message They need to rent. Using this instrument is too dangerous to everyone including you and the artist. I believe this artist played an outdoor concert here on a rented instrument . Every time the hammers move they will throw off mold spores. Who knows what will get released or transferred when you tune it , play test blows etc. When we had severe flooding of the rivers here away from the coast I did several inspections of pianos that had been in flooded homes. A large upright had so much moisture in the hammers that the mechanical moisture meters showed 100 % on the meter; same thing with the electronic digital meters. It had been in a moisture laden home where water had risen to the pedals and bottom board A grand piano in another town had been sitting in standing water halfway up the legs. 3/4 of the hammers had peeled off there cores and it too had high moisture readings in the action . each piano had little to no visible mold but it was probably starting. All new hammers shanks and flanges where installed but the customer did not want to go for whippens despite my recommendation to replace them All that moisture had really affected the action centers. Just lay it out and refuse to take the job
Sent: 03-04-2023 12:57
There are times when the most profitable thing we can do is to refuse a job. I would tell them the piano is not usable in this time frame, and may never be. The risk will be either to one's relationship with the account or to one's lungs and health. Not much of a decision imho.
Sent: 3/4/2023 9:15:00 AM
I agree that mold is not something to be taken lightly. Depending on how much is inside the piano, it might be worth getting a company like Servpro to evaluate the piano. If this mold is inside the action parts and on the soundboard under the plate, you might want to recommend a complete rebuild. If it can be proven that the failure of the DC system was due to an electrical problem, insurance might pay for it.
Sent: 3/4/2023 8:43:00 AM
PPS! I JUST learned that grain alcohol can encourage growth with certain types of mold! Dag-nabbit!!! Back to other alcohols, peroxide & Scott's Outdoor Cleaner. I have used the latter on all kinds of surfaces, incliding books, various finishes, & raw fingerboards, without any discoloration. Also works on laundry. LOL!
PPPS: I really hate mold. It's everywhere here. Sometimes you can even smell it outside when you get out of your car after breathing cleaner air through your car air filter. 😒
Maggie Jusiel, RPT
Athens, WV
(304)952-8615
mags@timandmaggie.net
Sent: 03-04-2023 08:34
PS: I have used Scott's Outdoor Cleaner, peroxide based, on my personal instruments with great success & with the mold either not returning at all or returning much later than with other products. I haven't used it on a good piano, though.
Wim: Bleach has been proven to encourage mold growth in the long run on porous surfaces. Works great on non porous surfaces, though. 😉
Maggie Jusiel, RPT
Athens, WV
(304)952-8615
Sent: 03-04-2023 08:26
The first question is, did they plug the DC back in, or is it still out?
Removing the mold might not be the hardest part. Yes, it will take time. (use a bleach product). The bigger concern is the tuning stability. As I asked, has the DC problem been solved? If not, you might have a hard time keeping the piano in tune.
Is there any way you can have access to the piano other than the day before your doctors appointment? Can you get in there over the weekend?
That's my recommendation.
