I've used Paraloid B-72 quite a bit and never had any of the symptoms you describe. It's worked great for me, excellent results and very controllable. Wonder if you got a bad batch? Or perhaps it wasn't applied as per the instructions, or the ratio was off? I don't know. This is the first time I've heard of someone getting the results you got with B-72.
Sent: 08-30-2025 14:43
Subject: Lacquer suggestions for hammer voicing
To those using B-72 go back and check your work. Stick a single needle in the hammers and check for gummed up hammers. It horrible stuff!! I did just that today. I was told it had only one application of B-72 and they felt like gummy rocks with no give. It perfectly explained the tone when first heard the piano. Bright, tinny and thin. The hammers did not have any give on the squeeze test. I ended up needling the shoulders from 9-3 with a 4 needle tool about 30 strikes per side just to get back rubber ball feel. So I must have Made the Piano Great Again, because the piano owner couldn't stop playing.
Say no to that B-72 urge. I'm dumping all of mine out.
Sent: 08-30-2025 14:21
I won't mention any names, but someone likes to read between the lines of my text and comment on what i didn't write. Hilarious.
So, i did a deep dive on alcohol drawing moisture out of the air this morning. I watched the test that proves that alcohol is not hygroscopic. Alcohol absorbs water when it comes into contact with water, which is why its used to remove water from gasoline. The water gets into the gas because of condensation.
Poster Love, if you want to state that there is false labeling going on so you can come out right on the issue when your wrong that's on you. So most if not all those facts you copy and pasted from google are incorrect. Especially after its seen with thine own eyes.
Regardless, i use Lab grade 99.9% alcohol. Its real, its not false advertising. Unless you think the Labs are fake too. What must have gone over a few heads is what i said ealier "you can see the faster absorption with the 99.9%". Now it makes more sense.
Sent: 08-30-2025 12:04
I don't think that's a problem Richard. I was responding to the statement that you don't want any water in the solutions that you're dissolving shellac with. I was just pointing out that there is a little bit of water in those solutions anyway and it doesn't seem to have a negative effect on the use of shellac. It was more a point of clarification than condemnation. Products like Everclear are stable at 95% if stored properly and there's a reason that 95% figure exists in this case. It kind of reminds me of certified organic products. Things don't have to be 100% free of substances that might render them as technically not organic. But the certification and labeling process offers some leeway.
Chris and others prefer shellac and that's fine. It has its own properties. I think what this thread shows is that people have different ways and preferences for hardening hammers. I was just making a point of clarification about "pure" so called 100% ethanol. It ain't. But it's close.
Sent: 08-30-2025 11:47
So, is it safe to say that hygroscopic solvents could create unpredictable voicing solutions which would make them less desirable for that purpose?
Richard West
Sent: 8/30/2025 11:27:00 AM
Subject: RE: Lacquer suggestions for hammer voicing
Oh Chris, so desperate to express your contempt. Yes, they are all highly flammable. It was simply a warning in case folks were unaware. We don't usually worry about the flammability of bathroom alcohol (typically 20-30% water) and denatured alcohol has some other additives which are quite toxic, if folks are using that instead of lacquer thinner or acetone because due to toxicity concerns.
Ethanol is hygroscopic but even putting it in a sealed bottle will not protect it forever. Stability is achieved around 95% and that's where it inevitably ends up. But the word you're looking for is azeotropic. "Ethanol forms a positive azeotrope with water. The boiling point of a mixture of 95.6% ethanol (by weight) with 4.4% water is 78.1 °C, which is lower than the boiling point of pure water (100 °C) or pure ethanol (78.4 °C). Because the azeotropic mixture boils at a lower temperature, it is impossible to use simple distillation to produce ethanol at concentrations higher than 95.6%."
To produce actual anhydrous (that means without water) alcohol, a special techniques beyond simple distillation are required, things like molecular sieves. Even then you are only achieving about 99% purity and the stuff folks are buying for things like mixing shellac or dissolving B72 or making their Everclear-tonic cocktail are not that level of purity. Easy to find this info with a simple search.
So grain alcohol, like Everclear is first fermented to produce a relatively low alcohol wash and then distilled. Since the distillation process can't achieve a concentration of stronger than 95.6% that's what you get. I know it's probably comes as a shock that labels might misrepresent what's actually in the bottle.
Sent: 08-29-2025 13:56
Poster Love,
I'm not sure if you're joking again or not, but It's kind of a silly notion about alcohol's flammability when you compare it to acetone, lacquer and lacquer thinner which are not only flammable but explosive like gasoline.
Also the word is hygroscopic, and its easy to control by keeping it in a dry place as i do. One more thing about the 99.9% is that one can clearly see the superior absorption rate of it into the hammer felt, so at least you're starting with minimal water %. I think the quoted 5% is a guess with no proof. (pun intended.
Sent: 08-29-2025 12:32
Just a small follow up here, the Steinway hammer solution is available from Wurdack, They don't sell it in concentrated form anymore, it's premixed. I did just order some out of curiosity. They would not tell me what their formula is, understandably, it's proprietary.
By the way for those who are using shellac, there really is no such thing as 100% grain alcohol. It is sold that way, but it's virtually impossible to distill all of the water out of grain alcohol. So even what's represented as 100% is probably more like 95%. Of course it's extremely flammable and you want be very careful with it. Denatured alcohol is something a little bit different and often has other chemicals in it as well like benzene. Some of those additives iactually inhibit the flakes from dissolving to some degree so you might want to strain it if you're using that.
Sent: 08-29-2025 08:25
It was Fred Drashe who said that. I was actually in attendance in his class when he stated the reasoning.
Sent: 8/29/2025 1:05:00 AM
Eric Shandall, at a Steinway dealer get-together, related to us a story of someone asking a vintage technician, "When did you start using lacquer in hammers?" His reply was "When we ran out of shellac!"
Shellac and sanding sealer, my favorites. Keytop solution, only in a desperate concert situation, and always crinkly. Filing, finishing with very fine grit goes a long way.
Warm Regards,
Peter Acronico, RPT
(408) 838-2559
Sent: 8/28/2025 10:08:00 AM
When i started voicing 3 decades ago, i used Lacquer exclusively. As time went on i tried B-72 and used it for a short time, about a year, then i made a big switch to Shellac. Shellac is amazing for voicing over the others.
Lacquer is smelly and when you accidentally go past the point you want, reversing is difficult, and your left with a ping in the sound you have to mitigate.
B-72 behaves in the hammer the same way it does when you make it in the jar. It gums up. I had some Ronsen pillow puff hammers once. As an experiment, i sacked one hammer and started juicing, i wanted to see if B-72 would give me the fortissimo i want out of a pillow puff hammer. The hammer gunked up and fortissimo wasn't reached. BTW, it's kind of snippety to say "choose the right hammer so little is needed". Of course,... but you don't always have that choice, and you don't always have control over the hammer set you get either. Ronsens, for example are all over the place from hard to soft, and rarely just right.
The ONLY issue with shellac is it can yellow a hammer a little. But this turns out to a diluting issue. I think people have gone a little sideways about hardness and flexibility of a hardener. I hear 10:1's, 4:1's no, no ,no. I'm more around 32:1, even 50:1 or thinner. You see the more flexible a "hardner" is, the heavier the dilution has to be. And looking back, i also used lacquer too thick. I could use it to advantage today, but still the harsher chemicals or smell is not desirable to me. So i wanted to switch to an alcohol solvent for that reason. This comes to alcohol. I can't emphasize enough how important water % in alcohol is. You want 0% water. Everclear has 5%, denatured has 15%. That water works against you in hardening felt. So you don't really have the control you think you have and most likely blame the hammer for the difference between sets. I use 99.9% isopropyl alcohol. I was amazed at the absorption difference when i first used it.
My hardeners of choice now are shellac and sandarac. Both are easily dissolved in alcohol. Both are natural tree resins with sandarac being the hardest. I dilute both very thin. At the recommended dilution shellac doesn't seem to yellow, or at least its not noticeable. I apply two drops of sandarac from the side above the moulding in a way it doesn't wick past the midpoint for fortissimo voicing. It usually only takes i application, rarely 2. With sandarac done this way, you no longer ever have to juice below 9 and 3 even on pillow puffs. Shellac, i use in two ways. When the sound is on the closed side but with a soft attack i only put shellac on the strike point. And when the sound is too open, then i'll apply it over the top to soak down to half way to the moulding ( i had already used sandarac).
Another important point is the sound characteristics of each. To me lacquer sounds harsh and pingy, B-72 has a muddy quality, and shellac has a sweetness about its sound.
This next part may disturb people who need numbers but, when i dilute i go by eye. For example a 2 lb cut of shellac is a dark amber color. I dilute, until its a very light yellow color like fresh apple juice, a couple shades above clear.
To summarize you want a hardener to be hard, so you can dilute it to the extreme, so very little is used. Sandarac gives me the foundation to use shellac in this way.
