A couple points. Wrong technique and wrong chemical. What i call fortissimo voicing should be done from the side and basically avoid the attack area. You have to pull the action and stand it up, so the sides of the hammers are exposed. B-72 is great for brightening the attack area without creating a ping like lacquer does. But its too soft for fortissimo voicing. Besides because of its softness you need to apply way too much , and by the time it becomes effective, it gumms up the felt. I use diluted sandarac (hardest alcohol solvent resin) for fortissimo voicing and very little is required to hear a difference. Once fortissimo is taken care of, the attack usually require a little B-72 only.
I enjoyed our lunch together very much!~ It was nice meeting you!
Take Care,
Inventor of Inertia Touch Wave (ITW)
Advanced Resonant Compression Engineered Soundboards (ARCHES)
