Ditto to what Don has suggested with regard to the Paulello wire. At the U of Oregon we have had our share of string breakage. We had one player who could, at will, break any string on any piano. It was quite the chase after he was done and he is now at another university (Thank goodness!!) In the past few years I have restrung several of our Steinway grands that were notorious string breakers and replaced strings in the "breaky sections" on others. In most cases this encompasses the C6-E/F7 area. The conversion takes about three hours to accomplish including dressing the capo a bit. One Steinway B that was restrung with Mapes strings was the worst and I was replacing strings on a weekly basis. The XM wire was clearly the answer and we now enjoy an instrument that is stable and serviceable. Of course the ONE STRING that broke after the repair was just below the new wire. Ya just can't win!! Sheesh. After several years all of the pianos with the XM strings in the problem areas have performed well. Doing this on many of our pianos, and not done yet, I can say without qualification that it works as Don described. In addition I have noted that along with the enhanced durability that there is little to no difference in the voicing and even using the original tuning scheme on CyberTuner that it was not necessary to change any of the values in that section. It's a win all the way around for us with minimal fuss to accomplish.
One additional note--I find that the Paulello wire seems to settle out a bit faster that other strings and not just the XM. A spot replacement before a performance will yield a bit more stability that most other products. I also find that the false beats are a bit better as well.
When I arrived at U of O there was a whole house full of pianos that had hammers not shaped in many years. I made the commitment to correct that and the reward was pianos with reduced string damage. It wasn't eliminated but certainly going the right way as far as string breakage. Nicer to listen to and tune as well.
I am preparing the restring one of our Hamburg Ds using the Paulello strings including the XM wire. We noticed that the capo was heat treated and even a file barely touched it. Both pianos have been habitual string breakers. When we get the strings on I'll report back on the results and am looking forward to a bit more stability and less string damage on these wonderful pianos
Mike Reiter
U of Oregon (go Ducks!!)
Michael Reiter RPT
Eugene OR
(541) 515-6499
Sent: 06-26-2025 11:43
Subject: Repeated String Breakage Yamaha C7X
Thank you so much Don! This is exactly the kind of information I was after. I will get some of the Paulello wire, check the capo again and raise that glide. Much appreciated.
Teri
Sent: 6/25/2025 11:56:00 PM
Subject: RE: Repeated String Breakage Yamaha C7X
Teri,
A few thoughts:
Yamaha capo bars are sometimes VERY hard. They heat treat them to the point where they are hard to file them! So the in those pianos the strings don't dig into the V, but the hardness can contribute to the wire weakening.
A smaller radius on the contact area actually encourages the pivoting action of the wire during hard playing. This slightly reduces metal fatigue. So if you are replacing the wire in the affected area, check the radius of the V-bar underneath. If the width of the V is around 4mm, that is a 2mm radius which is good. If it seems larger, see if you are able to file it smaller. If there are deep grooves in the iron from the wires, then the capo is not too hard - file it front and back first, then smooth the bottom to get rid of the grooves. Those grooves become 'saddles' that actually grab the wire, making it harder to tune and also forcing the wire to flex on the speaking side instead of pivoting as it should.
I have had excellent luck with Paulello 'XM' wire. You can order it online from France and they will ship it direct. It really is stronger. Of course, just having fresh wire in the entire section combined with shaping the hammers nicely usually completely stops the string breaking for a while anyway, but with the Paulello wire it will hold up longer.
One last minor tip I have used in some pianos: I raise up the balance rail glide that is closest to the breaking wire. Screw the glide bolt up as high as they can go so that they don't knock. This really takes away a lot of the attack - and it will weaken the tone of course and the pianist might complain about the feeling. Don't do multiple glides - just the closest one. And of course, never do this on a performance instrument!
I've worked through this issue quite a few times with multiple piano brands - good luck!
Don Mannino
