A well thought out resolution. I wonder if the parts were Renner parts made for asean oems or perhaps counterfeit. Another issue
is how many current parts are bushed (wng excepted) using non-traditional adhesives and high frequency or led for curing. Read
past journal articles which describe in detail how Pratt-Read spent many hours glue sizing action centers and bushing and curing in
hot boxes. Most likely this was done with hot animal glue. Many of those bushings are still moving freely today even after heavy use.
Perhaps the old ways WERE better if more costly.
Sent: 11-02-2024 09:26
Subject: Seizing Hammer Shanks
David Weiss,
The problem is not mine. I did not rebuild the the piano, I did not promote or sell the piano. We as piano technicians do the best we can to serve our customers once a piano is in the home. I have explained all this to my client, he understands fully, and does not hold me responsible for his frustration and inconvenience.
I am now preparing a brief letter to the dealer, explaining what's going on. It shall be the dealer's problem (technically and financially) to resolve the matter. We go to bat when we can, but we do not own our customers' pianos and their related problems (unless, of course, we created some malfunction, which we must rectify immediately at no cost). We have enough trouble keeping our dishwashers churning and maintaining fresh batteries in our TV remotes.
David G. Hughes, RPT
David Hughes RPT
Vintage Case Parts
Glyndon MD
(443) 522-2201
Sent: 11-02-2024 08:48
"1) The problem is not mine, it's that of the piano's owner and the dealer who sold it to him,"
As we know, once you do any work then it becomes your problem. I would replace the shanks, which is the only guaranteed solution.
David
David Weiss Piano Service
434-823-9733 Mobile
www.davidweisspiano.com
David Weiss RPT
Crozet VA
(434) 823-9733
davidweisspiano@gmail.com
Sent: 11-01-2024 08:17
Cecil Snyder,
Thank you for your insights. I have two thoughts: 1) The problem is not mine, it's that of the piano's owner and the dealer who sold it to him, and 2) I dread rebushing parts. I have never been adept at it, and I am not talented enough to perform a factory-quality job. If I were king, I'd pop all the hammers off the shanks and flanges, install new (dependable) shanks and flanges, re-hang the hammers, and regulate. If the piano were mine (playing the role of my client), I'd want the seizing parts out of my action once and for all for peace of mind.
David Hughes RPT
Vintage Case Parts
Glyndon MD
(443) 522-2201
Sent: 11-01-2024 00:38
Vodka, or denatured alcohol is a cure for a specific problem, namely bushing cloth which had not been sized properly. This was common for a time in the 60s and 70s with Wurlitzers and such but I haven't seen it piano of this era. This reminds me more of the type of problem with some more modern Korean and Chinese pianos: they will go along for a time then suddenly manifest sluggishness seemingly at random and not just with the hammers, but also in the damper undercover flanges and others. This is what Don Mannino was talking about and was a fault of the bushing cloth itself.
I assume we're talking about hammer flanges specifically here. Whippen and jack flanges are pinned to looser specs. When I first encounter this I will repin the affected flanges, mark them with chalk and explain to the customer that this problem is likely to recur without warning. If a great number of the flanges have been affected I think in the long run it would be easier for everyone concerned to just rebush and repin all the flanges. In a new or newly restored piano this should be certainly be a warranty issue. This is aggravating for the customer, a big hit for the dealer but, for the technician, anything less can only come back to haunt him. It doesn't matter if it's not your fault, you have now made it your problem. And this is something that can much easier be done in the shop than in the customer's house with some significant saving of time and control of the finished product. I've used Renner's bushing cloth with good results, and I finish off with a heated broach for consistency before I repin.
Cecil Snyder RPT
Torrance CA
(310) 542-7108
Sent: 10-28-2024 14:23
I think your best bet is to do all 88 and keep track with chaulk if you want to try samples. It is reminiscent of the problems that plaque certain makes of pianos. New flanges will not solve the issue since the problem is in the pin bushing contact which is in the hammer shank. Poor quality bushing cloth could be a factor something I ran into on a Baldwin grand. No matter what I did with lubes, teflon, reaming and burnishing, new pins the same 2 notes kept seizing . I would suggest popping out the center pins and the bushings and look at smoothness of the pin cut, plating . At the same time examine the felt for quality , loose strands of wool fiber. repin and rebush some samples with top quality parts and be careful of the amount of glue. Playing the piano generates heat and can cause seizing .
If the flanges and shanks are original maybe the parts have some of the parrafin bleeding out of course you mentioned all new parts I think
Wims idea of contacting the rebuilder is good to at least find out the parts source. Hopefully the issue is not with whippens and damper flanges
