Post says agraffe. If it's the felt tap, tap, tap should help. I go over the non speaking area(s) with my tuning lever handle as a hammer on a well shaped hardwood peg.
Sent: 05-28-2023 06:24
Subject: string-to-agraffe ticking sound when tuning
Steve,
You wrote:
"Another odd thing I've noticed is that as vexing as these pianos are to tune, they tend to stay in tune quite well."
As Del has repeatedly said over the years, "If you can't fix it, feature it!"
Hmmm... what then shall we call this feature: the mezzo-thermo-nuclear multi-grip stabilizing piano wire felt/cloth interface? Isn't THAT trippingly on the tongue?!?!
Sent: 05-28-2023 01:06
It seems there are two possible assumptions, agraffes or felt (it couldn't possibly be binding at the bridge pins, could it?).
I've had some luck with using ProTec on the felts, agraffes, and other front bearing points. Some older Kawai KG's have a brown understring felt that does not do well with corroded strings, particularly in the agraffe sections and the lube helps a lot. But I don't think the agraffes being a problem can be completely discounted. Alan, in your case it might be worth removing one of the most offending strings and really inspect them, also remove the agraffe for inspection. I wonder if the agraffe develops a wire edge that flops back and forth or maybe a V groove that the string binds in.
It just occurs to me that this problem seems to be with grands only, which would point toward the understring felt.
Sent: 05-27-2023 21:41
Technically speaking, this is really an issue of normal aging within a specific design of instrument. Within the first 5-10 years of "life" this problem generally dies not occur (much). However as the thing ages, the INTENSE pressure on the counterbearing cloth produces a glazed and hardened surface to the wire and all microscopic imperfections in the wire produce a mirror image on this underfelt. It is the forced movement of this that produces the ticking. Proof of this is if one hears a very high frequency pitch in conjunction with the ticking sound. This is the vibration of the forward NSL between the cloth edge and the tuning pin.
Previous to CBL (which I have been assured contains nothing that will travel) I used to use Protek. It was OK but often required two or three applications to fix the problem. CBL RARELY needs more than one application. And in all the time I've been using it, I believe I can count only two pianos that had a few notes that absolutely did not respond to it.
Similar to what Norm was describing I sometimes like to rub the entire surface of counterbearing to spread the stuff all over and try to work it under the strings. I also squirt it all along the agraffe line for good measure. Typically I will get one tick on the very first release and then it's smooth sailing after that.
Been a game changer for me.
Sent: 05-27-2023 10:23
Benjamin,
You wrote:
"I applied McLube 444 along the part of the string that touches the felt. This was prior to reading in the journal that this is not recommended."
Guess I missed that article. Who says that it is not recommended (allegedly with the endorsement of the PTJ editors)? Lubricating the string to felt/cloth contact has worked for you (and me) and several others on this list. What is the reasoning behind NOT taking this approach? And what, if anything, was offered as a viable alternative?
Sent: 05-27-2023 09:58
Not sure what brand the piano in question is, but I had a Young Chang with the same problem. Tuning was difficult at best, impossible at worst.
It turned out to be extreme friction in the felt / cloth under the strings before the agraffes. At the recommendation of a friend, I applied McLube 444 along the part of the string that touches the felt. This was prior to reading in the journal that this is not recommended. However, it worked wonderfully and provided a waxy coat on that part of the string. The piano now tunes normally. It's been over a year since doing that, and I just saw the piano on Wednesday; no issues. My friend has been using it for about two decades now, in the same way, and hasn't reported any issues either.
Sent: 05-27-2023 07:02
Stecen,
Throughout the agraffes, worse in the bass than in the tenor.
Sent: 05-26-2023 22:41
Alan, is the problem strictly in the tri chords or does it show up in the bi or mono chords as well?
Sent: 05-26-2023 22:03
Thanks, Norman. I'll give lanolin on the bearing cloth a try!
Sent: 05-26-2023 21:37
Alan, I tend to agree with Joe. Regardless of what the manufacturer says, I presume that your problem is just friction (rust) between the strings and the bearing felt. I call it "zinging". A not-that-uncommon problem. And no, I would definitely not recommend Protek or CBL, in part because the ingredients are not on the label to certify that it might not travel and get into the tuning pins – plus apparently not as effective as the following.
In the small number of bothersome cases that I have had, where prevention is necessary or very desirable, I just use some pure anhydrous lanolin rubbed into the bearing cloth. Come back in 3 or 4 weeks and the problem will be mostly gone. Not a biggie. After 6 month the zinging is usually entirely gone. Maybe they remove too much of the lanolin in the manufacturing of the bearing cloth. I've mentioned this approach on this list previously – sorry to duplicate.
Regards, Norman
Sent: 05-26-2023 19:51
"but have not yet tried combining that with dropping the pitch a semi-tone and picking it back up. That will be next on my list. Thanks for the suggestion".
Not to blow my own horn, but this is the first suggestion I made.
Sent: 5/26/2023 7:36:00 PM
Subject: RE: string-to-agraffe ticking sound when tuning
Peter,
Well, manufacturer's service reps are only human (this far, anyway), so they, too, could be wrong.
I have applied CBL to the string along the counter bearing cloth, but have not yet tried combining that with dropping the pitch a semi-tone and picking it back up. That will be next on my list. Thanks for the suggestion.
P. S. I was thinking about you just a few hours ago while using some of your brass key bushing cauls!
Sent: 05-26-2023 19:20
Alan,
With all due respect I think the manufacturers Service Dept is quite wrong.
Since you're familiar with CBL I'm hoping you applied it to the full width of the counter bearing cloth under the strings. If this did not solve it I would apply a second "coat" and drop the tension 1 semitone and pull it back up.
Now, if that proves fruitless I would re-orient the wires by dropping one string a 3rd or so and pulling its "hitch-mate" around the hitch pin (assuming of course this is not a Bosie or some other with all looped wires). This puts "fresh" wire into the agraffe. IF, in fact it is actually an agraffe issue this may treat it for a while.
Otherwise I would guess that there is something weird about the counterbearing cloth/felt.
Sent: 05-26-2023 17:51
How about applying a little diluted vinegar to the agraffe? It cleans up brass and won't affect steel. Let it sit for a few minutes and then apply something to wash it out and neutralize it afterwards.
-OR-
Since we already use Flitz to clean things like fallboard brass, how about applying a tiny bit, perhaps diluted with something so it can flow into the agraffe hole, to maybe clean up that string/brass contact point?
I've never tried this, it was just a wild thought, so please tell me I'm whacked if this is a stupid crazy idea.
