The Equations and Solutions of Unequal Beating Temperament System - Kirnberger III
Introduction
I posted the complete study package of the Equal and Unequal Beating Temperament System (https://my.ptg.org/discussion/equal-and-unequal-beating-temperament-system-complete-study-package) on 16th January 2026. The purpose of this post is to show why 0.966360326 is the universal solution to 9 decimal places for Unequal Beating Temperament System - Kirnberger III (https://my.ptg.org/discussion/unequal-beating-temperament-system-kirnberger-iii-and-kellner), which I have calculated in the Excel file for this temperament in the complete study package of the Equal and Unequal Beating Temperament System by using Goal Seek. I mentioned in my discussion thread for Unequal Beating Temperament System - Kirnberger III that when one is focusing on beat rates, cents lose their meaning. I also mentioned in that thread that the System of Cents has been baked into the Equal and Unequal Beating Temperament System. I gave Cent = 21 / 1200 as the standard definition of the cent. This post will illustrate that cents are eliminated from the equations and the solutions of this temperament, leaving us with frequencies and beat rates in Hz, which is the main objective of the entire Equal and Unequal Beating Temperament System.
Overview of Tools
I have used various tools throughout my mathematical explorations:
Microsoft Excel → Wolfram|Alpha (Online Calculator: https://www.wolframalpha.com) → MathPapa (Online Calculator: https://www.mathpapa.com) → Perplexity AI (Online AI: https://www.perplexity.ai) → MathGPT (Online AI: https://math-gpt.org) → Microsoft Excel
Equation
((((((((((((((((((((((((440 × 2 + (Δ × 3 × ((1200 × log2(81 / 80)) / (1200 × log2(531441 / 524288))))) / 3) × 4 + (Δ × 3 × ((1200 × log2(81 / 80)) / (1200 × log2(531441 / 524288))))) / 3) × 2 + (Δ × 3 × ((1200 × log2(81 / 80)) / (1200 × log2(531441 / 524288))))) / 3) × 4 + (Δ × 0)) / 3) × 2 + (Δ × 0)) / 3) × 4 + (Δ × 0)) / 3) × 4 + (Δ × 0)) / 3) × 2 + (Δ × 0)) / 3) × 4 + (Δ × 1 × (((1200 × log2(531441 / 524288)) - (1200 × log2(81 / 80))) / ((1200 × log2(531441 / 524288)) / 12)))) / 3) × 2 + (Δ × 0)) / 3) × 4 + (Δ × 0)) / 3) × 2 + (Δ × 3 × ((1200 × log2(81 / 80)) / (1200 × log2(531441 / 524288))))) / 3) = 220
Source: https://my.ptg.org/discussion/unequal-beating-temperament-system-kirnberger-iii-and-kellner
Important notes: The Circle of Equally and Unequally Beating 5ths and 4ths is a Pythagorean-Grad Temperament System, which has been modified to create the Pythagorean-Grad-Syntonic-Schisma Temperament System. The base of the logarithms can be changed to modify this equation, but the same one should be used throughout to remain consistent. There are different ways of expressing the arithmetic operations addition, subtraction, multiplication, and division for programming purposes. For example, either the hyphen-minus symbol (-) or the minus sign (−) can be used in the equation above.
Solution
Δ = 1573660 / (402225 × (log2(81 / 80) / log2(531441 / 524288)) + 1259712)
It took several attempts to find this solution by using AI. The one AI that worked in the end was MathGPT, which only just managed to figure out this solution after many tries. Perhaps I am at fault. Maybe AI is at fault. I have checked this solution by pasting it into the Excel file for Unequal Beating Temperament System - Kirnberger III that is inside the complete study package of the Equal and Unequal Beating Temperament System to ensure that it is indeed correct. This is the needle in the haystack for Unequal Beating Temperament System - Kirnberger III.
Commas
Commas are discrepancies in the mathematics of music. In the Equal and Unequal Beating Temperament System, they are being managed via the distribution of beat rates across intervals. I included in my discussion thread for Unequal Beating Temperament System - Kirnberger III the following commas:
Pythagorean Comma = 1200 × log2(531441 / 524288) = 23.460010385 cents
Syntonic Comma = 1200 × log2(81 / 80) = 21.506289597 cents
Grad = Pythagorean Comma / 12 = 1200 × log2(531441 / 524288) / 12 = 23.460010385 cents / 12 = 1.955000865 cents
Schisma = Pythagorean Comma - Syntonic Comma = 1200 × log2(531441 / 524288) - 1200 × log2(81 / 80) = 23.460010385 cents - 21.506289597 cents = 1.953720788 cents
Cents Ratios
Syntonic Comma / Pythagorean Comma = (1200 × log2(81 / 80)) / (1200 × log2(531441 / 524288)) = 21.506289597 cents / 23.460010385 cents = 0.916721231
Schisma / Grad = (1200 × log2(531441 / 524288) - 1200 × log2(81 / 80)) / (1200 × log2(531441 / 524288) / 12) = (23.460010385 cents - 21.506289597 cents) / 23.460010385 cents / 12 = 1.953720788 cents / 1.955000865 cents = 0.999345229
Insights
I have got the Δ and s variables from Alfredo Capurso's Circular Harmonic System (https://www.scribd.com/document/174787881/Alfredo-Capurso-A-New-Model-of-Interpretation-of-Some-Acoustic-Phenomena-Circular-Harmonic-System-C-HA-S).
There are an infinite number of ways to express the equations and solutions of this temperament by changing the base of the logarithm in both the beat rate (Δ) and the beat rate modifier (s). The following bases are just a handful of the ones that are available:
- Log Base 2
- Log Base 3
- Log Base 10
- Natural Logarithm (Log Base e or ln)
- Log Base 531441 / 524288 (Log Base Pythagorean Comma)
- Log Base (531441 / 524288)1 / 12 (Log Base Grad)
- Log Base 81 / 80 (Log Base Syntonic Comma)
- Log Base 42515280 / 42467328 (Log Base Schisma) [Pythagorean Comma (Ratio) / Syntonic Comma (Ratio) = (531441 / 524288) / (81 / 80) = (531441 / 524288) × (80 / 81) = (531441 × 80) / (524288 × 81) = 42515280 / 42467328]
- Change of Base Formula
- Decimal Form
Logarithms are being divided in both the Δ and s variables. Two things are happening:
- The change of base formula logc(a) / logc(b) = logb(a) expresses the division of logarithms that share the same base in the form of a logarithm with a different base.
- Cents are eliminated by dividing two logarithms with the same base (cents / cents).
If the base of the logarithm has changed, then the definition of the cent has changed, which means that multiple definitions of the cent exist in the Equal and Unequal Beating Temperament System. It is possible to eliminate cents when the definition of the cent is the same because the unit is the same. What would happen if we were to divide logarithms with different bases? We would end up with a hybrid cents unit (cents1/cents2), but it would still be possible to express it in the form of a cents ratio (cents / cents) by using the change of base formula.
In the next section, I will illustrate why the solution for Unequal Beating Temperament System - Kirnberger III is always the same when the logarithmic base is the same throughout its equation.
Log Base 2
Δ = 1573660 / (402225 × (log2(81 / 80) / log2(531441 / 524288)) + 1259712) = 0.966360326
Log Base 3
Δ = 1573660 / (402225 × (log3(81 / 80) / log3(531441 / 524288)) + 1259712) = 0.966360326
Log Base 10
Δ = 1573660 / (402225 × (log10(81 / 80) / log10(531441 / 524288)) + 1259712) = 0.966360326
Δ = 1573660 / (402225 × (loge(81 / 80) / loge(531441 / 524288)) + 1259712) = 0.966360326
Δ = 1573660 / (402225 × (log531441 / 524288(81 / 80) / log531441 / 524288(531441 / 524288)) + 1259712) = 0.966360326
Δ = 1573660 / (402225 × (log(531441 / 524288)1 / 12(81 / 80) / log(531441 / 524288)1 / 12(531441 / 524288)) + 1259712) = 0.966360326
Δ = 1573660 / (402225 × (log81 / 80(81 / 80) / log81 / 80(531441 / 524288)) + 1259712) = 0.966360326
Δ = 1573660 / (402225 × (log42515280 / 42467328(81 / 80) / log42515280 / 42467328(531441 / 524288)) + 1259712) = 0.966360326
Δ = 1573660 / (402225 × log531441 / 524288(81 / 80) + 1259712) = 0.966360326
Decimal Form
Δ = 1573660 / (402225 × 0.916721231 + 1259712) = 1573660 / (368728.197138975 + 1259712) = 1573660 / 1628440.197138970 = 0.966360326
Conclusion
It is just a bunch of numbers in the end.
Roshan Kakiya
