Hi Tim,
It's great to hear from you! You have made some very interesting points, and I shall go through them paragraph by paragraph.
Paragraph 1: Interesting stuff! Am I correct to understand that what makes these "equal beating" (EB) is that the tempered fifths beat equally? I am not seeing any of the thirds beat equally, though 7 pure fifths allow major/minor thirds to be synchronously (which is the case using regular offsets for these temperaments). Do you feel there is any practical reason to have fifths equally beating when functionally speaking, the fifths would rarely be played together in real music? The tempered fifths in your alternative temperaments don't seem to have any benefit to the major/minor third beat synchrony, which I believe is one of the practical benefits of unequal systems.
Response 1: Yes. I am using a system that I have developed called the Equal and Unequal Beating Temperament System, which is based on what I have learned by studying Alfredo Capurso's Circular Harmonic System and Bill Bremmer's Equal Beating Victorian Temperament. As you can see, the Circle of Equally and Unequally Beating 5ths and 4ths acts as the blueprint for each temperament. It standardises the Equal and Unequal Beating Temperament System. The Equal Beating Victorian Temperament clearly showcases how the Equal and Unequal Beating Temperament System can be used flexibly to make specific intervals beat equally in a manner that creates a coherent whole in the form of a fully usable temperament without any wolf intervals. You could say that I have found the middle ground between piano tuning and music making, where the emphasis is on standardising beats-based temperaments to achieve musical goals such as narrower 3rds in the "home" keys and wider 3rds in the "remote" keys.
Paragraph 2: Your EB Kellner seems usable, although the A-E fifth at 5.8 cents narrow pushes my own limit (I have found a 1/4 syntonic comma at 5.4 cents narrow is about the top of my usable limit, at least when used for modern music). For this reason, your EB Kirnberger III I would not use for most circumstances, with a 7 cent narrow A-E fifth, unless for earlier music. (I tune Kirnberger III regularly.)
Response 2: When one is focusing on beat rates, cents lose their meaning. The System of Cents (Cent = 21 / 1200) has been baked into the Equal and Unequal Beating Temperament System. The emphasis is on the beat rates and beat ratios, not the cents values. The primary unit of measure is Hz. The secondary unit of measure is cents. I have decided to construct Kellner by distributing the Pythagorean Comma across D4-A4 (5th), D4-G4 (4th), C4-G4 (5th), B3-F#4 (5th), and A3-E4 (5th) within the Temperament Octave A3-A4 to ensure that the Circle of 5ths and 4ths closes. Every tempered 5th and 4th beats equally in Kellner within the Octave A3-A4 for tuning purposes. In Kirnberger III, I have distributed the Syntonic Comma across D4-A4 (5th), D4-G4 (4th), C4-G4 (5th), and A3-E4 (5th) in order to make them beat equally within the Octave A3-A4 and get as close as possible to making the C4-E4 Major 3rd beatless. I have tried to remain faithful to the original intent of each temperament rather than its design alone.
Paragraph 3: Is there a practical reason you placed the schisma in your EB Kirnberger III between F#-C# instead of B-F# where it is traditionally placed? F#-C# schisma placement is Kirnberger II (1771 version), not III to my knowledge. If memory serves, the 1776 Kirnberger II combines the schisma into the two tempered fifths (D-A, A-E), making these 1/2 Pythagorean commas and slightly inverting the C-E and G-B "pure" major thirds. These are some gnarly fifths for sure!
Response 3: As I understand it, the Schisma was originally placed on the 5th F#-C# in Kirnberger III. I have placed it on the 4th C#4-F#4 in my standardised sequence of 5ths and 4ths to be faithful to its original design. It seems to me that this is a strategic move because it simultaneously minimises the harshness of multiple Major 3rds as you go round the Circle of 5ths and 4ths. From my perspective, the Major 3rds get harsher if there are more consecutive beatless 5ths and 4ths in that Circle. The aim is to disrupt that chain on purpose by introducing a comma in the specific place on that Circle where many Major 3rds are narrowed in order to reduce their harshness. This strategic move is evident in various temperaments, e.g., Kellner, Kirnberger III, and Werckmeister III.
I hope that I have answered your questions sufficiently! I am always open to challenging my own understanding and getting to know other people's perspectives.
Roshan Kakiya
Sent: 01-03-2026 11:38
Subject: Unequal Beating Temperament System - Kirnberger III and Kellner
Hi Roshan,
Question: Is there a practical reason you placed the schisma in your EB Kirnberger III between F#-C# instead of B-F# where it is traditionally placed? F#-C# schisma placement is Kirnberger II (1771 version), not III to my knowledge. If memory serves, the 1776 Kirnberger II combines the schisma into the two tempered fifths (D-A, A-E), making these 1/2 Pythagorean commas and slightly inverting the C-E and G-B "pure" major thirds. These are some gnarly fifths for sure!
