We added the felt during restoration to cancel the extra free section of music wire. The sound was too different (very open sounding, lots of high frequency information/harmonics) in the original to leave it unmuted. The concert grand has two open lengths of string, both 2" long, between the capo bar and tuning pins sections in the top two sections that were totally unmuted by felt. They will be muted in the completed restoration.
O.A. Watson
Sent: 04-16-2025 21:06
Subject: The Knabe sound
I'm not seeing an extra duplex? Certainly a felt strip kills that idea.
Inertia Touch Wave(ITW) The most advanced silky smooth actions.
Engineered Hygroscopic Soundboards. The strongest and lightest boards made today for acoustic projection, richness and warmth.
Sent: 04-16-2025 17:43
I have restored an old Knabe that was made in 1903. It is 6'5" long. I also noticed a difference in the tone quality of that piano. I currently have a 9' Knabe that was made in 1915 that is in my shop to be rebuilt. I have included a picture of the duplex section of the 6'5" piano here. I believe that the difference in tone is due to the extra duplex section of wire close to the tuning pin fields. Both pianos have this design.
O.A. Watson
Watson Piano Works
San Marcos TX
(512) 757-5556
Sent: 04-16-2025 16:26
Back in the day...the Big Five: Steinway, Baldwin, M&H, Chickering, Knabe...all had their own distinctive sound such that one could tell without looking what the brand was.
Sent: 04-16-2025 11:48
Hello David,
While I agree that the tuning both resonates incredibly well and brings out the singing characteristics in quality pianos generally, I'm referring to a particular "Knabe tone" that I hear regardless of tuning. It's so hard to describe, but it seems broader than the characteristic Steinway tone, but still a distinctly "American" piano sound. It also seems to have a longer "attack" (onset) than others pianos. The tenor and mid range have a cello quality, which I do believe the Paulello wire helps with as well, but type 0 was only used from A2-G3, so I know that's not affecting the G#3-E5 where I hear this quality very prominently.
Sent: 04-16-2025 10:16
I've just listened to the recording which is particularly good. But it's not the piano that's unique - it's good - but not unique. What's doing the singing is the tuning and from my experience now of nearly two decades, this is the sort of sound that I'd expect from a good instrument when tuned to the sort of methodology of tuning that we're applying to unequal temperament and tuning.
By aiming for resonance, and putting the power of the sound into the fundamental frequencies of the notes and using every aspect of the acoustics to reinforce the fundamental sounds we're putting the natural piano characteristics of the instrument on steroids.
Whether Steinway, Bechstein, Bluthner, Knabe, M&H or even Yamaha it's the tuning that's the cherry on the cake of a good instrument.
Here
https://www.youtube.com/watch?v=_52SJEgY2YU is a Yamaha C6 and partly assisted by the voicing I used for the concert, tuned to the variation of Kellner then rather than KIII, but similar, perhaps the instrument might sound better than a standard Yamaha . . . . ?
Good unequal temperament tuning improves the sound of pianos. Steinway just think I'm nuts.
Sent: 4/15/2025 7:52:00 AM
Subject: RE: The Knabe sound
I have long admired the unique shape of original Knabe hammers. They have (from my observation) the LEAST amount of wood in the tail of any hammer around. Many of us learned years ago from Wally Brooks that it's important to reduce the mass BEHIND the shank as it helps to get the hammer away from the strings faster, thus doing less "damping". Knabe (and a few others) clearly was aware of this phenomenon and incorporated it into their design.
Also, if I'm not mistaken, Steinway used Adirondack spruce back then in their boards...maybe up to the 40's...? Any confirmation of that? It does make a difference.
Edit: My standing order at Ronsen is to enlarge the cove as much as possible to reduce mass. He always does a nice job.
Sent: 04-14-2025 23:01
I just made a quick recording of my piano. The mic is not wonderful and it doesn't quite capture what I'm hearing as I play, but it does capture the intensity of the melody.
Mendelssohn on Knabe C
Sent: 04-14-2025 14:15
I rebuilt mine, original soundboard, hybrid stringing and rescaled, Abel natural felt hammers. Although hybrid stringing helped the tone of the low tenor, I'm talking about a general quality I hear in Knabe pianos. Here is the same model and similar year to mine- again, a similar sound (though I like mine better).
https://youtu.be/vhrnznBnLWo?si=KckNNSHn7AfUnfuD
Sent: 04-14-2025 12:09
Note, in the Youtube discussion that the piano was "rescaled by Paulello and using Ronsen hammers."
What sort of work was done on your piano?
Sent: 04-14-2025 07:36
Knabes of this era were made in Baltimore MD (the Ravens stadium is currently where the old factory was located). Aeolian bought them in the early 1930's. I believe production stayed in Baltimore a while longer until the operations were moved to New York.
Sent: 04-14-2025 07:31
The rebuilder in the video went to a lot of trouble to save those tuning pin bushings! Knabe advertised their superiority for vocal accompaniment. I assume they were produced in the same factory as the other Aeolian makes (Chickering, Steck, Mason & Hamlin).
