I recall Willis Snyder said that he tried converting a Steinway (unbushed) design to a bushed design, enlarging the holes to accept the bushings. He said it was a failure. Though I forget now precisely what he said happened as a result, I do believe that it was Willis that pointed out the fundamental design difference in these two construction methods. I do recall him saying he would never do it again.
Sent: 04-08-2023 13:20
Subject: Tuning pin bushing hole alignment
What is the thickness of the plate webbing of a Steinway, compared to the thickness of the webbing on pianos that have bushings?
Sent: 4/8/2023 1:09:00 PM
Subject: RE: Tuning pin bushing hole alignment
My understanding is that there is a fundamental difference in principle between bushed and non-bushed pinblock/plate mating.
A non-bushed plate transfers the entire stress load to the plate flange, therefore requiring a very close fit throughout to donits job as designed. The bushed plate spreads the stress load out between all 230 or so tuning pin holes, and in effect actually pulls the pinblock away from the flange slightly making block/flange fit less critical. The height of the coil on the tuning pins also has some effect on this, the higher they are the more pull back. Nonetheless I still shoot for as good a fit as I can get when I replace a block no matter whether bushings exist or not.
Sent: 04-08-2023 12:08
Some more things to consider, could another option be to not use bushings at all? Some famous makers do this. Perhaps the thickness of the plate in the tuning pin field is a factor wether to use bushings or not. Some bushings are harder than others and the hole diameters may also vary. I have had bushings split when driving tuning pins. I have heard it said many times that the bushing is a 'guide' for the drill. I have also heard discussion that the bushings can compensate for a poorly fit pinblock to plate flange.
Jonathan Moberg
Moberg Piano Sales & Service
414-962-2227
mobergpiano.com
Sent: 4/7/2023 10:17:00 PM
Wim, you just saved me many hours of work, thank you! 😊
Tim Foster
Sent: 04-07-2023 21:49
Tim
Put in the pinblock bushings and then string the piano. The bushings will give way to allow the pin to go in the pinblock hole. There is no need to drill out the bushings.
Sent: 4/7/2023 9:32:00 PM
Sorry for the confusion. Yes, Wim, I used the procedure you described exactly. I only meant that I am not drilling the pinblock through the plate after I installed it.
Tim Foster
Sent: 04-07-2023 21:25
Tim
Explain how you pre-drilled the pin block. Did you fit the plate flange, then held the block in place with four or five big clamps to hold the block to the plate? Then did you drill dimples in the block using the webbing of the plate as guides? Then took the block off the plate and, using a drill press and an angled platform, drill the holes using a pin block drill for a OO tuning pin?
If you didn't do that, then you're not going to able to aligning the holes in the block to the holes in the plate.
WIm
