Nathan,
Good to hear from you. I think this is the method I introduced to you in my shop?
At UNT, we used a spoon bit, but I find this takes away too much material, is difficult to keep cool and may cause differences where the hardness and density of the block differs. Now, I typically use a copper rifle bore brush about .008 larger than the intended tuning pin. It will take off the glaze and only a microscopic amount of material. I only do this by hand so I can get better tactile feedback and there is little risk of over-boring the hole. I haven't done a restring without replacing the block since I moved to TN, so I don't recall the exact diameters off hand. However, there may certainly be factors that determine if the original block should be used, such as case construction and/or fidelity to be as close to original as practical.
I use Klinke pins because you can get them in half sizes, and because they are the most precise. Sometimes WNG if situation calls for them.
On Baldwin or Delignit blocks I only increase one size. In my experience there is almost never a cause to replace this type unless they have been previously restrung, have delaminated or client insistence.
Dave Conte, RPT
Piano Technician in Residence
The University of Tennessee
College of Music
Knoxville TN
(817) 307-5656
Owner: Rocky Top Piano
Sent: 03-04-2025 07:24
Subject: Tuning Pin Size for Restringing w/ Original Pinblock
Oh, I used the one from Schaff, sold as "Tuning pin brush" number 270-B. I just clamp it in vise grips and run it in and out of each hole a few times. It could be chucked in a drill as well.
I assumed at first it was the same thing as the bore hole brushes that Wim mentioned, but after an internet search for those I think this might be a bit more coarse than what one would use on a rifle. I've done more than an entire piano with one and didn't feel the inclination to change it out.
Sent: 3/4/2025 6:02:00 AM
Subject: RE: Tuning Pin Size for Restringing w/ Original Pinblock
Thanks for the input Nathan - what sort of steel brush are you referring to?
Terry Farrell
Farrell Piano Service, Inc.
Brandon, Florida
terry@farrellpiano.com
813-684-3505
Sent: 03-03-2025 18:13
Recently, at the suggestion of Dan Reed, I tried going from fairly loose (i.e still holding pitch but not very well) 2/0 pins straight to 3.5/0 lo torques. I used the steel brush but did not ream. They came out feeling very nice.
