Patrick,
A fresh (and very good) tuning does in fact seem to expose other less desirable sounds the piano might already be making, since there's less "garbage" in the overall sound. The tuning cleaned up the "loose" garbage but the "embedded" garbage was left untouched. Naturally, her "eye" is now focused on that remaining garbage.
Im sure that you WILL in fact determine the source and treat it. The unfortunate side of this (be prepared) is that now that she has "tuned in" to it, she is hyper focused on it, and even when you reduce it to a reasonable level (similar to the others around it) she will hyper focus even more on those notes trying to "hear" it, such that even the slightest hint of the sound will still bother her.
Therefore, once you find and fix it, make a determined effort to show and explain the cause and get her to VERBALLY ACKNOWLEDGE the fact that it's better. (If she won't do that you're in trouble). Show how others notes have it too, just not as much.
Another tip...check all the casters to make sure they're all firmly engaged with the floor. Very typically one of the four is not quite the same. This can induce a twist with weird resonances (sometimes), exascerbating other things.
Not a fun situation to be in...been there, done that.
Sent: 10-29-2025 18:20
Subject: Wurlitzer clunk sound when key falls back-exasperated!
I would like to underscore Chris' point about the importance of asking, when sleuthing an unwanted sound,"What material(s) do I think I am hearing?" Taking that approach can and often does expedite the hunt, in my experience.
Sent: 10-29-2025 11:58
You should learn how to distinguish between the noises a piano can make, which can help your diagnosing skills.. "clunkie" doesn't quite cut it. There are wood to wood noises, wood to felt noises, metal to wood noises, metal to metal noises, and metal to felt noises. I find that when they are difficult to find, i'm thinking loose capstans and loose leads. Those would be metal to wood noises btw.
Good Luck Patrick.
Sent: 10-29-2025 11:35
I have found this in a number of spinets. The cheaper and older, the more likely they are to have this problem. It might be hard back rail felt, or hammer rest felt - any number of things, including loose keys.
There is another thing to consider here. It's almost certain that the sound was there before you tuned it, and now the customer notices it because she is listening in a different way, or they are just listening period when they weren't before. I have seen this happen with all sorts of variations. Sometimes I will tune a piano and then customer calls to say that there is a pedal noise. There isn't any pedal noise, but now that the piano is in tune, when they use the pedal the customer notices the complexity of the sound. They are just listening differently, or more closely. I once got a call from a church, where they had just moved a piano from one room to another, and someone noticed that it was out of tune. When I got there, it was almost perfectly in tune, but the sound was harsh so I needled the hammers.
It is totally fair to point out that tuning does not affect the mechanical parts of a piano. If you take your car to a tire place to get new tires, and then something goes wrong with the transmission, you don't complain about it to the tire place, an analogy you might use in this sort of situation.
At this point in my career, when someone calls to tell me that something is wrong with their piano after I tuned it, I tell them that if I return and find the piano is in tune, or that the problem is unrelated to any work I did, there will be a fee. I do it politely, but I don't hold back.
