I can't help you with Vetituner, but as far as bass tuning goes, I have a few thoughts. Bass is the most harmonically complex portion on the piano. Additionally, below E2 (I believe), the upper harmonics generally have greater amplitude here than the fundamental, though our ear "interprets" the harmonic information and our brains reconstruct the fundamental. Psychoacoustics are the coolest thing! Practically speaking, tuning the bass well has a dramatic effect on how our ears reconstruct the fundamental. On small pianos, the difference between a mild stretch (6:3) and a larger stretch (8:4, 10:5) is so great, that I believe it's wise to stick to the 6:3 and call it a job. Finding a "middle ground" between any two of these numbers will make all the octaves sound out of tune at every coincident. More importantly, it's not giving our brains enough information to reconstruct low fundamental frequencies. On larger pianos, however, a good middle ground can be so close in many coincident partials, that splitting the difference can really enhance the sound of the bass. For example, if you are tuning C1, silently hold C1 and C2 with your left hand. While holding, play a fairly loud G3, C4 and E4, hold for a second or so, let go of these keys while still holding your silent bass octave and tune C1 to find the best blend of the harmonics. Check your ETD and see what octave placement you tuned aurally, which will give you an idea of what settings with the best for the particular piano and your ear. You may find that the partials excited from G3 (6:3) and C4 (8:4) are very still but E4 (10:5) is beating faster. You may then choose 8:4 octave stretch since this gives a better resonance with the piano than a 10:5 would. Does this make sense?
Sent: 05-08-2026 08:21
Subject: Verituner settings
Summer,
You may find my comments harsh, however I find that one of new tuners' biggest stumbling blocks is that they don't fully understand the SOURCE of the beats they're supposed to listen to. I know this because that was my issue when I was learning. The books I used and my first instructor were not CLEAR and specific on identifying and isolating the relevant partials. KNOWING THIS (not guessing) is a game changer when learning aural tuning.
Honestly answer me: Can you quickly locate the beat source for a M3rd or M6th? (Don't get upset if your answer is "no". This is what education is all about).
Aside: I flunked Algebra II in high school (though I did extremely well in Algebra I and other math) because my teacher (though very smart) was unable to simplify things and explain the WHY behind the math. Had I understood this I could figure out how to do it. Unfortunately that never came and I got discouraged and gave up. (Hopefully you get what I'm driving at here).
Sent: 05-07-2026 22:52
Hello, Peter,
Spot on.
Kind regards,
Horace
Sent: 5/7/2026 10:31:00 PM
Subject: RE: Verituner settings
Summer,
Tuning aurally (a.k.a., analog...meaning to compare), REQUIRES that you 1) Know where to find the beats for any given interval, 2) What other intervals share the same beating partial(s), and 3) Listen to these beats and learn to compare their relative speeds in whatever context you are using them. It is exactly like learning to speak another language.
I've been doing this over 50 years and have yet to see someone who starts with a digital brain eventually discard that for their far superior analog brain. If you keep using the ETD, you will end up using the ETD, and do the absolute bare minimum analog...just enough to "pass" the exam...and then continue relying on the ETD. Aural tuning will become non-existent for you...guaranteed. Mark my words.
Sent: 05-07-2026 11:57
Summer --
I think that questioning Verituner over your instructor is not going to be the best path moving forward. If you plan on taking the RPT Tuning Exam, and I recommend you do, then you need to meet the requirements for that exam, which may be different than what your instructor is teaching you. I believe that all the major ETD's will meet those requirements, out of the box. The tuning exam, as I learned the hard way, is not about completing a tuning that pleases your ears so much as it is meeting the requirements of the test.
I further recommend that if you are interested in learning to tune aurally then you need to do that first. Don't get hooked on the ETD before you learn how to listen. The technology is so good that it's just too easy to let it take over. And because it's so good, and easy, so many of us wind up seldom going back to full aural tunings after that. That said, I used RCT as a check on my aural tunings when I was practicing for the exam. I would tune the whole piano, by ear, than use RCT, in exam mode, to check what I had done.
There are many aural tuning temperament sequences out there. They all will get you to pretty much the same place. Using the checks in those sequences, your aural tuning skills will then be needed to fine tune that sequence into the temperament you want to spread out over the rest of the piano. What you need to do is try several of them and find the one that you are most comfortable with, and the one that you can actually remember. Personally, I use the Swafford Every Which Way temperament sequence. It's the one I used to pass the tuning exam. Here is a link:
https://www.scribd.com/doc/2424528/Every-Which-Way-Temperament-Swafford
Finally, learn how to tune aurally, using your ETD as a check, before you start messing with the ETD settings to try and make it match what you want do to. Once you pass the tuning exam, and once you can nail down a good aural tuning that meets all those requirements, you will have a more educated idea of how you may want to tweak the ETD settings. The settings are there to tweak but resist that temptation until you know what you are doing.
The PTG Store has a series called PACE that is very helpful in learning the basics of tuning and repair. They are written, specifically, to help you pass the exams as they are given and graded. The exams are really a necessary starting point from which you can then start to really learn. Go to PTG Conventions and Conferences and really learn.
