I didn't check the rim. Next time I will pull the pick away from the wall and check the back too.
P.S. Piano Service
Sent: 04-08-2026 22:56
Subject: Yamaha console tenor bridge unglued
Peter,
If you have not already done so, you might want to check carefully to see if the soundboard might also be separating from the "rim", perhaps in the same general area as the bridge is separating.
Sent: 04-08-2026 21:34
Peter, it's hard when someone is hearing something you don't. One thing I would ask if you haven't already, is 'when' they are hearing the high frequencies, on the attack or when they lift their finger up. Perhaps it's the dampers and fluffing them up a little with solve the problem.
Sent: 04-08-2026 19:12
Hi Ed,
You are correct that this repair will not definitively solve the client's problem, and she is aware of that. I did do some voicing, but that didn't seem to help. The only thing that seemed to help was pressing on the bridge. My "quick fix" was wedging a few felt mutes between a plate strut and the bridge, which seemed to help, but not 100%.
Also, the worst offender for her was A3, which is not a wound string.
Peter Stevenson RPT
P.S. Piano Service
Prince George BC
(250) 562-5358
ps@pspianos.com
Sent: 04-08-2026 12:07
Peter-
I'm not sure your diagnosis established that the problem is caused by the slight gap between the bridge and the soundboard.
The wound strings at the end of the bridge tend to sound different from their neighbors.
You might consider voicing the hammers for those two notes and see if that solves the problem.
